oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
Intel oneAPI Debian Repo Broken?
jperaltac
I tried to update and upgrade my debian repository and got this error :
Err:4 https://apt.repos.intel.com/oneapi all/main all intel-oneapi-pytorch amd64 1.13.10.1-47264
404 Not Found [IP: 23.12.123.108 443]
Fetched 89.1 MB in 9s (9,683 kB/s)
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-pytorch-1.13.10.1-47264_amd64.deb 404 Not Found [IP: 23.12.123.108 443]
Any suggestion or help, it is welcome.
Joaquin
jperaltac
I solved, by using :
sudo apt remove intel-oneapi-python
sudo apt autoremove
and reinstalling with :
sudo apt install intel-oneapi-python
Joaquín.
jperaltac
sudo apt autoremove
Joaquín.
whatheway
workhorse@workhorse-MS-7D91:~$ sudo apt remove intel-aikit
[sudo] password for workhorse:
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Package 'intel-aikit' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
workhorse@workhorse-MS-7D91:~$ sudo apt autoremove
workhorse@workhorse-MS-7D91:~$ sudo apt install intel-oneapi-python
The following additional packages will be installed:
intel-oneapi-dal-daal4py-2023.1.0
intel-oneapi-dal-scikit-learn-intelex-2023.1.0
The following NEW packages will be installed:
intel-oneapi-dal-scikit-learn-intelex-2023.1.0 intel-oneapi-python
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/281 MB of archives.
After this operation, 283 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Selecting previously unselected package intel-oneapi-dal-daal4py-2023.1.0.
(Reading database ... 261437 files and directories currently installed.)
Preparing to unpack .../intel-oneapi-dal-daal4py-2023.1.0_2023.1.0-46349_amd64.d
eb ...
Unpacking intel-oneapi-dal-daal4py-2023.1.0 (2023.1.0-46349) ...
Selecting previously unselected package intel-oneapi-dal-scikit-learn-intelex-20
23.1.0.
Preparing to unpack .../intel-oneapi-dal-scikit-learn-intelex-2023.1.0_2023.1.0-
46349_amd64.deb ...
Unpacking intel-oneapi-dal-scikit-learn-intelex-2023.1.0 (2023.1.0-46349) ...
Selecting previously unselected package intel-oneapi-python.
Preparing to unpack .../intel-oneapi-python_2023.1.0-46399_amd64.deb ...
Unpacking intel-oneapi-python (2023.1.0-46399) ...
Setting up intel-oneapi-dal-scikit-learn-intelex-2023.1.0 (2023.1.0-46349) ...
Setting up intel-oneapi-dal-daal4py-2023.1.0 (2023.1.0-46349) ...
Setting up intel-oneapi-python (2023.1.0-46399) ...
workhorse@workhorse-MS-7D91:~$ sudo apt install intel-aikit
intel-aikit-getting-started intel-oneapi-common-licensing-2023.0.0
intel-oneapi-model-zoo intel-oneapi-modin intel-oneapi-mpi-2021.8.0
intel-oneapi-mpi-devel-2021.8.0 intel-oneapi-neural-compressor
intel-oneapi-pytorch intel-oneapi-tensorflow
intel-aikit intel-aikit-getting-started
intel-oneapi-common-licensing-2023.0.0 intel-oneapi-model-zoo
intel-oneapi-modin intel-oneapi-mpi-2021.8.0 intel-oneapi-mpi-devel-2021.8.0
intel-oneapi-neural-compressor intel-oneapi-pytorch intel-oneapi-tensorflow
0 upgraded, 10 newly installed, 0 to remove and 0 not upgraded.
Need to get 462 MB/1,784 MB of archives.
After this operation, 2,197 MB of additional disk space will be used.
Err:1 https://apt.repos.intel.com/oneapi all/main all intel-oneapi-pytorch amd64 1.13.10.1-47264
404 Not Found [IP: 104.69.89.197 443]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-pytorch-1.13.10.1-47264_amd64.deb 404 Not Found [IP: 104.69.89.197 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
whatheway
eb ...
23.1.0.
46349_amd64.deb ...
Solution doesn't solve the pytorch problem.
whatheway
workhorse@workhorse-MS-7D91:~$ sudo apt remove intel-oneapi-python
sudo apt autoremove
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
intel-aikit : Depends: intel-oneapi-python (>= 2023.0.0-25636)
Depends: intel-oneapi-pytorch (>= 1.13.0.0-31759)
Depends: intel-oneapi-modin (>= 0.17.0.1-31755)
intel-oneapi-neural-compressor : Depends: intel-oneapi-python (>= 2023.0.0-25636)
intel-oneapi-tensorflow : Depends: intel-oneapi-python (>= 2023.0.0-25636)
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
intel-aikit : Depends: intel-oneapi-pytorch (>= 1.13.0.0-31759)
intel-oneapi-python is already the newest version (2023.1.0-46399).
intel-oneapi-python set to manually installed.
