Wireless
9021 Discussions
problem with wifi
JCast40
Hi, I do not know how much you understand since this is from Google but I will tell you my problem.
I just bought a Veriton M4640G computer and when I got home I noticed that it does not have the wifi adapter, I started looking for it, downloaded it and installed the proset / wireless. The problem is that it seems that the driver was not installed.
AlHill
Does your computer have a wifi adapter or not? If it does not have the physical adapter (card or chip), then downloading the driver will not help you.
Download, run, and ATTACH the results of this utility:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then, an Intel support engineer can assist you.
Also, there is no need for google. Just use your language and the forum software can translate.
Doc
JCast40
Oh! gracias,debi haber parecido un estupido.
AlHill
You do not have a wireless adapter in your device.
Doc
JCast40
Ya veo =_= al menos me hubieran dicho esto cuando la compre pero bueno. Gracias por tu ayuda 👍
AlHill
Glad to help.
Doc
