I have installed oneapi basetoolkit at /opt/intel/oneapi and now I have forgotten which version of the toolkit I had installed. Is there a way to check the version of the installed oneapi toolkit through the command line ?
Thanks in advance!
Hi Vishnu, to check the version of the Intel® oneAPI toolkit installed on your system, you can use the following command:
source /opt/intel/oneapi/setvars.sh
source /opt/intel/oneapi/latest/setvars.sh && oneapi-cli --version
The above commands will display the version of the Intel® oneAPI toolkit installed on your system. It also displays the version of the Intel® Compiler (icx) installed on your system. You can replace 'icx' with other Intel® oneAPI tools like 'ifx' for the Intel® Fortran Compiler, 'idp' for the Intel® Distribution for Python, etc., to check their versions as well.
Note: Please ensure that the 'setvars.sh' script is located in the correct directory. If not, then you can use the below command and replace the "/opt/intel/oneapi/base/" with the actual installation directory:
cat /opt/intel/oneapi/base/version.txt
You can also check by using the option --list-products; you can get the list of downloaded products, their IDs, versions and statuses (installed/not installed). Use together with the --instance option to get the list of available products in a specific instance.
For example: sh ./l_[Toolkit Name]Kit_[version].sh -a --list-products --instance=<instance ID>.
Please refer to the Intel® oneAPI Toolkits Installation Guide for Linux* OS for more information.
Thanks, I tried the suggested methods but it doesn't seem to work.
Followed the below steps:
1. Installed oneapi basetoolkit 2024.0.1.46 (version taken from the filename --> l_BaseKit_p_2024.0.1.46_offline.sh)
2. Ran '$ oneapi-cli version' which returns 'devel'
Hi Vishnu, we have sent you a private message. Kindly check your community inbox.
![](/skins/images/1FC86CD46823E418D1E2B7B4DC10231C/responsive_peak/images/icon_anonymous_message.png)
