Analyzers
5285 Discussions
Cannot install VTune on Ubuntu 10.04(Lucid) x86_64
Jianshi_Huang
After entering the serial, comes the following error message.
Please type a selection or Serial Number: xxxx-xxxxxxxx
The Intel Software Setup Assistant may attempt to connect to the
Intel Software Development Products Registration Center to validate your Serial Number.
This may take several minutes depending on your network. Please wait...
You may press Ctrl+C to cancel.
secore.new: relocation error: /usr/lib32/libnss_mdns4_minimal.so.2: symbol strlen, version GLIBC_2.0 not defined in file libc.so.6 with link time reference
What's the problem andanyway to fix that?
Jianshi_Huang
Update:
However, strlen@@GLIBC_2.0 is actually defined. See below:
$ ldd /usr/lib32/libnss_mdns4_minimal.so.2
linux-gate.so.1 => (0xf7740000)
libc.so.6 => /lib32/libc.so.6 (0xf75a1000)
/lib/ld-linux.so.2 (0xf7741000)
$ readelf -s /lib32/libc.so.6 |grep strlen
805: 00074400 52 IFUNC GLOBAL DEFAULT 12 strlen@@GLIBC_2.0
935: 00079650 23 FUNC GLOBAL DEFAULT 12 __strlen_g@@GLIBC_2.1.1
Peter_W_Intel
Latest product v9.1 U8 supports Ubuntu* 9.10, v10.04 hasn't been tested!!!
Also please ensure that you can access Intel Product Register Center via network, when use serial number to install the product. You may copy license file to Linux side for installing the product. License file should be sent to you with serial number in email - if you missed the file, go Register Center to send again by yourself.
Regards, Peter
Vilya_Harvey
I had the same problem, also on Ubuntu 10.04 and x86_64 (although it was being reported in libresolv for me instead), but was able to install successfully by giving the path to a local license file. Looks like more testing is needed on 10.04, but at least there's a workaround.
Peter_W_Intel
Quoting Vilya Harvey
I am glad to see of using local license file to solve the installation problem:-)
However using the toolin unsupported OS, still is a risk.
Jianshi_Huang
I successfully installed VTune by license file. Thanks for the workaround.
The warning of unsupported OS version is only shown after the license was provided. Wouldn't it be better to let show on the first page?
BTW, stating a GNU-Linux system is not supported because of OS version isn't very convincing. It would be better if you can show a list of dependencies so we programmers can figure it out.
I hope it's just a installation glitch, finger crossed. :)
Jianshi
christian_convey
Quoting huangjs
Jianshi
Yes, but it would be far better iof Intel had near-same-day in VTune support for each new Ubuntu release.
TimP
It's an inconvenient fact that it's impossible to foresee "features" of distros which aren't available at the time a product is developed, and that several months of testing go into full support. Ubuntu is one of the most oddball distros for which it has been possible to offer full support, at cost of considerable additional effort. It's a very nice distro, but there is a reason why most others adhere to standards such as LSB.
License recognition by serial number may fail for a number of reasons, including web connectivity and temporary web site outages, so it's perhaps unfortunate if marketing requirements make the backup method difficult to discover.
