oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1578 Discussions
oneAPI installation and uninstallation with VS2022
仁义_许_
If I remove oneAPI 2022 from VS2022, the bellow error is popped up:
Removal of component has failed.
Component id: intel.oneapi.win.dpcpp_debugger.vsmi.vs2022, name: Intel Distribution for GDB*, version:2021.5.0-115.
Error: Sequence execution failed.
If I install oneAPI 2022.2 to VS2022, the bellow error is popped up:
Component id: intel.oneapi.win.compilers-common.ide.common_vs2022, name: IDE Common for visual Studio 2022, version:2022.0.0-161.
ArpanB_Intel
Hi Xu, please follow the below steps:
  • Close Intel® installers if any.
  • Uninstall all Microsoft Visual Studio instances and Visual Studio Installer.
  • Important: check that C:\ProgramData\Microsoft\VisualStudio\Setup\x86\Microsoft.VisualStudio.Setup.Configuration.Native.dll does not exist anymore. If it was not removed with Microsoft Visual Studio for some reason, please unregister the DLL using REGSVR32 /U C:\ProgramData\Microsoft\VisualStudio\Setup\x86\Microsoft.VisualStudio.Setup.Configuration.Native.dll
command in Command Prompt as Administrator, and then rename the file to Backup_Microsoft.VisualStudio.Setup.Configuration.Native.dll so the Intel® Installer can't load it.
仁义_许_
How can I update oneAPI?
The update button cannot be found in the oneAPI installer
ArpanB_Intel
Xu, once you have installed an Intel® oneAPI Base Toolkit, rerun the same installer again. It will automatically detect the presence of the existing version of the toolkit installed on your system and check and show you if a new version is available for update.
仁义_许_
Can oneAPI intergrate with xcode in macOS?
ArpanB_Intel
ArpanB_Intel
Xu, we have moved your post installation query to the relevant forum.
Your issue will be further addressed here> https://community.intel.com/t5/Intel-oneAPI-Data-Parallel-C/Failed-to-activate-the-quot-Environment-Configurator-for-Intel/td-p/1391990
ArpanB_Intel
Xu, since the installation issue was addressed, we are going ahead and closing this thread.
If you have any further queries please post a new question as this thread will no longer be monitored by Intel®.
