I am trying to install parallel_studio_xe_2020_update4 on a windows 2016 server with Visual Studio 2017(15.9.54). The installer crashes with this message:
"An Unhandled Microsoft .Net Framework exception occurred in install.exe [8680].
I am unfamiliar with the product.
Any assistance is greatly appreciated.
Hi Lee, please share the below information with us:
- OS build on which you are installing the software
- Is the installer an online or an offline package?
- Version of Microsoft Visual Studio installed along with it's build version
- Other versions of Intel® Parallel Studio XE or Intel® oneAPI already installed on the system
- Screenshots of the error screen
- Installation Log files.
The default path for a log file for a oneAPI installation is: C:\Program Files (x86)\Intel\oneAPI\logs
The default path for a log file for a Parallel Studio XE installation is: %temp%\pset_tmp_PSXE<version>_<username>
We would like to know.
Lee, please follow the below steps regarding the uninstallation and following installation:
- Close Intel® installers if any.
- Uninstall all Microsoft Visual Studio instances and Visual Studio Installer.
- Important: check that C:\ProgramData\Microsoft\VisualStudio\Setup\x86\Microsoft.VisualStudio.Setup.Configuration.Native.dll does not exist anymore. If it was not removed with Microsoft Visual Studio for some reason, please unregister the DLL using
REGSVR32 /U C:\ProgramData\Microsoft\VisualStudio\Setup\x86\Microsoft.VisualStudio.Setup.Configuration.Native.dll
command in Command Prompt as Administrator, and then rename the file to Backup_Microsoft.VisualStudio.Setup.Configuration.Native.dll so the Intel® Installer can't load it.
- Uninstall older Intel® Parallel Studio XE and Intel® oneAPI products.
- Install required versions of Microsoft Visual Studio supported by the Intel® Parallel Studio XE. See the full list here: https://www.intel.com/content/www/us/en/developer/articles/reference-implementation/intel-compilers-compatibility-with-microsoft-visual-studio-and-xcode.html. For the Intel® Parallel Studio XE 2020 Update 4, the supported versions are Visual Studio 2017 15.9 and Visual Studio 2019 16.7.2.
Lee, unfortunately we were unable to hear back from you.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
![](/skins/images/9701FEC4E90D143B667C09F3DB2F340F/responsive_peak/images/icon_anonymous_message.png)
