Analyzers
Collect locks and waits data failed
zhihong_l_
I run vtune on linux (redhat 7.1) ,use the gui tool. when I collected the locks and waits type, collection can not continue:
Application sets its own handler for signal 38 that is used for internal needs of the tool.
but other type of analysis works well.
what's the problem and how to fixed it ? I want to collect locks and waits data of my system.
thank you.
Peter_W_Intel
I heard this issue before, do you use latest VTune(TM) Amplifier XE 2016 Update 1?
zhihong_l_
hi Peter,
I use  VTune(TM) Amplifier XE 2016 Update 2.
thanks.
Peter_W_Intel
Sorry, latest is Update 2.
Can you please try command line like - "amplxe-cl -c locksandwaits --run-pass-thru=--profiling-signal=33 -- application"?
zhihong_l_
OK, thanks Peter, I will try it soon, and tell you the result later.
Now I have a new problem, I install vtune (latest version) in another system (OEL 7.1) and while i start run ./amplxe-gui and it shows:error_0.png
and then the opening GUI were filled with messy code.
Is the OS lack of some libs ? or I need some other configuration?
thanks.
Peter_W_Intel
It implied there some X11 libraries missed - font library? Please do sanity check of your GTK*.
zhihong_l_
Hi ,Peter,
I run that command in command line, and it  works well. but the elapsed time only 0.075 seconds.
how can i control the analysis time? add  '--duration=xxx ' ? or How can i just let it run untill i stop it ?
thank you.
zhihong_l_
hi Peter,
by the way , is the signal 38 conflict were caused by gui model ? or why it work in command line ?
Peter_W_Intel
It is great that you can work on command line...you also can use option "-d xxx" to stop application to terminate collection if it still runs.
