We've not been able to install the recent v2024.1.0.466 release of the Fortran compiler on Windows machines that don't have UIs (Windows Servercore, etc.).
We normally install using:
w_fortran-compiler_p_2024.1.0.466_offline.exe -s -a --silent --eula "accept" --install-dir "C:\oneAPI"
When this failed, we extracted the contents with
w_fortran-compiler_p_2024.1.0.466_offline.exe -s -x -f C:\extract-2024.1
to confirm the issue was not with the extraction process.
From there, any attempts to run bootstrapper.exe yeild the following error message in bootstrapper.*.log:
04/10/2024 13:43:47:209 : 1716 : MESSAGE : <Bootstrapper> >>> THE BOOTSTRAPPER IS LAUNCHED <<<
04/10/2024 13:43:47:231 : 1716 : WARNING : QtWarningMsg: SetProcessDpiAwarenessContext(DPI_AWARENESS_CONTEXT_PER_MONITOR_AWARE_V2) failed: COM error 0x5: Access is denied.
Qt's default DPI awareness context is DPI_AWARENESS_CONTEXT_PER_MONITOR_AWARE_V2. If you know what you are doing you can overwrite this default using qt.conf (https://doc.qt.io/qt-6/highdpi.html#configuring-windows)
The most portable reproduction of this I could come up with was using Docker:
- Get an interactive pwsh shell by running:
docker run -it --rm mcr.microsoft.com/powershell:windowsservercore
- Download, extract, and attempt to run the v2024.1 installer:
# Download the installer
Invoke-WebRequest https://registrationcenter-download.intel.com/akdlm/IRC_NAS/f6a44238-5cb6-4787-be83-2ef48bc70cba/w_fortran-compiler_p_2024.1.0.466_offline.exe -OutFile w_fortran-compiler_p_2024.1.0.466_offline.exe
# Extract the contents
./w_fortran-compiler_p_2024.1.0.466_offline.exe -s -x -f C:\extract-2024.1
# Try to run --help
./extract-2024.1/bootstrapper.exe --help
# View the log(s)
Get-Content C:\Users\ContainerAdministrator\AppData\Local\Temp\IntelInstaller\*.log
- Try the same with the v2023.1 installer:
Invoke-WebRequest https://registrationcenter-download.intel.com/akdlm/IRC_NAS/81e6950b-73c9-4ed6-95dc-57f38a7e9a30/w_fortran-compiler_p_2023.1.0.46351_offline.exe -OutFile w_fortran-compiler_p_2023.1.0.46351_offline.exe
./w_fortran-compiler_p_2023.1.0.46351_offline.exe -s -x -f C:\extract-2023.1
# Try to run --help
.\extract-2023.1\bootstrapper.exe --help
# View the logs
Get-Content C:\Users\ContainerAdministrator\AppData\Local\Temp\bootstrapper.*.log
Hi Ryan, we have sent you a private message. Kindly check your community inbox.
![](/skins/images/1FC86CD46823E418D1E2B7B4DC10231C/responsive_peak/images/icon_anonymous_message.png)
