I am having an issue with network manager when creating a hotspot on my device. After some troubleshooting I was able to narrow the issue down to setting WPA3 as the encryption protocol. On WPA2 the hotspot works without issue. There is no warning when setting WPA3 in nm-connection-editor.
I generally use nmcli to start the hotspot via nmcli con up hotspot it fails with the error: Error:Error: Connection activation failed: 802.1X supplicant took too long to authenticate
Hint: use 'journalctl -xe NM_CONNECTION=51931e8f-e06d-4f86-aefa-d7604162e806 + NM_DEVICE=wlp2s0' to get more details.
gephw@gepserver:~$ journalctl -xe NM_CONNECTION=51931e8f-e06d-4f86-aefa-d7604162e806 + NM_DEVICE=wlp2s0
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8034] dhcp4 (wlp2s0): option expiry >
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8034] dhcp4 (wlp2s0): option ip_addre>
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8034] dhcp4 (wlp2s0): option requeste>
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8035] dhcp4 (wlp2s0): option requeste>
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8036] dhcp4 (wlp2s0): option requeste>
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8037] dhcp4 (wlp2s0): option requeste>
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8037] dhcp4 (wlp2s0): option routers >
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8037] dhcp4 (wlp2s0): option subnet_m>
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8037] dhcp4 (wlp2s0): state changed u>
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8070] device (wlp2s0): state change: >
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8322] device (wlp2s0): state change: >
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8329] device (wlp2s0): state change: >
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8388] device (wlp2s0): Activation: su>
lines 976-1001/1001 (END)
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8034] dhcp4 (wlp2s0): option expiry => '1638959025'
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8034] dhcp4 (wlp2s0): option ip_address => '192.168.1.101'
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8034] dhcp4 (wlp2s0): option requested_broadcast_address => '1'
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8034] dhcp4 (wlp2s0): option requested_domain_name => '1'
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8034] dhcp4 (wlp2s0): option requested_domain_name_servers => '1'
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8035] dhcp4 (wlp2s0): option requested_domain_search => '1'
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8035] dhcp4 (wlp2s0): option requested_host_name => '1'
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8035] dhcp4 (wlp2s0): option requested_interface_mtu => '1'
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8035] dhcp4 (wlp2s0): option requested_ms_classless_static_routes => '1'
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8035] dhcp4 (wlp2s0): option requested_nis_domain => '1'
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8035] dhcp4 (wlp2s0): option requested_nis_servers => '1'
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8036] dhcp4 (wlp2s0): option requested_ntp_servers => '1'
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8036] dhcp4 (wlp2s0): option requested_rfc3442_classless_static_routes => '1'
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8036] dhcp4 (wlp2s0): option requested_root_path => '1'
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8036] dhcp4 (wlp2s0): option requested_routers => '1'
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8036] dhcp4 (wlp2s0): option requested_static_routes => '1'
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8036] dhcp4 (wlp2s0): option requested_subnet_mask => '1'
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8037] dhcp4 (wlp2s0): option requested_time_offset => '1'
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8037] dhcp4 (wlp2s0): option requested_wpad => '1'
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8037] dhcp4 (wlp2s0): option routers => '192.168.1.1'
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8037] dhcp4 (wlp2s0): option subnet_mask => '255.255.255.0'
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8037] dhcp4 (wlp2s0): state changed unknown -> bound
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8070] device (wlp2s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8322] device (wlp2s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8329] device (wlp2s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
12月 08 16:23:45 gepserver NetworkManager[735]: <info> [1638951825.8388] device (wlp2s0): Activation: successful, device activated.
Thanks in advance.
- Tags:
- WiFi
Hello ChunjieHao,
Thank you for posting on the Intel
Josue O.
