Analyzers
Collection failed
Cyril_Khazan
Hi, would appreciate help with the following error. Has been working fine with XE Beta, now fails in XE Update 4:
OS: Windows 7
Compiler: VS 2008
Source code: anything, e.g. "int main() { return 0; }"
Analysis type attempted: Hotspots
Error: Source\\pin\\core_ia32\\ins_xed_ia32.cpp:LEVEL_CORE::xed_exact_map_from_pin_reg:1371: An architectural register is required, but we got: pin_t0
Target process's profiling finished but the following processes are still being profiled:
PPID PID STATE NAME
034672 034148 RESUME test.exe
You may stop collection manually. The processes listed above will be terminated.
Error: Source\\pin\\core_ia32\\ins_xed_ia32.cpp:LEVEL_CORE::xed_exact_map_from_pin_reg:1371: An architectural register is required, but we got: pin_t0Target process's profiling finished but the following processes are still being profiled:PPID PID STATE NAME034672 034148 RESUME test.exe
Cyril
