FPGA Intellectual Property
6359 Discussions
Looking for free IPs
I am new to Altera forum and Altera FPGAs in general. I have the following queries pls.
** Like Xilinx Core generator, does Altera Quartus 2 give free IPs as well? If so, what is the name of the core generator interface and is there a list of free IPs (preferably in VHDL) which one can
use?
** What is the difference between web edition and pro edition.
Arvind Gupta
IP Base Suite: https://www.altera.com/products/intellectual-property/design/q_and_a.html
Included with standard and pro editions of the software. You can get a license to use it with the Lite edition.
Here's a comparison of the different editions: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/po/ss-quartus-comparison.pdf
There is no web edition anymore. It is now called the Lite edition.
OK... are the basic IPs not free...?I am looking for tit bits like LCD controller, SPI master/slave, I2c etc.
Thanks and Regards,
Arvind Gupta
The IP base suite is for more advanced IPs such as Ethernet or DRAM controllers. You will find GPIOS and SPI master/slaves in the embedded ips (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_embedded_ip.pdf) and most of them are free. There is an I2C core on the altera wiki (http://www.alterawiki.com/wiki/i2c_(opencores)). For LCD I'm not sure there is a dedicated controller but you can use a GPIO and bit bang it (or use an LCD with an I2C interface).
You could always take have a go with the lottery of stuff on opencores.org aswell. Though from what Ive seen there they are hobbiest projects with poor documentation and poor quality code formatting/commenting, and little support.
Otherwise take the plunge and write your own - good learning experience.
If you are a student learning about FPGA using one of the DE-series boards, you can get free IP for the boards via the university program installer:
https://www.altera.com/support/training/university/materials-ip-cores.html
