AI Tools from Intel
Find answers to your toolkit installation, configuration, and get-started questions.
TEMP HIGH I5 14600K
BEmY
Hello friends, I have a question. I would be grateful if you could help me. I have a CPU I5 14600K, my water cooling is DEEPCOOL LE720 ARGB. When I install a game, the temperature immediately rises above 80 degrees from 35 degrees, and also in the CPU Z benchmark test, the system also lags what is the problem?
Mike_Intel
Hello BEmY,
Before we proceed, let me gather some details about the issue.
  1. When did you start having the overheating issue?
  2. Are you running on default settings?
  3. What is the temperature reading inside the BIOS?
  4. What are the troubleshooting steps that you tried so far?
Michael L.
Mike_Intel
Hello BEmY,
Michael L.
Mike_Intel
Hello BEmY,
I am sending another follow up on the information that I requested.
Michael L.
