oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1670 Discussions
Oneapi Base toolkit installer not launching
Sbh
I have installed Oneapi Base toolkit in linux in the default directory. I want to uninstall it and then reinstall it in a different directory. I have deleted packagemanager.db in /var/intel/installercache. While installing in command line in silent installation, it got interrupted. Now the installer is not launching from root. The error I am getting is,
Launching the installer...
Installer failed with error Error preparing SQL statement.
If I try to install from user account the installer launches (without sudo). But then I have no permission to install in the desired directory I want. If I use sudo the following error is shown,
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
Any suggestion will be really helpful. Thank you in advance.
