Analyzers
Assertion fail during install.sh
Martin_I_
During VTune Amplifier XE installation, on Fedora20 X64, I am getting an assert and install fails,
Any suggestion how to fix it is welcome.
Please type a selection or press "Enter" to accept default choice [1]: 2
process 19133: arguments to dbus_move_error() were incorrect, assertion "(dest) == NULL || !dbus_error_is_set ((dest))" failed in file dbus-errors.c line 282.
This is normally a bug in some application using the D-Bus library.
  D-Bus not built with -rdynamic so unable to print a backtrace
./install.sh: line 769: 19133 Aborted                 $pset_engine_cli_binary --tmp_dir=$user_tmp --TEMP_FOLDER=$temp_folder --log_file=$log_file $silent_params $duplicate_params $params --PACKAGE_DIR=$fullpath --PSET_MODE=install
David_A_Intel1
What release are you trying to install and have you verified that Fedora 20 is supported by that version?  See the Release Notes "System Requirements" section.
Also, are you installing as root, sudo, or a regular user?
Martin_I_
Hi.
I am trying to evaluate vtune_amplifier_xe_2015.1.0.367959, and Fedora 20 is supported, working as root.
Vitaly_S_Intel
Hi Martin!
Can you please tell on which step install failed with this message?
Can you attach files intel.pset and intel.issa located in /tmp after installation?
Thanks!
