Wireless
9045 Discussions
wifi problem
Krniranjan
My WiFi has not been working for a year. i did everything but not a single onemethod worked for me . Screenshot 2025-06-29 170742.pngScreenshot 2025-06-29 170808.pngScreenshot 2025-06-29 170825.pngScreenshot 2025-06-29 170847.pngScreenshot 2025-06-29 172929.png
Mike_Intel
Hello Krniranjan,
For me to further investigate this issue, please help provide the following details:
  1. What is the brand and model of your system?
  2. What was the last change made in the system before the issue started a year ago?
  3. Did you try to update the driver? If yes, did you get any error message during the update?
Michael L.
Krniranjan
1. Asus TUF F15 FX507ZC4
2. I don't remember the exact date, but one day the Wi-Fi option disappeared from the Quick Settings panel and from the main Settings. I watched some videos on YouTube to fix it, and it worked temporarily. However, the problem happened again. I tried everything—disabling and enabling the driver, uninstalling and reinstalling it, even rolling it back—but nothing worked.
These days, the same problem is happening with Bluetooth. When I turn it on, it connects, but after a few seconds or minutes, it disappears. I have to restart my laptop to get Bluetooth back, but when I try to use it again, it disappears. I got frustrated and stopped using it
3. Yes, it is. I use the Intel Driver & Support Assistant to keep all my drivers updated.
There were no error messages during the driver updates. Everything installed successfully using the Intel Driver & Support Assistant.
"I just updated both the Bluetooth and Wi-Fi drivers—there were no error messages during the update."
"My Wi-Fi driver status is showing code 10"
Mike_Intel
Hello Krniranjan,
Thank you for the update.
For error code 43 and error code 10, we have a troubleshooting guide that you can try. Please follow the steps here specially the clean driver installation part to check that this is just a driver issue. Hopefully this is not a hardware issue since it is not working for a year now.
Error Codes 10, 22, 28, 31, 43, or 45 in Device Manager for...
Michael L.
Mike_Intel
Hello Krniranjan,
Michael L.
JeanetteC_Intel
Hello Krniranjan,
Since I haven't received any response from you recently, I will go ahead and close this thread. If you require help in the future, please submit a new inquiry, as this thread will no longer be monitored.
Sincerely,
JeanetteC.
