I am new to Altera forum and Altera FPGAs in general. I have the following queries pls. ** Like Xilinx Core generator, does Altera Quartus 2 give free IPs as well? If so, what is the name of the core generator interface and is there a list of free IPs (preferably in VHDL) which one can use? ** What is the difference between web edition and pro edition. Thanks, Arvind GuptaLink Copied
IP Base Suite: https://www.altera.com/products/intellectual-property/design/q_and_a.html
Included with standard and pro editions of the software. You can get a license to use it with the Lite edition. Here's a comparison of the different editions: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/po/ss-quartus-comparison.pdf There is no web edition anymore. It is now called the Lite edition.- Mark as New
OK... are the basic IPs not free...?I am looking for tit bits like LCD controller, SPI master/slave, I2c etc.
Thanks and Regards, Arvind Gupta- Mark as New
The IP base suite is for more advanced IPs such as Ethernet or DRAM controllers. You will find GPIOS and SPI master/slaves in the embedded ips (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_embedded_ip.pdf) and most of them are free. There is an I2C core on the altera wiki (http://www.alterawiki.com/wiki/i2c_(opencores)). For LCD I'm not sure there is a dedicated controller but you can use a GPIO and bit bang it (or use an LCD with an I2C interface).
You could always take have a go with the lottery of stuff on opencores.org aswell. Though from what Ive seen there they are hobbiest projects with poor documentation and poor quality code formatting/commenting, and little support.
Otherwise take the plunge and write your own - good learning experience.- Mark as New
If you are a student learning about FPGA using one of the DE-series boards, you can get free IP for the boards via the university program installer:
https://www.altera.com/support/training/university/materials-ip-cores.html- Subscribe to RSS Feed
