[Process] Process Name: amplxe-runss.exe Virtual Memory Size: 218580K Working Set Size: 41936K [Assertion] CrashedPID: 11644 CrashedTID: 13288 Expression: process != NULL && process->getParentId() == ppid File: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\event_handler.cpp Line: 781 Product: Intel(R) VTune(TM) Amplifier 2018 Update 1; 535340 ReportPath: C:\Users\max\AppData\Local\Temp\amplxe-log-max\2018-04-13-12-41-53-752.amplxe-runss.exe\ [Products] Package ID: N/A Package Contents: Intel(R) VTune(TM) Amplifier 2018 Update 1 Build Number: 535340 [System] Host Name: DESKTOP-74O9PUR OS Name: Microsoft Windows 10 Pro OS Version: 10.0.16299 N/A Build 16299 OS Manufacturer: Microsoft Corporation OS Configuration: Standalone Workstation OS Build Type: Multiprocessor Free Registered Owner: Windows User Registered Organization: Product ID: 00330-80000-00000-AA399 Original Install Date: 11/15/2017, 02:40:56 PM System Boot Time: 4/11/2018, 04:16:25 PM System Manufacturer: Hewlett-Packard System Model: HP Compaq Elite 8300 CMT System Type: x64-based PC Processor(s): 1 Processor(s) Installed. [01]: Intel64 Family 6 Model 58 Stepping 9 GenuineIntel ~3392 Mhz BIOS Version: Hewlett-Packard K01 v03.06, 2/12/2018 Windows Directory: C:\WINDOWS System Directory: C:\WINDOWS\system32 Boot Device: \Device\HarddiskVolume1 System Locale: en-us;English (United States) Input Locale: en-us;English (United States) Time Zone: (UTC+03:00) Minsk Total Physical Memory: 16,258 MB Available Physical Memory: 6,953 MB Virtual Memory: Max Size: 24,450 MB Virtual Memory: Available: 11,067 MB Virtual Memory: In Use: 13,383 MB Page File Location(s): C:\pagefile.sys Domain: WORKGROUP Logon Server: \\DESKTOP-74O9PUR Hotfix(s): 12 Hotfix(s) Installed. [01]: KB4048951 [02]: KB4053577 [03]: KB4054022 [04]: KB4056887 [05]: KB4058043 [06]: KB4058702 [07]: KB4088785 [08]: KB4090914 [09]: KB4093110 [10]: KB4099989 [11]: KB4088776 [12]: KB4093112 Network Card(s): 2 NIC(s) Installed. [01]: Intel(R) 82579LM Gigabit Network Connection Connection Name: Ethernet DHCP Enabled: Yes DHCP Server: 192.168.1.1 IP address(es) [01]: 192.168.1.165 [02]: fe80::951f:907d:590a:20cc [03]: 2a00:6440:173:101::f4c [02]: VirtualBox Host-Only Ethernet Adapter Connection Name: VirtualBox Host-Only Network DHCP Enabled: No IP address(es) [01]: 192.168.56.1 [02]: fe80::613f:6697:7dc3:bce4 Hyper-V Requirements: VM Monitor Mode Extensions: Yes Virtualization Enabled In Firmware: Yes Second Level Address Translation: Yes Data Execution Prevention Available: Yes [ClientInfo] Report ID: 58c3a1d2-6b39-432a-88a7-3b78a67ef8d7 UUID: {AA1C6D45-4AF2-4D65-B4F8-04F93DB2ED59} [Dump] Path: C:\Users\max\AppData\Local\Temp\amplxe-log-max\2018-04-13-12-41-53-752.amplxe-runss.exe\crash.dmp [PremortalLog] 1458 [13288] WARN perfrun.etw <> - can't find grandparent process for the process with pid 0 and ppid = 0, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:430 1544 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 0; pid = 0, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1544 [13288] WARN perfrun.etw <> - the thread was not added: tid = 0; pid = 0, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:177 1545 [13288] WARN perfrun.etw <> - can't append the thread: tid = 0; pid = 0, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\event_handler.cpp:711 1545 [13288] WARN perfrun.etw <> - the thread was not added: tid = 0; pid = 0, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:177 1545 [13288] WARN perfrun.etw <> - can't append the thread: tid = 0; pid = 0, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\event_handler.cpp:711 1545 [13288] WARN perfrun.etw <> - the thread was not added: tid = 0; pid = 0, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:177 1545 [13288] WARN perfrun.etw <> - can't append the thread: tid = 0; pid = 0, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\event_handler.cpp:711 1545 [13288] WARN perfrun.etw <> - the thread was not added: tid = 0; pid = 0, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:177 1545 [13288] WARN perfrun.etw <> - can't append the thread: tid = 0; pid = 0, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\event_handler.cpp:711 1545 [13288] WARN perfrun.etw <> - the thread was not added: tid = 0; pid = 0, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:177 1545 [13288] WARN perfrun.etw <> - can't append the thread: tid = 0; pid = 0, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\event_handler.cpp:711 1545 [13288] WARN perfrun.etw <> - the thread was not added: tid = 0; pid = 0, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:177 1545 [13288] WARN perfrun.etw <> - can't append the thread: tid = 0; pid = 0, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\event_handler.cpp:711 1546 [13288] WARN perfrun.etw <> - the thread was not added: tid = 0; pid = 0, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:177 1546 [13288] WARN perfrun.etw <> - can't append the thread: tid = 0; pid = 0, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\event_handler.cpp:711 1546 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 12; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1546 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 16; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1546 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 20; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1546 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 24; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1546 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 28; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1630 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 36; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1630 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 40; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1630 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 44; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1631 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 48; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1631 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 52; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1631 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 56; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1631 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 60; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1631 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 64; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1631 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 68; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1631 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 72; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1632 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 76; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1632 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 80; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1632 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 104; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1632 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 108; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1632 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 112; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1632 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 116; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1632 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 120; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1633 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 124; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1633 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 136; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1633 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 140; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1633 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 144; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1633 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 148; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1633 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 152; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1633 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 156; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1633 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 160; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1634 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 164; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1634 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 168; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1634 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 172; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1634 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 176; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1634 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 180; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1634 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 184; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1634 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 188; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1635 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 200; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1635 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 204; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1635 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 208; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1635 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 212; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1635 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 220; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1635 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 268; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1635 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 272; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1635 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 280; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1636 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 284; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1636 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 288; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1636 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 292; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1636 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 296; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1636 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 300; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1636 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 304; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1636 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 308; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1637 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 312; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1637 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 316; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1637 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 320; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1637 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 324; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1637 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 328; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1637 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 332; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1637 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 336; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1637 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 340; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1638 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 344; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1638 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 348; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1638 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 352; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1638 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 356; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1638 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 396; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1638 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 404; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1638 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 408; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1639 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 412; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1639 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 420; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1639 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 432; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1639 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 436; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1639 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 444; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1639 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 448; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1639 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 464; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1639 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 468; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1640 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 472; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1640 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 476; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1640 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 480; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1640 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 484; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1640 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 488; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1640 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 492; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1640 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 496; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1640 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 500; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 1641 [13288] WARN perfrun.etw <> - start address isn't inside a known module: tid = 564; pid = 4, at file: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\vcs\perfrun1\plugins\etw\src\kernel\process_tree.cpp:166 [Context.0x000011e8] EAX: 0x0000000000000000 EBP: 0x000002bed61aa3a8 EBX: 0x0000000000000000 ECX: 0x0000000000000000 EDI: 0x0000000000000000 EDX: 0x0000000000000000 EIP: 0x00007fff3511ff04 ESI: 0x0000000000000000 ESP: 0x000000faf01ff258 R10: 0x0000000000000000 R11: 0x0000000000000000 R12: 0x0000000000000000 R13: 0x0000000000000000 R14: 0x0000000000000000 R15: 0x0000000000000000 R8: 0x0000000000000000 R9: 0x0000000000000000 [Context.0x000013d8] EAX: 0x0000000000000000 EBP: 0x000000faef4fd550 EBX: 0x0000000000000000 ECX: 0x0000000000000000 EDI: 0x0000000000000000 EDX: 0x0000000000000000 EIP: 0x00007fff3511ff04 ESI: 0x0000000000000000 ESP: 0x000000faef4fd478 R10: 0x0000000000000000 R11: 0x0000000000000000 R12: 0x0000000000000000 R13: 0x0000000000000000 R14: 0x0000000000000000 R15: 0x0000000000000000 R8: 0x0000000000000000 R9: 0x0000000000000000 [Context.0x000015d8] EAX: 0x0000000000000000 EBP: 0x000000faefbfe900 EBX: 0x0000000000000000 ECX: 0x0000000000000000 EDI: 0x0000000000000000 EDX: 0x0000000000000000 EIP: 0x00007fff3511ff04 ESI: 0x0000000000000000 ESP: 0x000000faefbfe888 R10: 0x0000000000000000 R11: 0x0000000000000000 R12: 0x0000000000000000 R13: 0x0000000000000000 R14: 0x0000000000000000 R15: 0x0000000000000000 R8: 0x0000000000000000 R9: 0x0000000000000000 [Context.0x000017a0] EAX: 0x0000000000000000 EBP: 0x000000faf02ffb70 EBX: 0x0000000000000000 ECX: 0x0000000000000000 EDI: 0x0000000000000000 EDX: 0x0000000000000000 EIP: 0x00007fff3511ff04 ESI: 0x0000000000000000 ESP: 0x000000faf02ffa78 R10: 0x0000000000000000 R11: 0x0000000000000000 R12: 0x0000000000000000 R13: 0x0000000000000000 R14: 0x0000000000000000 R15: 0x0000000000000000 R8: 0x0000000000000000 R9: 0x0000000000000000 [Context.0x000029cc] EAX: 0x0000000000000000 EBP: 0x0000000000000414 EBX: 0x0000000000000000 ECX: 0x0000000000000000 EDI: 0x0000000000000000 EDX: 0x0000000000000000 EIP: 0x00007fff351209d4 ESI: 0x0000000000000000 ESP: 0x000000faf00ff228 R10: 0x0000000000000000 R11: 0x0000000000000000 R12: 0x0000000000000000 R13: 0x0000000000000000 R14: 0x0000000000000000 R15: 0x0000000000000000 R8: 0x0000000000000000 R9: 0x0000000000000000 [Context.0x000031ec] EAX: 0x0000000000000000 EBP: 0x000000faefcff630 EBX: 0x0000000000000000 ECX: 0x0000000000000000 EDI: 0x0000000000000000 EDX: 0x0000000000000000 EIP: 0x00007fff3511ff04 ESI: 0x0000000000000000 ESP: 0x000000faefcfee38 R10: 0x0000000000000000 R11: 0x0000000000000000 R12: 0x0000000000000000 R13: 0x0000000000000000 R14: 0x0000000000000000 R15: 0x0000000000000000 R8: 0x0000000000000000 R9: 0x0000000000000000 [Context.0x000032e4] EAX: 0x0000000000000000 EBP: 0x000000faf06fe370 EBX: 0x0000000000000000 ECX: 0x0000000000000000 EDI: 0x0000000000000000 EDX: 0x0000000000000000 EIP: 0x00007fff351205a4 ESI: 0x0000000000000000 ESP: 0x000000faf06fe2b8 R10: 0x0000000000000000 R11: 0x0000000000000000 R12: 0x0000000000000000 R13: 0x0000000000000000 R14: 0x0000000000000000 R15: 0x0000000000000000 R8: 0x0000000000000000 R9: 0x0000000000000000 [Context.0x000033e8] EAX: 0x00007fff01b0a264 EBP: 0x000000faefdfdc30 EBX: 0x000002bed8f89fb0 ECX: 0x0000000000000000 EDI: 0x000002bed977f840 EDX: 0x00007fff350c1630 EIP: 0x00007fff317b4008 ESI: 0x0000000000000000 ESP: 0x000000faefdfdb30 R10: 0x00007fff01b29800 R11: 0x0000000000000000 R12: 0x000000000000030d R13: 0x000002bed8f89fb0 R14: 0x000000faefdfddd8 R15: 0x000002bed8f71a90 R8: 0x000000faefdfd608 R9: 0x0000d3601b2d9ff6 [Context.0x00003484] EAX: 0x0000000000000000 EBP: 0x000000faefaff650 EBX: 0x0000000000000000 ECX: 0x0000000000000000 EDI: 0x0000000000000000 EDX: 0x0000000000000000 EIP: 0x00007fff351209d4 ESI: 0x0000000000000000 ESP: 0x000000faefaff2d8 R10: 0x0000000000000000 R11: 0x0000000000000000 R12: 0x0000000000000000 R13: 0x0000000000000000 R14: 0x0000000000000000 R15: 0x0000000000000000 R8: 0x0000000000000000 R9: 0x0000000000000000 [Context.0x000036cc] EAX: 0x0000000000000000 EBP: 0x0000000000000000 EBX: 0x0000000000000000 ECX: 0x0000000000000000 EDI: 0x0000000000000000 EDX: 0x0000000000000000 EIP: 0x00007fff35123794 ESI: 0x0000000000000000 ESP: 0x000000faef5ff7d8 R10: 0x0000000000000000 R11: 0x0000000000000000 R12: 0x0000000000000000 R13: 0x0000000000000000 R14: 0x0000000000000000 R15: 0x0000000000000000 R8: 0x0000000000000000 R9: 0x0000000000000000 [Context.0x00003798] EAX: 0x0000000000000000 EBP: 0x0000000000000000 EBX: 0x0000000000000000 ECX: 0x0000000000000000 EDI: 0x0000000000000000 EDX: 0x0000000000000000 EIP: 0x00007fff35123794 ESI: 0x0000000000000000 ESP: 0x000000faef7ffaf8 R10: 0x0000000000000000 R11: 0x0000000000000000 R12: 0x0000000000000000 R13: 0x0000000000000000 R14: 0x0000000000000000 R15: 0x0000000000000000 R8: 0x0000000000000000 R9: 0x0000000000000000 [Context.0x00003958] EAX: 0x0000000000000000 EBP: 0x000000faf03ff350 EBX: 0x0000000000000000 ECX: 0x0000000000000000 EDI: 0x0000000000000000 EDX: 0x0000000000000000 EIP: 0x00007fff3511ffa4 ESI: 0x0000000000000000 ESP: 0x000000faf03ff2b8 R10: 0x0000000000000000 R11: 0x0000000000000000 R12: 0x0000000000000000 R13: 0x0000000000000000 R14: 0x0000000000000000 R15: 0x0000000000000000 R8: 0x0000000000000000 R9: 0x0000000000000000 [Context.0x00004018] EAX: 0x0000000000000000 EBP: 0x0000000000000000 EBX: 0x0000000000000000 ECX: 0x0000000000000000 EDI: 0x0000000000000000 EDX: 0x0000000000000000 EIP: 0x00007fff35123794 ESI: 0x0000000000000000 ESP: 0x000000faeffff9c8 R10: 0x0000000000000000 R11: 0x0000000000000000 R12: 0x0000000000000000 R13: 0x0000000000000000 R14: 0x0000000000000000 R15: 0x0000000000000000 R8: 0x0000000000000000 R9: 0x0000000000000000 [Context.0x00004060] EAX: 0x0000000000000000 EBP: 0x000000faef9ffaa0 EBX: 0x0000000000000000 ECX: 0x0000000000000000 EDI: 0x0000000000000000 EDX: 0x0000000000000000 EIP: 0x00007fff351209d4 ESI: 0x0000000000000000 ESP: 0x000000faef9ff728 R10: 0x0000000000000000 R11: 0x0000000000000000 R12: 0x0000000000000000 R13: 0x0000000000000000 R14: 0x0000000000000000 R15: 0x0000000000000000 R8: 0x0000000000000000 R9: 0x0000000000000000 [Context.0x00004098] EAX: 0x0000000000000000 EBP: 0x0000000000000000 EBX: 0x0000000000000000 ECX: 0x0000000000000000 EDI: 0x0000000000000000 EDX: 0x0000000000000000 EIP: 0x00007fff35123794 ESI: 0x0000000000000000 ESP: 0x000000faefeff858 R10: 0x0000000000000000 R11: 0x0000000000000000 R12: 0x0000000000000000 R13: 0x0000000000000000 R14: 0x0000000000000000 R15: 0x0000000000000000 R8: 0x0000000000000000 R9: 0x0000000000000000 [Context.0x00004304] EAX: 0x0000000000000000 EBP: 0x0000000000000000 EBX: 0x0000000000000000 ECX: 0x0000000000000000 EDI: 0x0000000000000000 EDX: 0x0000000000000000 EIP: 0x00007fff35123794 ESI: 0x0000000000000000 ESP: 0x000000faef6ff8d8 R10: 0x0000000000000000 R11: 0x0000000000000000 R12: 0x0000000000000000 R13: 0x0000000000000000 R14: 0x0000000000000000 R15: 0x0000000000000000 R8: 0x0000000000000000 R9: 0x0000000000000000 [Context.0x0000475c] EAX: 0x0000000000000000 EBP: 0x000000faef8fef49 EBX: 0x0000000000000000 ECX: 0x0000000000000000 EDI: 0x0000000000000000 EDX: 0x0000000000000000 EIP: 0x00007fff3511ff04 ESI: 0x0000000000000000 ESP: 0x000000faef8fedd8 R10: 0x0000000000000000 R11: 0x0000000000000000 R12: 0x0000000000000000 R13: 0x0000000000000000 R14: 0x0000000000000000 R15: 0x0000000000000000 R8: 0x0000000000000000 R9: 0x0000000000000000 [Module000] Age: 0x0000000000000001 Base: 0x00007fff35080000 Begin: 0x00007fff35081000 End: 0x00007fff35193000 FullName: C:\WINDOWS\SYSTEM32\ntdll.dll Guid: 780c0c1b-6159-ae8b-7663-b42759ba7b4e Size: 0x00000000001e0000 SymbolName: ntdll.pdb Timestamp: 0x00000000effc9126 [Module001] Age: 0x0000000000000001 Base: 0x00007fff34ef0000 Begin: 0x00007fff34ef1000 End: 0x00007fff34f63000 FullName: C:\WINDOWS\System32\KERNEL32.DLL Guid: 1bccd94c-5154-86e0-3396-c7e89525227e Size: 0x00000000000ae000 SymbolName: kernel32.pdb Timestamp: 0x000000000c2cf900 [Module002] Age: 0x0000000000000001 Base: 0x00007fff34e80000 Begin: 0x00007fff34e81000 End: 0x00007fff34ec5000 FullName: C:\WINDOWS\System32\WS2_32.dll Guid: cf4c0101-147e-bd22-2bac-40066d789722 Size: 0x000000000006c000 SymbolName: ws2_32.pdb Timestamp: 0x000000009ac9e819 [Module003] Age: 0x0000000000000001 Base: 0x00007fff34650000 Begin: 0x00007fff34651000 End: 0x00007fff34684000 FullName: C:\WINDOWS\System32\sechost.dll Guid: 700da429-0140-4e2f-8a39-d001481b8a97 Size: 0x000000000005b000 SymbolName: sechost.pdb Timestamp: 0x00000000caf94b03 [Module004] Age: 0x0000000000000001 Base: 0x00007fff32580000 Begin: 0x00007fff32581000 End: 0x00007fff32780000 FullName: C:\WINDOWS\System32\combase.dll Guid: 7e1b6b31-68d2-00e8-9c33-239fa072f28a Size: 0x0000000000308000 SymbolName: combase.pdb Timestamp: 0x000000003db461b4 [Module005] Age: 0x0000000000000001 Base: 0x00007fff317a0000 Begin: 0x00007fff317a1000 End: 0x00007fff3188e000 FullName: C:\WINDOWS\System32\KERNELBASE.dll Guid: 141ada76-555f-cf3b-df62-e499523d3170 Size: 0x0000000000266000 SymbolName: kernelbase.pdb Timestamp: 0x0000000090a96867 [Module006] Age: 0x0000000000000001 Base: 0x00007fff30c00000 Begin: 0x00007fff30c01000 End: 0x00007fff30c4f000 FullName: C:\WINDOWS\system32\mswsock.dll Guid: 1afd6eca-ed9e-7dd0-fbd2-f6999a01f7f5 Size: 0x0000000000066000 SymbolName: mswsock.pdb Timestamp: 0x000000003a7c7ba7 [Module007] Age: 0x0000000000000001 Base: 0x00007fff1d200000 Begin: 0x00007fff1d201000 End: 0x00007fff1d226000 FullName: C:\Program Files (x86)\IntelSWTools\VTune Amplifier\bin64\amplxe_boost_thread_1.55.dll Guid: 4dfe7b00-b017-4b33-8331-3a9653a80604 Size: 0x0000000000043000 SymbolName: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\build\build_release_win32-x86_64_icl_15.0.221_mstools_12.0\boost\boost_1.55.0\boost.thread\amplxe_boost_thread_1.55.pdb Timestamp: 0x000000005a02343d [Module008] Age: 0x0000000000000001 Base: 0x00007fff06180000 Begin: 0x00007fff06181000 End: 0x00007fff06232000 FullName: C:\Program Files (x86)\IntelSWTools\VTune Amplifier\bin64\amplxe_qfagentminidump_core_1.18.dll Guid: 8007942b-82ab-4976-9242-7ce7f631f53d Size: 0x0000000000131000 SymbolName: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\build\build_release_win32-x86_64_icl_15.0.221_mstools_12.0\qfagentminidump.core\amplxe_qfagentminidump_core_1.18.pdb Timestamp: 0x000000005a02359c [Module009] Age: 0x0000000000000001 Base: 0x00007fff04d60000 Begin: 0x00007fff04d61000 End: 0x00007fff04d93000 FullName: C:\Program Files (x86)\IntelSWTools\VTune Amplifier\bin64\amplxe_qfagent_assert_1.18.dll Guid: d5178b62-283f-428c-9d5d-3d13b3754442 Size: 0x0000000000064000 SymbolName: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\build\build_release_win32-x86_64_icl_15.0.221_mstools_12.0\qfagentminidump.assert\amplxe_qfagent_assert_1.18.pdb Timestamp: 0x000000005a02359d [Module010] Age: 0x0000000000000001 Base: 0x00007fff04220000 Begin: 0x00007fff04221000 End: 0x00007fff0433c000 FullName: C:\Program Files (x86)\IntelSWTools\VTune Amplifier\bin64\amplxe_cpil_2.18.dll Guid: 45e55a89-a7dd-4820-961c-e14c30fa0a48 Size: 0x00000000001e9000 SymbolName: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\build\build_release_win32-x86_64_icl_15.0.221_mstools_12.0\cpil\amplxe_cpil_2.18.pdb Timestamp: 0x000000005a023447 [Module011] Age: 0x0000000000000001 Base: 0x00007fff03470000 Begin: 0x00007fff03471000 End: 0x00007fff03518000 FullName: C:\Program Files (x86)\IntelSWTools\VTune Amplifier\bin64\MSVCR120.dll Guid: 3e4edf77-4220-443e-8524-b0a90dfb7699 Size: 0x00000000000ef000 SymbolName: msvcr120.amd64.pdb Timestamp: 0x00000000524f83ff [Module012] Age: 0x0000000000000001 Base: 0x00007ff75d4b0000 Begin: 0x00007ff75d4b1000 End: 0x00007ff75d9f9000 FullName: C:\Program Files (x86)\IntelSWTools\VTune Amplifier\bin64\amplxe-runss.exe Guid: dcda541e-663d-4755-a0a6-bd6ccf048700 Size: 0x00000000008b5000 SymbolName: C:\bb\INNLphep2w6r\b\b\tmplj_pzx\build\build_release_win32-x86_64_icl_15.0.221_mstools_12.0\perfrun.launcher\amplxe-runss.pdb Timestamp: 0x000000005a0235a6 [Stack.clean.0x000011e8] + | 0x000000faf01ff260 | 0x00007fff3183b62e + | 0x000000faf01ff2e0 | 0x00007ff75d9b14b0 + | 0x000000faf01ffa20 | 0x00007ff75d767e72 + | 0x000000faf01ffb90 | 0x00007fff1d2050de + | 0x000000faf01ffcd0 | 0x00007fff1d204833 + | 0x000000faf01ffd20 | 0x00007fff34f01fe4 + | 0x000000faf01ffd50 | 0x00007fff350eefc1 [Stack.clean.0x000013d8] + | 0x000000faef4fd480 | 0x00007fff317b3b7f + | 0x000000faef4fd520 | 0x00007ff75d5d5f2b + | 0x000000faef4fdbd0 | 0x00007ff75d55af3c + | 0x000000faef4fe060 | 0x00007ff75d4c2f25 + | 0x000000faef4fe5c0 | 0x00007ff75d4cae13 + | 0x000000faef4fe7a0 | 0x00007ff75d4bdf5c + | 0x000000faef4ff850 | 0x00007ff75d4b1214 + | 0x000000faef4ff980 | 0x00007ff75d9f6ebf + | 0x000000faef4ff9b0 | 0x00007fff34f01fe4 + | 0x000000faef4ff9e0 | 0x00007fff350eefc1 [Stack.clean.0x000015d8] + | 0x000000faefbfe890 | 0x00007fff30c09137 + | 0x000000faefbfe930 | 0x00007fff30c11aec + | 0x000000faefbfed40 | 0x00007fff34e9727c + | 0x000000faefbfedc0 | 0x00007fff34e971a2 + | 0x000000faefbfee00 | 0x00007ff75d5bfc12 + | 0x000000faefbff0c0 | 0x00007ff75d5b5998 + | 0x000000faefbff2f0 | 0x00007ff75d5926d0 + | 0x000000faefbff780 | 0x00007ff75d5a86d5 + | 0x000000faefbff7f0 | 0x00007fff1d2050de + | 0x000000faefbff930 | 0x00007fff1d204833 + | 0x000000faefbff980 | 0x00007fff34f01fe4 + | 0x000000faefbff9b0 | 0x00007fff350eefc1 [Stack.clean.0x000017a0] + | 0x000000faf02ffa80 | 0x00007fff317b3b7f + | 0x000000faf02ffb20 | 0x00007ff75d5f8bd1 + | 0x000000faf02ffb50 | 0x00007ff75d5fa47e + | 0x000000faf02ffba0 | 0x00007fff03494f7f + | 0x000000faf02ffbd0 | 0x00007fff03495126 + | 0x000000faf02ffc00 | 0x00007fff34f01fe4 + | 0x000000faf02ffc30 | 0x00007fff350eefc1 [Stack.clean.0x000029cc] + | 0x000000faf00ff230 | 0x00007fff317fa9c6 + | 0x000000faf00ff530 | 0x00007fff3261aa73 + | 0x000000faf00ff7c0 | 0x00007fff3261ce00 + | 0x000000faf00ff810 | 0x00007fff3261a931 + | 0x000000faf00ff870 | 0x00007fff3265157c + | 0x000000faf00ff8a0 | 0x00007fff34f01fe4 + | 0x000000faf00ff8d0 | 0x00007fff350eefc1 [Stack.clean.0x000031ec] + | 0x000000faefcfee40 | 0x00007fff3183b62e + | 0x000000faefcfeec0 | 0x00007ff75d9b14b0 + | 0x000000faefcff600 | 0x00007ff75d9b0315 + | 0x000000faefcfff10 | 0x00007ff75d6ead0b + | 0x000000faefcfff60 | 0x00007fff34f01fe4 + | 0x000000faefcfff90 | 0x00007fff350eefc1 [Stack.clean.0x000032e4] + | 0x000000faf06fe2c0 | 0x00007fff3180f109 + | 0x000000faf06fe330 | 0x00007fff061bbfd6 + | 0x000000faf06ff740 | 0x00007fff1d2050de + | 0x000000faf06ff880 | 0x00007fff1d204833 + | 0x000000faf06ff8d0 | 0x00007fff34f01fe4 + | 0x000000faf06ff900 | 0x00007fff350eefc1 [Stack.clean.0x000033e8] + | 0x000000faefdfdc10 | 0x00007fff04d61986 + | 0x000000faefdfdc40 | 0x00007fff04d613a1 + | 0x000000faefdfdec0 | 0x00007fff042b7799 + | 0x000000faefdfdef0 | 0x00007ff75d7ecd86 + | 0x000000faefdfe230 | 0x00007ff75d7f79d3 + | 0x000000faefdfe5f0 | 0x00007ff75d81d37f + | 0x000000faefdfefd0 | 0x00007ff75d81bae9 + | 0x000000faefdff300 | 0x00007ff75d7c7f97 + | 0x000000faefdff330 | 0x00007fff34653d81 + | 0x000000faefdff410 | 0x00007fff34653169 + | 0x000000faefdff470 | 0x00007fff3465b209 + | 0x000000faefdff4d0 | 0x00007ff75d7c8dd6 + | 0x000000faefdff9d0 | 0x00007ff75d7cb625 + | 0x000000faefdffa00 | 0x00007ff75d7c5405 + | 0x000000faefdffd50 | 0x00007fff1d2050de + | 0x000000faefdffe90 | 0x00007fff1d204833 + | 0x000000faefdffee0 | 0x00007fff34f01fe4 + | 0x000000faefdfff10 | 0x00007fff350eefc1 [Stack.clean.0x00003484] + | 0x000000faefaff2e0 | 0x00007fff317fa9c6 + | 0x000000faefaff5e0 | 0x00007fff317fa8ae + | 0x000000faefaff620 | 0x00007fff1d208c77 + | 0x000000faefaff730 | 0x00007ff75d68dc12 + | 0x000000faefaff7e0 | 0x00007ff75d67ee48 + | 0x000000faefaff8e0 | 0x00007ff75d67e9b3 + | 0x000000faefaffa10 | 0x00007ff75d66f3bd + | 0x000000faefaffa40 | 0x00007fff1d2050de + | 0x000000faefaffb80 | 0x00007fff1d204833 + | 0x000000faefaffbd0 | 0x00007fff34f01fe4 + | 0x000000faefaffc00 | 0x00007fff350eefc1 [Stack.clean.0x000036cc] + | 0x000000faef5ff7e0 | 0x00007fff350b49dd + | 0x000000faef5ffb70 | 0x00007fff34f01fe4 + | 0x000000faef5ffba0 | 0x00007fff350eefc1 [Stack.clean.0x00003798] + | 0x000000faef7ffb00 | 0x00007fff350b49dd + | 0x000000faef7ffe90 | 0x00007fff34f01fe4 + | 0x000000faef7ffec0 | 0x00007fff350eefc1 [Stack.clean.0x00003958] + | 0x000000faf03ff2c0 | 0x00007fff317fd3ce + | 0x000000faf03ff320 | 0x00007ff75d5fc651 + | 0x000000faf03ff430 | 0x00007ff75d5f74a1 + | 0x000000faf03ff620 | 0x00007fff1d2050de + | 0x000000faf03ff760 | 0x00007fff1d204833 + | 0x000000faf03ff7b0 | 0x00007fff34f01fe4 + | 0x000000faf03ff7e0 | 0x00007fff350eefc1 [Stack.clean.0x00004018] + | 0x000000faeffff9d0 | 0x00007fff350b49dd + | 0x000000faeffffd60 | 0x00007fff34f01fe4 + | 0x000000faeffffd90 | 0x00007fff350eefc1 [Stack.clean.0x00004060] + | 0x000000faef9ff730 | 0x00007fff317fa9c6 + | 0x000000faef9ffa30 | 0x00007fff317fa8ae + | 0x000000faef9ffa70 | 0x00007fff1d208c77 + | 0x000000faef9ffb80 | 0x00007fff061d5e12 + | 0x000000faef9ffc30 | 0x00007fff061ae4ca + | 0x000000faef9ffd20 | 0x00007fff1d2050de + | 0x000000faef9ffe60 | 0x00007fff1d204833 + | 0x000000faef9ffeb0 | 0x00007fff34f01fe4 + | 0x000000faef9ffee0 | 0x00007fff350eefc1 [Stack.clean.0x00004098] + | 0x000000faefeff860 | 0x00007fff350b49dd + | 0x000000faefeffbf0 | 0x00007fff34f01fe4 + | 0x000000faefeffc20 | 0x00007fff350eefc1 [Stack.clean.0x00004304] + | 0x000000faef6ff8e0 | 0x00007fff350b49dd + | 0x000000faef6ffc70 | 0x00007fff34f01fe4 + | 0x000000faef6ffca0 | 0x00007fff350eefc1 [Stack.clean.0x0000475c] + | 0x000000faef8fede0 | 0x00007fff317b3b7f + | 0x000000faef8fee80 | 0x00007fff0349b9f8 + | 0x000000faef8fefb0 | 0x00007fff0349ca24 + | 0x000000faef8ff000 | 0x00007fff0349c880 + | 0x000000faef8ff070 | 0x00007fff061b2df3 + | 0x000000faef8ff200 | 0x00007fff061a270e + | 0x000000faef8ff2c0 | 0x00007fff061b8b89 + | 0x000000faef8ff2f0 | 0x00007fff06216f54 + | 0x000000faef8ffa20 | 0x00007fff061adf58 + | 0x000000faef8ffaf0 | 0x00007fff1d2050de + | 0x000000faef8ffc30 | 0x00007fff1d204833 + | 0x000000faef8ffc80 | 0x00007fff34f01fe4 + | 0x000000faef8ffcb0 | 0x00007fff350eefc1 [CreationLog] qfagent_1::processAssertionExceptionWindows : 2018-04-13-12-41-56-766 : Assertion report initialized qfagent_1::processAssertionExceptionWindows : 2018-04-13-12-41-56-771 : Process section is set up in crash report qfagent_1::runAssertionHandling : 2018-04-13-12-41-56-771 : Started assertion handling in crashed thread... qfagent_1::startExecuteMinidumpTaskthread : 2018-04-13-12-41-56-771 : EMT Service started! qfagent_1::runAssertionHandling : 2018-04-13-12-41-56-771 : Set assertion info in report PE qfagent_1::ExecuteMinidumpTaskThread::operator() : 2018-04-13-12-41-56-771 : THE PIPE created e in worker thread... qfagent_1::WindowsHandlerState::run : 2018-04-13-12-41-56-772 : Worker thread took over... qfagent_1::HandlerState::exportCrashInfo : 2018-04-13-12-41-56-772 : Set exception info, thread ID, pid qfagent_1::ProblemReportStorage::addContext : 2018-04-13-12-41-56-772 : Added context for thread: 0x00000000000033e8 qfagent_1::HandlerState::exportCrashInfo : 2018-04-13-12-41-56-772 : Set thread context qfagent_1::HandlerState::exportCrashInfo : 2018-04-13-12-41-56-772 : Set crash dump info qfagent_1::HandlerState::exportCrashInfo : 2018-04-13-12-41-56-775 : Added premortal log qfagent_1::HandlerState::exportCrashInfo : 2018-04-13-12-41-56-775 : Added app property pool qfagent_1::ProblemReportStorage::detectProductInfo : 2018-04-13-12-41-56-775 : Detecting product info qfagent_1::ProblemReportStorage::detectProductInfo : 2018-04-13-12-41-56-775 : failed to derive product info from module map, fallback to cfgmgr API qfagent_1::HandlerState::exportCrashInfo : 2018-04-13-12-41-56-775 : Set failed product info: Intel(R) VTune(TM) Amplifier 2018 Update 1; 535340 minidump : 2018-04-13-12-41-56-775 : invoke out-of-proc handling... feedback-tool : 2018-04-13-12-41-56-858 : took over... wmain : 2018-04-13-12-41-56-859 : Collecting stacks... collectStacks : 2018-04-13-12-41-56-859 : Entered collectStacks : 2018-04-13-12-41-56-871 : Loading module map... collectStacks : 2018-04-13-12-41-56-930 : begin collection stack loop... collectThreadStack : 2018-04-13-12-41-56-932 : Collecting stack for thread: 0x00000000000013d8 qfagent_1::ProblemReportStorage::addContext : 2018-04-13-12-41-56-937 : Added context for thread: 0x00000000000013d8 qfagent_1::ProblemReportStorage::addStack : 2018-04-13-12-41-56-938 : Added clean stack for thread: 0x00000000000013d8 collectThreadStack : 2018-04-13-12-41-56-938 : Collecting stack for thread: 0x00000000000036cc qfagent_1::ProblemReportStorage::addContext : 2018-04-13-12-41-56-939 : Added context for thread: 0x00000000000036cc qfagent_1::ProblemReportStorage::addStack : 2018-04-13-12-41-56-939 : Added clean stack for thread: 0x00000000000036cc collectThreadStack : 2018-04-13-12-41-56-939 : Collecting stack for thread: 0x0000000000004304 qfagent_1::ProblemReportStorage::addContext : 2018-04-13-12-41-56-940 : Added context for thread: 0x0000000000004304 qfagent_1::ProblemReportStorage::addStack : 2018-04-13-12-41-56-940 : Added clean stack for thread: 0x0000000000004304 collectThreadStack : 2018-04-13-12-41-56-941 : Collecting stack for thread: 0x0000000000003798 qfagent_1::ProblemReportStorage::addContext : 2018-04-13-12-41-56-941 : Added context for thread: 0x0000000000003798 qfagent_1::ProblemReportStorage::addStack : 2018-04-13-12-41-56-941 : Added clean stack for thread: 0x0000000000003798 collectThreadStack : 2018-04-13-12-41-56-941 : Collecting stack for thread: 0x000000000000475c qfagent_1::ProblemReportStorage::addContext : 2018-04-13-12-41-56-943 : Added context for thread: 0x000000000000475c qfagent_1::ProblemReportStorage::addStack : 2018-04-13-12-41-56-943 : Added clean stack for thread: 0x000000000000475c collectThreadStack : 2018-04-13-12-41-56-943 : Collecting stack for thread: 0x0000000000004060 qfagent_1::ProblemReportStorage::addContext : 2018-04-13-12-41-56-944 : Added context for thread: 0x0000000000004060 qfagent_1::ProblemReportStorage::addStack : 2018-04-13-12-41-56-945 : Added clean stack for thread: 0x0000000000004060 collectThreadStack : 2018-04-13-12-41-56-945 : Collecting stack for thread: 0x0000000000003484 qfagent_1::ProblemReportStorage::addContext : 2018-04-13-12-41-56-946 : Added context for thread: 0x0000000000003484 qfagent_1::ProblemReportStorage::addStack : 2018-04-13-12-41-56-947 : Added clean stack for thread: 0x0000000000003484 collectThreadStack : 2018-04-13-12-41-56-947 : Collecting stack for thread: 0x00000000000015d8 qfagent_1::ProblemReportStorage::addContext : 2018-04-13-12-41-56-949 : Added context for thread: 0x00000000000015d8 qfagent_1::ProblemReportStorage::addStack : 2018-04-13-12-41-56-950 : Added clean stack for thread: 0x00000000000015d8 collectThreadStack : 2018-04-13-12-41-56-950 : Collecting stack for thread: 0x00000000000031ec qfagent_1::ProblemReportStorage::addContext : 2018-04-13-12-41-56-951 : Added context for thread: 0x00000000000031ec qfagent_1::ProblemReportStorage::addStack : 2018-04-13-12-41-56-952 : Added clean stack for thread: 0x00000000000031ec collectThreadStack : 2018-04-13-12-41-56-952 : Collecting stack for thread: 0x00000000000033e8 qfagent_1::ProblemReportStorage::addStack : 2018-04-13-12-41-56-956 : Added clean stack for thread: 0x00000000000033e8 collectThreadStack : 2018-04-13-12-41-56-956 : Collecting stack for thread: 0x0000000000004098 qfagent_1::ProblemReportStorage::addContext : 2018-04-13-12-41-56-957 : Added context for thread: 0x0000000000004098 qfagent_1::ProblemReportStorage::addStack : 2018-04-13-12-41-56-957 : Added clean stack for thread: 0x0000000000004098 collectThreadStack : 2018-04-13-12-41-56-957 : Collecting stack for thread: 0x0000000000004018 qfagent_1::ProblemReportStorage::addContext : 2018-04-13-12-41-56-958 : Added context for thread: 0x0000000000004018 qfagent_1::ProblemReportStorage::addStack : 2018-04-13-12-41-56-958 : Added clean stack for thread: 0x0000000000004018 collectThreadStack : 2018-04-13-12-41-56-958 : Collecting stack for thread: 0x00000000000029cc qfagent_1::ProblemReportStorage::addContext : 2018-04-13-12-41-56-960 : Added context for thread: 0x00000000000029cc qfagent_1::ProblemReportStorage::addStack : 2018-04-13-12-41-56-960 : Added clean stack for thread: 0x00000000000029cc collectThreadStack : 2018-04-13-12-41-56-960 : Collecting stack for thread: 0x00000000000011e8 qfagent_1::ProblemReportStorage::addContext : 2018-04-13-12-41-56-962 : Added context for thread: 0x00000000000011e8 qfagent_1::ProblemReportStorage::addStack : 2018-04-13-12-41-56-962 : Added clean stack for thread: 0x00000000000011e8 collectThreadStack : 2018-04-13-12-41-56-962 : Collecting stack for thread: 0x00000000000017a0 qfagent_1::ProblemReportStorage::addContext : 2018-04-13-12-41-56-963 : Added context for thread: 0x00000000000017a0 qfagent_1::ProblemReportStorage::addStack : 2018-04-13-12-41-56-963 : Added clean stack for thread: 0x00000000000017a0 collectThreadStack : 2018-04-13-12-41-56-963 : Collecting stack for thread: 0x0000000000003958 qfagent_1::ProblemReportStorage::addContext : 2018-04-13-12-41-56-964 : Added context for thread: 0x0000000000003958 qfagent_1::ProblemReportStorage::addStack : 2018-04-13-12-41-56-965 : Added clean stack for thread: 0x0000000000003958 collectThreadStack : 2018-04-13-12-41-56-965 : Collecting stack for thread: 0x00000000000032e4 qfagent_1::ProblemReportStorage::addContext : 2018-04-13-12-41-56-967 : Added context for thread: 0x00000000000032e4 qfagent_1::ProblemReportStorage::addStack : 2018-04-13-12-41-56-968 : Added clean stack for thread: 0x00000000000032e4 collectStacks : 2018-04-13-12-41-56-969 : end collection stack loop... qfagent_1::ProblemReportStorage::SyncModuleMapWithStackMap : 2018-04-13-12-41-56-969 : Sync-up module map with current stack map qfagent_1::ProblemReportStorage::detectProductInfo : 2018-04-13-12-41-56-970 : Detecting product info collectStacks : 2018-04-13-12-41-56-972 : added product info qfagent_1::ProblemReportStorage::updateModuleMap : 2018-04-13-12-41-56-972 : Updating module map... collectStacks : 2018-04-13-12-41-56-974 : updated module map collectStacks : 2018-04-13-12-41-56-974 : Finished collecting stacks, exit wmain : 2018-04-13-12-41-56-974 : Performing intermediate dump of collected stack data wmain : 2018-04-13-12-41-56-977 : Collecting stacks succeeded wmain : 2018-04-13-12-41-57-23 : Added report GUID and UUID qfagent_1::ProblemReportStorage::updateModuleMap : 2018-04-13-12-41-57-65 : Updating module map... wmain : 2018-04-13-12-41-57-68 : collecting system info... wmain : 2018-04-13-12-41-59-817 : Appending custom sections
