Wireless
8653 Discussions
wireless hotspot intel 9260 - adapter not found, hosted network support: No
APana2
I recently installed an intel 9260 network card on my razer blade which used to use a killer 1535. The main reason why i swapped it out is because my killer network card did not support wireless display and casting from my laptop to any device in general. Since swapping out the card, the wireless display is now working with the intel 9260 and the wifi is better than ever, but now i am having problems with mobile hotspot. In my device manager i cannot find the wireless network adapter and in command prompt when i search info about wireless network drivers is says hosted network support: No. These network cards have been consuming my energy and time.
Please if anyone has any insight in how to make this work i would be grateful.
Any info required i would gladly attach to my reply.
best regards,
Andre
Hello Andre,
Thanks for posting.
Please bear in mind that Intel does not support, nor recommends custom integration of wireless adapters since this may lead to installation errors, connection issues, software error messages (as the adapter not showing in Device Manager), and in some cases it may even be illegal. For more information, please check the following advisories:
- https://www.intel.com/content/www/us/en/support/articles/000005846/network-and-i-o/wireless-networking.html?wapkw=5846 Why Doesn't My Laptop Recognize My New Intel® Wireless Adapter?
- https://www.intel.com/content/www/us/en/support/articles/000005687/network-and-i-o/wireless-networking.html?_ga=1.33281086.1415059657.1457358642 Regulatory Information Regarding Hardware Installation or Upgrade.
As for hosted network support, this along with ad-hoc features are not supported on Windows 10* due to the new driver model. Using the embedded Windows 10* mobile hotspot feature is recommended. Please check the article below for details:
- https://www.intel.com/content/www/us/en/support/articles/000023257/network-and-i-o/wireless-networking.html Why Hosted and Ad-Hoc Networks are Not Working on Windows® 10
We recommend installing the latest wireless driver, this may help Device Manager to properly recognize the adapter:
- https://www.intel.com/content/www/us/en/support/articles/000005559/network-and-i-o/wireless-networking.html Download the Latest Driver for Your Intel® Wireless Adapter
Eugenio F.
APana2
Thank you for your reply,
I have the latest drivers installed and I have tried to install the generic drivers before I posted this question and nothing really.changed so I reinstalled the latest drivers for that specific chip intel 9260.
Besides that, i have a hunch that it's a software issue as I am able to connect to the WiFi mobile hotspot through my.phone but.i don't have internet access. In my network settings(control panel) I am not able to share the connection that actually does have the internet access with the "virtual network". On top of that if my hotspot wasn't working then my wireless display shouldn't work either correct?
What I meant that in my device manager the adapter used for mobile hotspot is not there but it does recognise my intel 9260 along with a bunch of other drivers that come with it but not the mobile hotspot.
There is definitely not a legal issue with this either. I have read in forums about other people changing their killer card on their razer for an intel 8260 or 8265 for the reason that they also had trouble connecting to a wireless display. However I don't know if that affected their mobile hotspot like my case.
I have read the links you posted... However I have trouble coming to a conclusion. Does this mean that I should wait for driver updates from.eothrr windows 10 or intel? Or is it just a fact I have to accept that I cannot use mobile hotspot on my laptop unless I comprise wireless display and switch back to the killer card?
Hello ap00262,
Under normal circumstances, you should be able to use https://support.microsoft.com/en-us/help/4027762/windows-use-your-pc-as-a-mobile-hotspot Windows 10* mobile hotspost (this is different from hosted networks configured through netsh commands or third party apps). However, there are no plans to add the hosted network and ad-hoc features specified in the https://www.intel.com/content/www/us/en/support/articles/000023257/network-and-i-o/wireless-networking.html article shared in our previous post.
We recommend to http://support.razerzone.com/contact-support contact the OEM (Original Equipment Manufacturer) support to check which adapters are supported by your computer and replace it with them whenever possible.
NOTE: Links to third party sites are being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Please let us know if there's anything else we can help you with.
Eugenio F.
APana2
Hello, thank you for your reply.
I have spoken with razer and they directed me to a number of inter AC wireless cards which include 9260.
They noted that I should either contact intel about this issue or Microsoft tech support.
I will also notify Microsoft about this issue as the intel 9260 is made to work for both mobile hotspot and wireless display.
Obviously it is a software issue as the laptop is made to support any M2 22x30 card.
Also to note, under network adapters in device manager I cannot see any realtek drivers. I fear that might be the issue with my.mobile hotspot.
Any further guidence at this point would be greatly appreciated.
APana2
Also, could it be something that my firewall or antivirus is blocking?
Hello ap00262,
Thanks for your reply.
To discard software issues, Please try the following:
- Update your BIOS and chipset drivers are up to date.
- Update graphics drivers (both integrated and video card).
- Perform a https://www.intel.com/content/www/us/en/support/articles/000022173/network-and-i-o/wireless-networking.html clean wireless driver installation.
- Temporarily disabled your Firewall and antivirus.
- As a last resort, reinstall the operating system.
Regarding the Realtek* drivers, we are not aware of this being a requirement for using Miracast* (Microsoft*'s wireless display).
Eugenio F.
APana2
Does this intel chip 9260 support mobile hotspot from windows 10?
Hello ap00262,
Yes, we can confirm that the Intel® Wireless-AC 9260 is compatible with Windows 10* embedded mobile hotspot feature with the https://www.intel.com/content/www/us/en/support/articles/000005559/network-and-i-o/wireless-networking.html latest Intel wireless driver.
This could be the result of the many unpredictable issues that come with wireless integrations. However, there's one more thing you can test.
Please try using the inbox driver. To do so, uninstall Intel® PROSet/Wireless Software and remove the wireless driver from Device Manager. Reboot your computer and Windows 10* will install the inbox driver.
Eugenio F.
Hello ap00262,
We haven't heard from you in the last few days.
Eugenio F.
