oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions for Intel oneAPI Toolkits, Intel Parallel Studio XE and Intel System Studio
877 Discussions
Failed to update firmware via Capsule on Minnowboard Turbot/E3826
ymhuang
On Minnowboard Turbot (E3826) -
1. Flash latest firmware from https://software.intel.com/sites/default/files/managed/e5/fb/minnowboard-max-rel-1-01-firmware-images.zip (MSYS\MNW2MAX1.X64.0101.R01.1908071815.bin)
2. Follow https://github.com/tianocore/edk2-platforms/blob/master/Platform/Intel/Vlv2TbltDevicePkg/Readme.md build the Capsule ROMs.
3. Boot into internal UEFI shell, and execute "CapsuleApp.efi Red.0.0.0.18.cap Green.0.0.0.34.cap Blue.0.0.0.20.cap Minnow.0.0.0.12.cap"
Capsule doesn't reboot automatically, but shows "CapsuleApp: failed to query capsule capability - Invalid Parameter".
The error seems come from https://github.com/tianocore/edk2/blob/master/MdeModulePkg/Application/CapsuleApp/CapsuleApp.c#L940 that query firmware fail.
Is Capsule on MInnowboard Turbot requires specific firmware, not the one publish on the page?  Or any suggestions to resolve the error?
CarlosAM_INTEL
Hello, @ymhuang:
You should address as a reference the questions related to the cited third-party device or any product manufacturer by the cited company to the channel listed on the following website:
http://www.minnowboard.org/support/
@CarlosAM_INTEL.
ymhuang
Thank you, @CarlosAM_INTEL ,
But the default firmware are provided by Intel and seems failed while query its capability of Capsule.  It should be fair to check with Intel if default firmware has issue in Capsule supporting vs. EDK2 master tree?
I will also see if Minnowboard.org can provide the support for Intel firmware.
ymhuang
CarlosAM_INTEL
Hello, @ymhuang:
Thanks for your reply.
You should request the proper firmware and received support related to it through the manufacturer of the affected device.
This is the reason to give the suggestions stated in our previous communication.
@CarlosAM_INTEL.
ymhuang
The default firmware is exactly the link from Intel page in my very first post.  I also consider contact manufacturer of the firmware for the support since it appears default firmware seems has issue with Capsule.
Unfortunately, it seems I misunderstand something here that Intel request to contact Minnowboard.org for the firmware which is provided on Intel page.  Perhaps, Intel is not the one manufacture the default firmware, but Minnowboard.org is?
Anyway, I already submit this issue to Minnowboard.org.  If it happen Intel indeed is the one create the default firmware, and know why it has issue in querying of Capsule capability, it will be appreciated that Intel can provide the support or direction here.
ymhuang
CarlosAM_INTEL
Hello, @ymhuang:
We are moving this thread to the proper forum, the team in charge will contact you as soon as possible.
@CarlosAM_INTEL
