Wireless
8782 Discussions
unstable bluetooth and wifi connection after update of AC9560 intel installed
danw
Both bluetooth and wifi are unstable and computer require a hard reboot to reinstall the drivers. Error message say error 10 "not installed" or missing driver . reboot corrects this but wifi connection is lost regularly.  The bluetooth icon disappears and no "on" button exists and says bluetooth not installed.
I have run dism & sfc with no results.
All this happens after a windows update.
Can anyone help?
Esteban_D_Intel
Hello danw,
To better assist you please provide the following information:
  • Please provide the version of Windows* that was previously installed.
  • What is your current wireless driver version?
  • Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
To gather more information about your system please run the following tool and attach the reports generated.
Intel® System Support Utility (Intel® SSU) Download link
1. Open the application and click on "Scan" to see the system and device information.
2. By default, Intel® SSU will take you to the "Summary View".
3. Click on the menu where it says "Summary" to change to "Detailed View".
4. To save your scan, click on "Next", then "Save".
Esteban D.
Intel Technical Support Technician
danw
see attached intel scan details
Esteban_D_Intel
Hello danw,
Thank you for your response.
Can you also provide the information that was previously requested? This will help to determine what could be possibly causing this behavior.
Please confirm the following:
  • Is this the original adapter that came pre-installed with your laptop?
As you may know error code 10 in device manager could indicate two things:
1)  Driver corruption.
2)  Hardware failure.
Usually a Code 10 is a temporal error generated when Device Manager cannot start the hardware device.
I would recommend the following:
Cold Reboot process:
  1. Perform a cold reboot (hold the power button until the PC powers off).
  2. Access the BIOS (Refer to your computer manufacturer for guidance)
  3. Load BIOS defaults. (Refer to your computer manufaucturer for guidance on settings/updates)
  4. Test connectivity once the system boots.
If the behavior persists, then I would recommend a Clean Install of your Wireless /Bluetooth drivers. However, please use the drivers provided by ASUS*.
You can find them here.
This is because system manufacturers regularly customize Intel generic drivers to meet the needs of their specific system design.
I would recommend the installation of the drivers provided by the manufacturer to avoid any potential impact caused by loading non-customized drivers and ensure top performance.
Please check the Clean Installation of Wireless Drivers as a reference.
Esteban D.
Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third-party endorsement of Intel or any of its products is implied.
Esteban_D_Intel
Hello danw,
Were you able to check the previous post?
Please let me know if you need further assistance.
Esteban D.
danw
computer sent or service as both wifi & bluetooth a problem. Bluetooth now says "failure to power up".
Esteban_D_Intel
Hello danw,
Do you still have the laptop with you?
Are you getting error code 10 in device manager for both devices?
Were you able to follow the steps provided above? (BIOS defaults + Clean Install of driver) Same behavior after those steps?
Esteban D.
Esteban_D_Intel
Hello danw,
Esteban D.
Esteban_D_Intel
Hello danw,
We have not heard back from you.
I hope that you were able to resolve this behavior after replacing the possible faulty unit with the appropriate team on your side. Please keep in mind the recommendations provided earlier in this thread about customizations performed by the Original Equipment Manufacturer and other factors that may have caused the error code 10.
Checking with the manufacturer of the system will be always recommended to avoid any potential impact due to the load of no-customized drivers.
If you need any additional information, please submit a new question as this thread will no longer being monitored
Esteban D.
