Analyzers
5297 Discussions
an oddness problem when run vtune9.1 update 8 for linux
explore_zjx
Hello, everyone:
I installed vtune 9.1 update 8 for linux successfully on my platform.
The Plateform is as follows:
OS:FC12-2.6.31-127
CPU: core i3 550
I create a newsmpling project step by step through click the next button. However, there is an oddness problem when I slected a sampling wizard. In the "linux executable application" dialogue, there are no response when I click the next button. But the "ALT+N" command could forward the next window. I'm assure the the mouse works well. Andin the last dialogue,the "finish" button is the same as before.I want to ask if there are some bugs in the vtune9.1 update 8 for linux FC12 on core i3 platform.
Would you give me some possible reasons aboutabove phenomenon.
Thanks a lot.
Jason
2010/10/13
Peter_W_Intel
I suppose that was caused by new OS, please see this article.
Hope it helps.
Regards, Peter
Peter_W_Intel
Hope it helps.
Regards, Peter
explore_zjx
thanks ! It's the best answer.
