AI Tools from Intel
Find answers to your toolkit installation, configuration, and get-started questions.
oneAPI MODIN fail on CORE (GEN13 i9)
WeiSeng
When I try to installed oneAPI base toolkit and test the MODIN sample apps:
https://github.com/oneapi-src/oneAPI-samples/tree/master/AI-and-Analytics/Getting-Started-Samples/IntelModin_GettingStarted
Then detected error below:
(raylet) [2023-10-10 22:04:54,885 E 21639 21688] (raylet) agent_manager.cc:135: The raylet exited immediately because the Ray agent failed. The raylet fate shares with the agent. This can happen because the Ray agent was unexpectedly killed or failed. Agent can fail when
(raylet) - The version of grpcio doesn't follow Ray's requirement. Agent can segfault with the incorrect grpcio version. Check the grpcio version pip freeze | grep grpcio.
(raylet) - The agent failed to start because of unexpected error or port conflict. Read the log cat /tmp/ray/session_latest/dashboard_agent.log. You can find the log file structure here https://docs.ray.io/en/master/ray-observability/ray-logging.html#logging-directory-structure.
(raylet) - The agent is killed by the OS (e.g., out of memory).
oneAPI Version: oneAPI toolkit version: 2023.2.0
Environment:
OS is Linux uBuntu 22.04.2 LTS
CPU: 13th Gen Intel(R) Core(TM) i9-13900
RAM: 32GB
Steps to reproduce:
Using the conda running the MODIN sample apps that released by oneAPI:
AthiraM_Intel
Based on our discussion about creating a priority ticket if needed, I am going ahead and closing this thread for now.
Please feel free to contact us further if you need any assistance from our side.
