There seems to be an issue when trying to install the 32 version of the intel basekit.
Repo steps:
- Perform pre install steps and configure repository according to: APT (intel.com)
- Install 64 bit kit using sudo apt install intel-basekit. Result, success.
- Install 32 bit kit using sudo apt install intel-basekit-32bit. Result, failure, receive error ' Unable to locate package intel-basekit-32bit'
32 bit version of package seems to be missing from your APT repository.
Hi, could you use the following command and check if you are able to install the 32bit BaseKit version:
sudo dpkg --add-architecture i386 && apt update
We would like to know.
Hi, could you confirm the following with us:
- OS build on which you are installing the toolkit
- Screenshot of the error screen
System setup, Ubuntu 22.04.1 running on WSL2.
Screenshot of error encountered when running sudo apt install intel-basekit-32bit attached.
Just to reiterate, only the 32bit package causing an issue, 64bit package installs fine.
Hi, thank you for sharing the screenshot with us.
We have contacted you internally with some information. Please check your inbox for further updates.
Hi, we have contacted you privately to gather some information. Please check your inbox for further updates.
Unfortunately issue still not resolved, tried again from my dev PC and a fresh Ubuntu VM, 32bit basekit still not found.
Hi, we have contacted you internally to share some information. Please check your inbox for further updates.
Hi, that fixed it, am now able to apt install the 32bit basekit. Thank you.
Hi, thank you for accepting our solution. We are glad that the issue is resolved.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
