oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1491 Discussions
Error about modulefiles in OneApi Base Toolkit installation directory.
mpi_new_user
New Contributor II
I have installed base toolkit successfully,and I run the script ' modulefiles-setup.sh'. It creates a folder.Everything seems ok.
I tried to load the MKL library by running the command line :
module load intel/mkl/2021.1.1
And I got an error like this:
Loading mkl version 2021.1.1
Loading intel/mkl/2021.1.1
ERROR: Unable to locate a modulefile for 'compiler-rt/2021.1.1'
ERROR: Load of requirement 'compiler-rt/2021.1.1' failed
Then I tried to run 'module load intel/compiler-rt/2021.1.1'.The command was executed successfully.So, I reloaded mkl.The error still happened.
[root@node1 intel]# module list
Currently Loaded Modulefiles:
1) intel/mpi/2021.1.1 3) intel/compiler-rt32/2021.1.1 5) intel/tbb32/2021.1.1 7) intel/tbb32/latest
2) intel/compiler-rt/2021.1.1 4) intel/tbb/2021.1.1 6) intel/tbb/latest
[root@node1 intel]# module load intel/mkl/2021.1.1
Please let me know if I'm missing something.Thanks.
mpi_new_user
New Contributor II
After I reinstall the toolkit,I can use the modulefiles without errors.
I think it has been solved.
GouthamK_Intel
Thanks for reaching out to us!
As your issue is related to oneAPI toolkit Installation/Setting up the environment, we are having a dedicated forum where any issues related to Getting Started questions (registration, sign up, download, licensing, or installation) are answered.
So, we are redirecting this thread there for a faster response.
Have a Good day!
Thanks & Regards
Goutham
mpi_new_user
New Contributor II
GouthamK_Intel
Thanks for the confirmation!
As this issue has been resolved, we will no longer respond to this thread.
If you require any additional assistance from Intel, please start a new thread.
Any further interaction in this thread will be considered community only.
Have a Good day.
Thanks & Regards
Goutham
