I tried installing oneAPI 2021 Fortran compilers on Windows Server 2022 using the following batch script.
:: URL for the offline installer of Intel OneAPI Fortran compiler. See
set URL=https://registrationcenter-download.intel.com/akdlm/irc_nas/18247/w_HPCKit_p_2021.4.0.3340_offline.exe
:: Component to install.
set COMPONENTS=intel.oneapi.win.ifort-compiler
:: Download the installer. curl is included by default in Windows since Windows 10, version 1803.
::cd %Temp% :: CD does not work if %Temp% is on a different drive.
curl.exe --output webimage.exe --url %URL% --retry 5 --retry-delay 5
start /b /wait webimage.exe -s -x -f webimage_extracted --log extract.log
:: Install the compiler.
webimage_extracted\bootstrapper.exe -s --action install --components=%COMPONENTS% --eula=accept -p=NEED_VS2017_INTEGRATION=0 -p=NEED_VS2019_INTEGRATION=0 -p=NEED_VS2022_INTEGRATION=0 --log-dir=.
set installer_exit_code=%ERRORLEVEL%
:: Run the script that sets the environment variables.
call "C:\Program Files (x86)\Intel\oneAPI\setvars.bat"
:: Show the result of the installation.
echo The path to ifort is:
where ifort.exe
echo The path to ifx is:
where ifx.exe
:: Remove the installer.
del webimage.exe
rd /s/q "webimage_extracted"
:: Exit with the installer exit code.
exit /b %installer_exit_code%
It fails with the following message.
Checking system requirements...
Done.
Wait while the installer is preparing...
Done.
Launching the installer...
Process crashed
D:\a\setup_mex\setup_mex>set installer_exit_code=-1073741819
Here is a screenshot.
In contrast, the same installation works well on Windows Server 2019.
Is this a known issue, or did I overlook something?
Thank you very much.
Moving this over to the Installation Forum. They are better equipped to help.
![](/skins/images/7746D4550810124E96DD2FD9957552B1/responsive_peak/images/icon_anonymous_message.png)
