FPGA Intellectual Property
6376 Discussions
NIOS2 DDR2 refrence desing
Dear friends,
does any body have solution for NIOS2 DDR2 in sopc builder, i tried with ddr2 documents but during complilation timing error, i dont know why, pleaese help me.
if any body have refrence design, please upload here, i am using custom statrix II board.
regards,
baba
I think you are profession in my issues, I need your help.
I have some troubles with my design with Stratix II devices. I use MegaWizard, Quartus's Web edition, to create ALTMEMPHY. It releases many files such as:
*_alt_mem_phy_reconfig_sii
*_alt_mem_phy_ sii
alt_mem_phy_defines
alt_mem_phy_sequencer.vhd
*_altmem_phy_sequencer_wrapper.vo
Module "alt_mem_phy_sequencer.vhd" is encrypted, so I can't see anything. How can I use this module?
To ensure my logic is ok, I simulate them with my logic by using NCverilog 5.5. But the way ALTMEMPHY tool uses parameter is new to me. And when I run my simulation, it can not stop and print out may warnings. So you can give me your advice.
I'm very impressed by ALTMEMPHY but I can't use it for a long time.
Thank you in advance!
today is friday, 7.30 pm, so, detail solution tomorrow , no problem you can beat that
What timing issues are you running? What messages do you get within SOPC Builder or the Quartus II Compilation?
More info buddy
Hi babaship,
What is the error message?
I think that You must delete the following files list and regenerate your NIOS system.
- add_constraints_for_< >.tcl
- auto_add_ddr_constraints.tcl
- auto_verify_ddr_timing.tcl
- ddr_lib_path.tcl
- remove_add_constraints_for_< >tcl
- verify_timing_for_< >.tcl
--- Quote Start ---
*_alt_mem_phy_ sii
alt_mem_phy_defines
--- Quote End ---
Hi tuanna,
You can simulate your NIOS system by using SOPC Builder. It can create a simulator project.
