Wireless
8782 Discussions
unattended upgrade with ADDLOCAL
Hi there.
I'm facing a problem with software upgrade and adding some features to it, at the same time.
I'm trying to upgrade Intel Pro Set 11.5.1.2_x32 to 12.1.2, and trying to add WIFI_SSO and WIFI_PLC to software configuration.
I'm using a command:
\msiexec /i "\Intel PROSet Wireless.msi" /qn ADDLOCAL=WIFI_Driver,WIFI_SSO,WIFI_PLC REBOOT=ReallySuppress
the only thing I'm getting is: software upgrade installed as default, no WIFI_SSO or WIFI_PLC installed.
If I re-enter above command once again, it will install WIFI_SSO and WIFI_PLC features.
My question is: can I have upgrade software and changing features at the same time?
OS=XP PRO
Greg.
EDIT
solved by running batch file with 3 lines in it:
1 line - silent upgrade (it installs everythin as it was in previous installation
2 line - ADDLOCAL WIFI_SSO,WIFI_PLC
3 line - REMOVE (every functionality that is not needed eg: Admin_Toolkit)
is there a other way to do it?
