I tried to update and upgrade my debian repository and got this error :
Err:4 https://apt.repos.intel.com/oneapi all/main all intel-oneapi-pytorch amd64 1.13.10.1-47264
404 Not Found [IP: 23.12.123.108 443]
Fetched 89.1 MB in 9s (9,683 kB/s)
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-pytorch-1.13.10.1-47264_amd64.deb 404 Not Found [IP: 23.12.123.108 443]
Any suggestion or help, it is welcome.
Joaquin
I solved, by using :
sudo apt remove intel-oneapi-python
sudo apt autoremove
and reinstalling with :
sudo apt install intel-oneapi-python
Joaquín.
sudo apt autoremove
Joaquín.
workhorse@workhorse-MS-7D91:~$ sudo apt remove intel-aikit
[sudo] password for workhorse:
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Package 'intel-aikit' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
workhorse@workhorse-MS-7D91:~$ sudo apt autoremove
workhorse@workhorse-MS-7D91:~$ sudo apt install intel-oneapi-python
The following additional packages will be installed:
intel-oneapi-dal-daal4py-2023.1.0
intel-oneapi-dal-scikit-learn-intelex-2023.1.0
The following NEW packages will be installed:
intel-oneapi-dal-scikit-learn-intelex-2023.1.0 intel-oneapi-python
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/281 MB of archives.
After this operation, 283 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Selecting previously unselected package intel-oneapi-dal-daal4py-2023.1.0.
(Reading database ... 261437 files and directories currently installed.)
Preparing to unpack .../intel-oneapi-dal-daal4py-2023.1.0_2023.1.0-46349_amd64.d
eb ...
Unpacking intel-oneapi-dal-daal4py-2023.1.0 (2023.1.0-46349) ...
Selecting previously unselected package intel-oneapi-dal-scikit-learn-intelex-20
23.1.0.
Preparing to unpack .../intel-oneapi-dal-scikit-learn-intelex-2023.1.0_2023.1.0-
46349_amd64.deb ...
Unpacking intel-oneapi-dal-scikit-learn-intelex-2023.1.0 (2023.1.0-46349) ...
Selecting previously unselected package intel-oneapi-python.
Preparing to unpack .../intel-oneapi-python_2023.1.0-46399_amd64.deb ...
Unpacking intel-oneapi-python (2023.1.0-46399) ...
Setting up intel-oneapi-dal-scikit-learn-intelex-2023.1.0 (2023.1.0-46349) ...
Setting up intel-oneapi-dal-daal4py-2023.1.0 (2023.1.0-46349) ...
Setting up intel-oneapi-python (2023.1.0-46399) ...
workhorse@workhorse-MS-7D91:~$ sudo apt install intel-aikit
intel-aikit-getting-started intel-oneapi-common-licensing-2023.0.0
intel-oneapi-model-zoo intel-oneapi-modin intel-oneapi-mpi-2021.8.0
intel-oneapi-mpi-devel-2021.8.0 intel-oneapi-neural-compressor
intel-oneapi-pytorch intel-oneapi-tensorflow
intel-aikit intel-aikit-getting-started
intel-oneapi-common-licensing-2023.0.0 intel-oneapi-model-zoo
intel-oneapi-modin intel-oneapi-mpi-2021.8.0 intel-oneapi-mpi-devel-2021.8.0
intel-oneapi-neural-compressor intel-oneapi-pytorch intel-oneapi-tensorflow
0 upgraded, 10 newly installed, 0 to remove and 0 not upgraded.
Need to get 462 MB/1,784 MB of archives.
After this operation, 2,197 MB of additional disk space will be used.
Err:1 https://apt.repos.intel.com/oneapi all/main all intel-oneapi-pytorch amd64 1.13.10.1-47264
404 Not Found [IP: 104.69.89.197 443]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-pytorch-1.13.10.1-47264_amd64.deb 404 Not Found [IP: 104.69.89.197 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
eb ...
23.1.0.
46349_amd64.deb ...
Solution doesn't solve the pytorch problem.
workhorse@workhorse-MS-7D91:~$ sudo apt remove intel-oneapi-python
sudo apt autoremove
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
intel-aikit : Depends: intel-oneapi-python (>= 2023.0.0-25636)
Depends: intel-oneapi-pytorch (>= 1.13.0.0-31759)
Depends: intel-oneapi-modin (>= 0.17.0.1-31755)
intel-oneapi-neural-compressor : Depends: intel-oneapi-python (>= 2023.0.0-25636)
intel-oneapi-tensorflow : Depends: intel-oneapi-python (>= 2023.0.0-25636)
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
intel-aikit : Depends: intel-oneapi-pytorch (>= 1.13.0.0-31759)
intel-oneapi-python is already the newest version (2023.1.0-46399).
intel-oneapi-python set to manually installed.
