Trying to install Intel-AIKIT on a FRESH cleanly installed Ubuntu 22.04.2
sudo -S apt -y install intel-aikit
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following additional packages will be installed:
intel-aikit-getting-started intel-oneapi-common-licensing-2023.0.0
intel-oneapi-dal-daal4py-2023.1.0
intel-oneapi-dal-scikit-learn-intelex-2023.1.0 intel-oneapi-model-zoo
intel-oneapi-modin intel-oneapi-mpi-2021.8.0 intel-oneapi-mpi-devel-2021.8.0
intel-oneapi-neural-compressor intel-oneapi-python intel-oneapi-pytorch
intel-oneapi-tensorflow
The following NEW packages will be installed:
intel-aikit intel-aikit-getting-started
intel-oneapi-common-licensing-2023.0.0 intel-oneapi-dal-daal4py-2023.1.0
0 upgraded, 13 newly installed, 0 to remove and 2 not upgraded.
Need to get 462 MB/2,065 MB of archives.
After this operation, 2,479 MB of additional disk space will be used.
Err:1 https://apt.repos.intel.com/oneapi all/main all intel-oneapi-pytorch amd64 1.13.10.1-47264
404 Not Found [IP: 104.69.89.197 443]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-pytorch-1.13.10.1-47264_amd64.deb 404 Not Found [IP: 104.69.89.197 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
workhorse
Hi Will, we have contacted you internally with some information. Please check your inbox for further updates.
Hi Will, for a fresh installation you need to first set up the repository.
- To do this, download the key to the system keyring:
wget -O- https://apt.repos.intel.com/intel-gpg-keys/GPG-PUB-KEY-INTEL-SW-PRODUCTS.PUB \
| gpg --dearmor | sudo tee /usr/share/keyrings/oneapi-archive-keyring.gpg > /dev/null
- Add the signed entry to APT sources and configure the APT client to use the Intel repository:
echo "deb [signed-by=/usr/share/keyrings/oneapi-archive-keyring.gpg] https://apt.repos.intel.com/oneapi all main" | sudo tee /etc/apt/sources.list.d/oneAPI.list
- Update the packages list and repository index.
sudo apt update
For complete installation instructions, please click here: https://www.intel.com/content/www/us/en/docs/oneapi/installation-guide-linux/2023-0/apt.html
Any update from Intel about the missing .deb file?
Will, we are glad that the issue has been resolved.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
