Analyzers
5339 Discussions
Amplifier cannot detect remote machine configuration.
zhangmiao__dong
Hi
When I use vtune on windows host to analysis the target linux application with ssh, the vtune show error "Amplifier cannot detect remote machine configuration." Can anybody tell me how to correct it? Thanks very much!
So for, I have installed the drivers required on target linux and copy the vtune_amplifier_2018.3.0.566015 folder to /opt/intel.
Then link the /lib64/ld-linux-x86-64.so.2 to /lib/.
Run amplxe-runss --context-value-list show follow logs.
targetOS: Linux
OS: Linux
OSBuildNumber: 0
OSBitness: 64
RootPrivileges: true
isPtraceScopeLimited: false
isTSXAvailable: true
isHTEnabled: false
fpgaOnBoard: None
pciClassParts:
isSGXAvailable: false
LinuxRelease: 4.8.0-36-generic
IsNUMANodeWithoutCPUsPresent: false
Hypervisor: VMwareVMware
PerfmonVersion: 1
isPtraceAvailable: true
areGpuHardwareMetricsAvailable: UnsupportedInterfaceVersion
i915Status: MissingDriver
isFtraceAvailable: yes
isMdfEtwAvailable: false
isCSwitchAvailable: yes
isGpuBusynessAvailable: unsupportedHardware
isGpuWaitAvailable: no
isFunctionTracingAvailable: yes
isIowaitTracingAvailable: yes
isVSyncAvailable: yes
isPAXDriverLoaded: true
isHyperVEnabled: false
isDeviceOrCredentialGuardEnabled: false
isSEPDriverAvailable: true
platformType: 103
CPU_NAME: Intel(R) Processor code named Skylake
PMU: skylake
referenceFrequency: 3200000000
isVTSSPPDriverAvailable: true
isNMIWatchDogTimerRunning: false
LinuxPerfCredentials: Unlimited
LinuxPerfCapabilities: breakpoint:raw;cpu:raw,format,events,ldlat,frontend;msr:raw,format,events;power:raw,format,events;software:raw;tracepoint:raw
LinuxPerfStackCapabilities: fp,dwarf
isTPSSAvailable: true
isPytraceAvailable: true
isGENDebugInfoAvailable: false
isGTPinCollectionAvailable: ErrorUnsupportedHardware
isSTTAvailable: no
isCOHNPKCtrlLibAvailable: false
Kirill_U_Intel
Hi, Dong.
Could you share the host command output?
INSTALL_VTUNE_DIR/bin64/amplxe-python INSTALL_VTUNE_DIR/bin64/amplxe-runss.py --no-modules --log-folder=WRITABLE_FOLDER --target-system=ssh:USER@TARGET_IP --target-install-dir=/opt/intel/vtune_amplifier_2018.3.0.566015 --ui-output-format xml --context-value-list
and attach WRITABLE_FOLDER with logs files.
Thanks, Kirill
