oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1401 Discussions
Cannot install package "intel-oneapi-runtime-compilers" from APT repo due to unmet dependencies
johnio
When trying to install the package "intel-oneapi-runtime-compilers" from the oneAPI APT repository, I get the following error:
The following packages have unmet dependencies:
intel-oneapi-runtime-compilers : Depends: intel-oneapi-runtime-openmp (= 2023.2.2-47) but 2024.0.0-49819 is to be installed
E: Unable to correct problems, you have held broken packages.
RahulC_Intel
Hi John, could you please share the below details for further investigation:
  • OS build on which you are installing the software
  • Is the installer an online or an offline package?
  • Other versions of Intel® Parallel Studio XE or Intel® oneAPI already installed on the system
  • Installation Log files or screenshot of an error
johnio
Hi!
I am installing on Ubuntu 20.04 docker containers.
I use the following commands to install it:
    # Download the key to system keyring
    INTEL_KEY_URL=https://apt.repos.intel.com/intel-gpg-keys/GPG-PUB-KEY-INTEL-SW-PRODUCTS.PUB
    wget -O- $INTEL_KEY_URL | gpg --dearmor | tee /usr/share/keyrings/oneapi-archive-keyring.gpg > /dev/null || exit $?
    # Add signed entry to apt sources and configure the APT client to use Intel repository
    echo "deb [signed-by=/usr/share/keyrings/oneapi-archive-keyring.gpg] https://apt.repos.intel.com/oneapi all main" | tee /etc/apt/sources.list.d/oneAPI.list || exit $?
    apt update || exit $?
    # Install the OpenCL runtime
    apt --assume-yes install intel-oneapi-runtime-opencl intel-oneapi-runtime-compilers || exit $?
 There are no other installations present in the container.
I already sent the error message:
RahulC_Intel
Hi John, thank you for sharing the details with us. Kindly refer to the link: https://www.intel.com/content/www/us/en/docs/oneapi/installation-guide-linux/2024-0/apt.html, follow the troubleshooting steps and resolve the issue.
johnio
I ended up changing to the -2024 version of the packages (intel-oneapi-runtime-opencl-2024 intel-oneapi-runtime-compilers-2024) after finding a way to solve this other issue: Solved: clinfo lists 0 platforms on ubuntu 20.04 - Intel Community
Still I think it is not good that the old packages are now broken after the repository was updated.
RahulC_Intel
Hi John, we have sent you a private message. Kindly check your inbox.
