THis seems to be a generic problem. Can we get a solution everyone can read about here? I need to know how to fix this as well.
Hi David, thank you for reaching out to us. We are working on the issue. We will soon share the solution with you.
David, we have contacted you internally with some information. Please check your inbox for further updates.
David, you would have to fix the corrupted files.
Use Command Prompt commands to repair system file corruption:
- Open Command Prompt as administrator
- Use the following command and press Enter: sfc /scannow
- Reboot your system
- If SFC returned an error, then use the following command lines, pressing Enter after each:
- DISM /Online /Cleanup-Image /CheckHealth
- DISM /Online /Cleanup-Image /ScanHealth
- DISM /Online /Cleanup-Image /RestoreHealth
We would like to know.
David, unfortunately we were unable to hear back from you.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
![](/skins/images/7B0AB6865064EAE32B30EC9A4E94B48A/responsive_peak/images/icon_anonymous_message.png)
Topic Options
