Analyzers
Call tree and bottom-up stopped working, VS C++
Stephen_T_1
I'm compiling and running a VS C++ application and then running it stand-alone with Vtune XE 2013
It was working fine and I could see the top-down and bottom-up calls trees but now for some reason
these will not go further than one level - is there something broken, set-up,
What have I gone and done ?
Steve
stephethomas@gmail.com
Robert_L_Intel1
Hi Stephen - Is it possible you have set the filter by accident?  The "call-stack-mode" at the bottom?
Could you post a screen-shot?
Stephen_T_1
Please find the screen shot attached
I'm quite stuck, any help would be appreciated
Steve
Kevin_O_Intel1
Hi Steve,
Could you share your vtune amplifier xe result directory?(or if you prefer... you could send it to me directly)
Also... what compiler version are you using?
Kevin
Stephen_T_1
I'm using the Visual Studio C++ compiler, 2010
Can I send the result directory to you (zip'ed )
Stephen_T_1
zip'ed result directory attached
Vitaly_S_Intel
Hi Stephen!
I see your results are collected with "--mrte-mode=managed" - in VS it is inherited from VS settings (debugging -> managed). Since your application is native, you need to change this option.
If you are unable to find this setting in VS, you can try standalone VTune (not the one integrated to VS) - create new project and run Basic Hotspots there, you should see call stacks now.
Stephen_T_1
Hi Vitaly
I have been running in Stand-Alone Vtune without launching from Visual Studio. Would this make a difference ?
What would you recommend. Should I somehow start over and create a new project in VTune ?
I can not find the option you mentioned in VS, would it be under compiler C++ or linker ?
Stephen
Stephen_T_1
Found the tools, debugging options, I'm using VS2010 so the compatabilty mode is not an
available option
There has to be some other reason why the call stacks are not showing up ?
Vitaly_S_Intel
Stephen, please check the following options in VS (depending on VS version):
- Configuration Properties -> Debugging -> Debugger Type (should be Auto or Native)
- Debug -> Enable unmanaged code debugging (should be turned on)
If you collect data using VTune standalone, please make sure the following option has correct value:
- Project Properties -> Managed code profiling mode = Auto or Native
Stephen_T_1
Thank-you !!!
It was set to Managed in Vtune and switching to Auto corrected the problem
Much appreciated !
