i have read all the posts and articles but nothing is working everyone is in problem so if more than a 100,000 people are in problem why is there no solution do we have to change our pc its not our fault that we did something in our software's to broke the drivers its the company's fault,if you think im assuing the company but im not.i JUST NEED HELP!!
CAN YOU PLEASE TELL US ALL HOW TO FIX THIS
I HAVE A LIST OF THINGS I HAVE TRIED:
1.UPDATE FROM 10 TO 11
2.UPDATE TO LATEST DRIVER
3.CLEAN INSTALLATION
4.OEM DRIVER INSTALLATION
IF YOU THINK I TRIED ALL OF THESE STEP NOT CORRECTLY YOUR WORNG EVERYTHING IS RIGHT
AND MANY MORE BUT NOTHING WORKED DO I AHVE TO STOP THIS AND RETIRE MY PC
IS THERE NO SOLUTION PLEASE HELP US ALL USERS TO FIX THIS
- Tags:
- INTEL WIFI AX201
- WiFi
Hello AryanJ,
Thank you for posting in the communities. I can sense urgency in your situation, and we want to help you. On the screenshot, I can see that you are experiencing a code 10 error. To determine the correct troubleshooting steps that we need to take, I need to be more familiar with your system. As such, please share with us your SSU logs. I also noticed you mention you have tried reading posts and articles; would you be able to share some of them in this thread so I can check them for you? Please also let us know when did this occur and if there are any changes that you have on your system before the error message appeared.
I will be waiting for your reply.
Ramyer M.
Hello AryanJ,
I am just looking for an update regarding the information we requested. Kindly please let me know about this information so we can identify the next steps that needs to be taken to solve this issue.
Ramyer M.
Hello AryanJ,
Thank you for responding back to us. The information we want to see in your logs is the current configuration of your system. This includes drivers and components that you are currently using. This will also allow us to also check for possible errors present in your device. You may also follow the steps at this link: How to get the Intel® System Support Utility Logs on Windows*. If you also prefer to continue by email, you may let me know as well.
Ramyer M.
Hello AryanJ,
I wanted to check if you had the chance to review the information we posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Norman S.
Hello AryanJ,
Thank you for sharing the screenshot of your logs. To check for possible errors, would you be able to send the .txt file instead? I will be waiting for your reply.
Ramyer M.
here is the txt file please let me know the FIX thankyou
Hello AryanJ,
Thank you for sharing this. Kindly please allow us sometime to analyze this logs and I promise to get back to you as soon as possible.
Ramyer M.
Hello AryanJ,
Thank you for patiently waiting. Upon checking the logs, I did found out that there is a recommended update with your system BIOS. Kindly please try updating to the following version:
- 1.28.0 - Release date of 07 May 2024
After doing so, kindly please make sure to to do a clean installation of the critical update for your Inspiron 5400 AIO with the following version:
- 23.20.0.3, A46 - Release date 12 Mar 2024
If the above steps do not work, please try the following as well:
- Restore the system from the restore point. If the wireless network problem happens recently, and if you have ever created a restore point or there is an automatic system restore existed, try to restore the computer to a point before the problem began.
- Reset your PC. If the problem persists after all troubleshooting steps are completed. Please back up your personal files, then reset the PC back to its original configuration.
You may also visit this article for more details: Codes 10, 22, 28, 31, 43 or 45 Errors in Device Manager for Bluetooth® or Wireless (Wi-Fi) Devices
Should the issue still persists after trying all of these steps, it would be best to reach out to your Original Equipment Manufacturer which is Dell.
Ramyer M.
Hello AryanJ,
I am just checking in on your system. Is the issue still present? I will be waiting for your reply.
Ramyer M.
Hello AryanJ,
As we have not heard a response in the past few days, I will proceed in closing this case. Should the issue still persists after trying all of these steps, it would be best to reach out to your Original Equipment Manufacturer which is Dell.
Ramyer M.
![](/skins/images/54BF544B471F3F61DFD338F1D58F9426/responsive_peak/images/icon_anonymous_message.png)
