oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions for Intel oneAPI Toolkits, Intel Parallel Studio XE and Intel System Studio
801 Discussions
Yum installation of OneMKL results in conflict error
jpharr
I am working with a CentOS7-based Singularity container where I install OneMKL following these instructions: https://software.intel.com/content/www/us/en/develop/articles/installing-intel-oneapi-toolkits-via-yum.html
After adding the OneAPI repository to /etc/yum.repos.d, I run:
export MKL_VERSION=2021.1.1
yum -y install intel-oneapi-mkl-${MKL_VERSION}.x86_64
Previously this completed without errors, but now runs into the following conflict error:
---> Package intel-oneapi-openmp-common-2021.1.2.noarch 0:2021.1.2-266 will be installed
--> Processing Conflict: intel-oneapi-common-vars-2021.2.0-195.noarch conflicts intel-oneapi-common-licensing < 2021.2.0
--> Finished Dependency Resolution
Error: intel-oneapi-common-vars conflicts with intel-oneapi-common-licensing-2021.1.1-2021.1.1-60.noarch
 You could try using --skip-broken to work around the problem
 You could try running: rpm -Va --nofiles --nodigest
 The source of the issue therefore relates to intel-oneapi-common-licensing:
dependency: intel-oneapi-common-licensing
   provider: intel-oneapi-common-licensing-2021.1.1.noarch 2021.1.1-60
   provider: intel-oneapi-common-licensing.noarch 2021.2.0-195
Any thoughts on what one would need to do to resolve this? Unfortunately using --skip-broken is impossible as it prevents installation of several key components.
Many thanks in advance for your help!
jpharr
Further to my previous response,
I investigated a little further and found that if I swap the OS to CentOS8 without making other changes to the recipe, that is:
Bootstrap: docker
... then the installation works.
Best wishes,
Jesse
ArpanB_Intel
Hi Jesse, could you please confirm whether you have multiple versions of Intel® oneAPI installed on your system or not? Please note that having multiple versions of the product on the same system might not work. From the error message you had shared, we believe that you might have 2021.1.1 version of the compiler already installed on the system.
jpharr
Thanks for the reply. I can confirm that there are no other versions of Intel® oneAPI installed. I have attached a minimal Singularity container definition file + associated .repo file for reproducing the error, which appears when building a new container.
As .def and .repo file extensions aren't supported by the forum, I have added these as .txt files (to use them, they will need to be renamed to mkl_conflict.def and oneAPI.repo).
On a system with Singularity installed, the container can be built with:
sudo singularity build mkl_conflict.sif mkl_conflict.def
 For ease of viewing, I will also write out the contents of the files.
oneAPI.repo:
[oneAPI]
name=Intel(R) oneAPI repository
baseurl=https://yum.repos.intel.com/oneapi
enabled=1
gpgcheck=1
repo_gpgcheck=1
gpgkey=https://yum.repos.intel.com/intel-gpg-keys/GPG-PUB-KEY-INTEL-SW-PRODUCTS.PUB
 mkl_conflict.def:
Bootstrap: docker
%files
  oneAPI.repo /etc/yum.repos.d
%post
  yum -y update
I have also attempted this variation to no avail:
Bootstrap: library
Cleaning the Singularity cache had no impact on the overall result and the problem has also been replicated by colleagues. We suspect there may be a recent problem with the repository, as previously there was no issue.
Many thanks,
Jesse
jpharr
Bootstrap: docker
Best wishes,
Jesse
