AI Tools from Intel
Find answers to your toolkit installation, configuration, and get-started questions.
153 Discussions
intel extension for pytorch: OSError: [WinError 126] The specified module could not be found.
isale
4 304 Visites
Hello, I am trying to install Intel Extension for PyTorch in my conda environment with Python 3.10. I have an Intel ARC A750. I followed the official guide exactly: https://intel.github.io/intel-extension-for-pytorch/index.html#installation?platform=gpu&version=v2.1.30%2bxpu&os=windows&package=pip . However, it is not detected and returns this error:
0 Compliments
Ying_H_Intel
Modérateur
4 155 Visites
Hi
Thank you for raising the quesiton here,
The error message shows some related dll are not found in the environment. Could you please check if you already install all related SW inlcude oneAPI Base tools and MSVS 2022?
for example, the github issue: ipex-xpu "OSError: [WinError 126] The specified module could not be found." on windows i7-1185G7 · Issue #429 · intel/intel-extension-for-pytorch (github.com)
here is one install guide for your reference:
1. conda create -n ipex_test python=3.10
2.conda activate ipex_test
3. conda install pkg-config libuv
4. python -m pip install torch==2.1.0.post2 torchvision==0.16.0.post2 torchaudio==2.1.0.post2 intel-extension-for-pytorch==2.1.30.post0 --extra-index-url https://pytorch-extension.intel.com/release-whl/stable/xpu/us/
5. pip install dpcpp-cpp-rt==2024.1 mkl-dpcpp==2024.1
6. python -m pip install setuptools==69.5.1
python -m pip install numpy==1.26.4
7. Verify Env is correct : python -c "import torch; import intel_extension_for_pytorch as ipex; print(torch.__version__); print(ipex.__version__); [print(f'[{i}]: {torch.xpu.get_device_properties(i)}') for i in range(torch.xpu.device_count())];
Please feel free to let me know if any result.
Voir la solution dans l'envoi d'origine
0 Compliments
2 Réponses
Ying_H_Intel
Modérateur
4 156 Visites
Hi
0 Compliments
isale
4 063 Visites
Good morning, thank you very much for the response. I apologize for the delay in replying. It works perfectly now, again, thank you so much!
0 Compliments
Répondre
