Analyzers
5255 Discussions
Crash when generating report
Jeremy_N_
I just installed VTune and ran into problems right away.
I am using Visual Studio 2012 on a Windows 7 64 bit platform. I followed the steps on the "Getting Started with Intel VTune..." page and configured it for Intel 64 Visual Studio 2012 environment. When I created a new Analysis, I got a popup saying "Fail in NS_NewNativeLocalFile!" It seemed to recover from this error. I tried to run a "Basic Hot Spots" analysis with one of my test applications. It is just an .exe that runs Google Test unit tests. It seemed to run fine and said "Data collection is completed successfully", but when post-processing the results, a popup appeared "Intel VTune Amplifier experienced an unexpected error" with the info below. I then tried running an analysis on a smaller test project, and it hung on "Finalizing Results"/"Saving the result". Perhaps there is some permissions error that is preventing VTune from saving files? I set the output directory to have full read/write permissions but it did not resolve the issue. Any suggestions?
Side note: the error popup explicitly said to email
parallel.studio.support@intel.com, but then I got a reply that I should not use that inbox! That's a bit annoying.
[Exception]
Address: 0x000007fefbf11573
Code: 0x0000000080000003
CrashedPID: 22100
CrashedTID: 26392
Description: EXCEPTION_BREAKPOINT
Module: mozalloc.dll
Product: Intel(R) VTune(TM) Amplifier XE 2016 Update 2
[Process]
Process Name: amplxe-eil-bridge.exe
Virtual Memory Size: 911832K
Working Set Size: 284464K
[Products]
Package ID: N/A
Package Contents: Intel(R) VTune(TM) Amplifier XE 2016 Update 2
Build Number: 444464
[System]
Host Name:                 CHQ3W76JMNELSON
OS Name:                   Microsoft Windows 7 Enterprise
OS Version:                6.1.7601 Service Pack 1 Build 7601
OS Manufacturer:           Microsoft Corporation
OS Configuration:          Member Workstation
OS Build Type:             Multiprocessor Free
Registered Owner:          hdlocal
Registered Organization:
Product ID:                00392-918-5000002-85377
Original Install Date:     10/10/2012, 2:44:39 PM
System Boot Time:          1/19/2016, 6:35:06 AM
System Manufacturer:       Dell Inc.
System Model:              Precision T5600
System Type:               x64-based PC
Processor(s):              2 Processor(s) Installed.
                           [01]: Intel64 Family 6 Model 45 Stepping 7 GenuineIntel ~3101 Mhz
                           [02]: Intel64 Family 6 Model 45 Stepping 7 GenuineIntel ~3101 Mhz
BIOS Version:              Dell Inc. A06, 10/25/2012
Windows Directory:         C:\Windows
System Directory:          C:\Windows\system32
Boot Device:               \Device\HarddiskVolume1
System Locale:             en-us;English (United States)
Input Locale:              en-us;English (United States)
Time Zone:                 (UTC-05:00) Eastern Time (US & Canada)
Total Physical Memory:     32,694 MB
Available Physical Memory: 11,787 MB
Virtual Memory: Max Size:  33,716 MB
Virtual Memory: Available: 15,010 MB
Virtual Memory: In Use:    18,706 MB
Page File Location(s):     C:\pagefile.sys
Domain:                    win.ansys.com
Logon Server:              \\CANDC3
Hotfix(s):                 254 Hotfix(s) Installed.
                           [01]: KB2849697
                           [02]: KB2849696
                           [03]: KB2841134
                           [04]: KB2670838
                           [05]: KB2830477
                           [06]: KB2592687
                           [07]: KB2479943
                           [08]: KB2491683
                           [09]: KB2506014
                           [10]: KB2506212
                           [11]: KB2506928
                           [12]: KB2509553
                           [13]: KB2511455
                           [14]: KB2515325
                           [15]: KB2533552
                           [16]: KB2534111
                           [17]: KB2536275
                           [18]: KB2544893
                           [19]: KB2545698
                           [20]: KB2547666
                           [21]: KB2552343
                           [22]: KB2560656
                           [23]: KB2563227
                           [24]: KB2564958
                           [25]: KB2570947
                           [26]: KB2574819
                           [27]: KB2579686
                           [28]: KB2585542
                           [29]: KB2603229
                           [30]: KB2604115
                           [31]: KB2619339
                           [32]: KB2620704
                           [33]: KB2621440
                           [34]: KB2631813
                           [35]: KB2640148
                           [36]: KB2644615
                           [37]: KB2647753
                           [38]: KB2654428
                           [39]: KB2660075
                           [40]: KB2661254
                           [41]: KB2667402
                           [42]: KB2676562
                           [43]: KB2685811
                           [44]: KB2685813
                           [45]: KB2690533
                           [46]: KB2698365
                           [47]: KB2705219
                           [48]: KB2709715
                           [49]: KB2712808
                           [50]: KB2719857
                           [51]: KB2724197
                           [52]: KB2726535
                           [53]: KB2727528
                           [54]: KB2729094
                           [55]: KB2732059
                           [56]: KB2732487
                           [57]: KB2736422
                           [58]: KB2742599
                           [59]: KB2750841
                           [60]: KB2761217
                           [61]: KB2763523
                           [62]: KB2770660
                           [63]: KB2773072
                           [64]: KB2786081
                           [65]: KB2791765
                           [66]: KB2799494
                           [67]: KB2799926
                           [68]: KB2800095
                           [69]: KB2803821
                           [70]: KB2807986
                           [71]: KB2808679
                           [72]: KB2813170
                           [73]: KB2813347
                           [74]: KB2813430
                           [75]: KB2834140
                           [76]: KB2839894
                           [77]: KB2840631
                           [78]: KB2843630
                           [79]: KB2847927
                           [80]: KB2852386
                           [81]: KB2853952
                           [82]: KB2857650
                           [83]: KB2861698
                           [84]: KB2862152
                           [85]: KB2862330
                           [86]: KB2862335
                           [87]: KB2862973
                           [88]: KB2864202
                           [89]: KB2868038
                           [90]: KB2868116
                           [91]: KB2871997
                           [92]: KB2884256
                           [93]: KB2887069
                           [94]: KB2888049
                           [95]: KB2891804
                           [96]: KB2892074
                           [97]: KB2893294
                           [98]: KB2893519
                           [99]: KB2894844
                           [100]: KB2900986
                           [101]: KB2908783
                           [102]: KB2911501
                           [103]: KB2912390
                           [104]: KB2918077
                           [105]: KB2919469
                           [106]: KB2923545
                           [107]: KB2928562
                           [108]: KB2929733
                           [109]: KB2931356
                           [110]: KB2937610
                           [111]: KB2943357
                           [112]: KB2952664
                           [113]: KB2957189
                           [114]: KB2957509
                           [115]: KB2963952
                           [116]: KB2966583
                           [117]: KB2968294
                           [118]: KB2970228
                           [119]: KB2972100
                           [120]: KB2972211
                           [121]: KB2972280
                           [122]: KB2973112
                           [123]: KB2973201
                           [124]: KB2973351
                           [125]: KB2976627
                           [126]: KB2976897
                           [127]: KB2977292
                           [128]: KB2977728
                           [129]: KB2978120
                           [130]: KB2978742
                           [131]: KB2984972
                           [132]: KB2985461
                           [133]: KB2990214
                           [134]: KB2991963
                           [135]: KB2992611
                           [136]: KB2999226
                           [137]: KB3000483
                           [138]: KB3003743
                           [139]: KB3004361
                           [140]: KB3004375
                           [141]: KB3006121
                           [142]: KB3006137
                           [143]: KB3006625
                           [144]: KB3008923
                           [145]: KB3010788
                           [146]: KB3011780
                           [147]: KB3013531
                           [148]: KB3019215
                           [149]: KB3020338
                           [150]: KB3020369
                           [151]: KB3020370
                           [152]: KB3020388
                           [153]: KB3021674
                           [154]: KB3021917
                           [155]: KB3021952
                           [156]: KB3022345
                           [157]: KB3022777
                           [158]: KB3023215
                           [159]: KB3025390
                           [160]: KB3030377
                           [161]: KB3032655
                           [162]: KB3033889
                           [163]: KB3033890
                           [164]: KB3033929
                           [165]: KB3034196
                           [166]: KB3035126
                           [167]: KB3035132
                           [168]: KB3037574
                           [169]: KB3038314
                           [170]: KB3040272
                           [171]: KB3042058
                           [172]: KB3042553
                           [173]: KB3045685
                           [174]: KB3046017
                           [175]: KB3046269
                           [176]: KB3049563
                           [177]: KB3050265
                           [178]: KB3054476
                           [179]: KB3055642
                           [180]: KB3058515
                           [181]: KB3059317
                           [182]: KB3060716
                           [183]: KB3061518
                           [184]: KB3064209
                           [185]: KB3065822
                           [186]: KB3065987
                           [187]: KB3067903
                           [188]: KB3068708
                           [189]: KB3069392
                           [190]: KB3069762
                           [191]: KB3071756
                           [192]: KB3072305
                           [193]: KB3072630
                           [194]: KB3072633
                           [195]: KB3074543
                           [196]: KB3074886
                           [197]: KB3075226
                           [198]: KB3075249
                           [199]: KB3075516
                           [200]: KB3075851
                           [201]: KB3076949
                           [202]: KB3077715
                           [203]: KB3078071
                           [204]: KB3078601
                           [205]: KB3078667
                           [206]: KB3080079
                           [207]: KB3080149
                           [208]: KB3080446
                           [209]: KB3083324
                           [210]: KB3083710
                           [211]: KB3084135
                           [212]: KB3086255
                           [213]: KB3087038
                           [214]: KB3087039
                           [215]: KB3087918
                           [216]: KB3087985
                           [217]: KB3092601
                           [218]: KB3092627
                           [219]: KB3093513
                           [220]: KB3093983
                           [221]: KB3097877
                           [222]: KB3097966
                           [223]: KB3097989
                           [224]: KB3099862
                           [225]: KB3100213
                           [226]: KB3100773
                           [227]: KB3101722
                           [228]: KB3101746
                           [229]: KB3102429
                           [230]: KB3102810
                           [231]: KB3104002
                           [232]: KB3107998
                           [233]: KB3108371
                           [234]: KB3108381
                           [235]: KB3108664
                           [236]: KB3108669
                           [237]: KB3108670
                           [238]: KB3109094
                           [239]: KB3109103
                           [240]: KB3109560
                           [241]: KB3110329
                           [242]: KB3112148
                           [243]: KB3112343
                           [244]: KB3121212
                           [245]: KB3121461
                           [246
Network Card(s):           3 NIC(s) Installed.
                           [01]: Intel(R) 82579LM Gigabit Network Connection
                                 Connection Name: Local Area Connection
                                 DHCP Enabled:    Yes
                                 DHCP Server:     10.5.200.25
                                 IP address(es)
                                 [01]: 10.5.120.105
                           [02]: Cisco Systems VPN Adapter for 64-bit Windows
                                 Connection Name: Local Area Connection 2
                                 Status:          Hardware not present
                           [03]: Bluetooth Personal Area Network Device
                                 Connection Name: Bluetooth Network Connection 2
                                 Status:          Media disconnected
[ClientInfo]
Open Result Paths: D:\AnsysDev\V171\CodeDV\CADIntegration\ModelRollmarkManager\Tests\EngineTests\My Amplifier XE Results - Ans.ModelManager.Engine.Tests\r001hs\r001hs.amplxe
Report ID: cb217217-dda7-4561-8534-a011a1da625a
UUID: {B34C7E16-C5F4-4F6D-9167-37CDEAFA1763}
[Dump]
Path: C:\Users\jmnelson\AppData\Local\Temp\amplxe-log-jmnelson\2016-02-12-Fri-09-26-44-259.amplxe-eil-bridge.exe\crash.dmp
[PremortalLog]
65687 [26392] ERROR cfgmgr <> - Errors happened during transformation
67190 [26392] ERROR cfgmgr <> - Cannot find context value: gpuDX., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
67198 [26392] ERROR cfgmgr <> - Cannot find context value: systemWideDiskIO., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
67198 [26392] ERROR cfgmgr <> - Cannot find context value: androidBoardPlatform., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
67198 [26392] ERROR cfgmgr <> - Cannot find context value: collectIoWaits., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
67198 [26392] ERROR cfgmgr <> - Cannot find context value: systemWideContextSwitch., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
67199 [26392] ERROR cfgmgr <> - Cannot find context value: androidVersionMajor., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
67230 [26392] ERROR cfgmgr <> - Cannot find context value: gpuDX., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
67319 [26392] ERROR cfgmgr <> - Cannot find context value: gpuDX., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
67326 [26392] ERROR cfgmgr <> - Cannot find context value: systemWideDiskIO., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
67326 [26392] ERROR cfgmgr <> - Cannot find context value: androidBoardPlatform., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
67326 [26392] ERROR cfgmgr <> - Cannot find context value: collectIoWaits., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
67326 [26392] ERROR cfgmgr <> - Cannot find context value: systemWideContextSwitch., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
67327 [26392] ERROR cfgmgr <> - Cannot find context value: androidVersionMajor., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
76609 [26392] ERROR cfgmgr <> - Cannot find context value: gpuDX., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
76682 [7244] ERROR cfgmgr <> - Cannot find context value: systemWideDiskIO., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
76682 [7244] ERROR cfgmgr <> - Cannot find context value: androidBoardPlatform., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
76682 [7244] ERROR cfgmgr <> - Cannot find context value: collectIoWaits., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
76682 [7244] ERROR cfgmgr <> - Cannot find context value: systemWideContextSwitch., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
76683 [7244] ERROR cfgmgr <> - Cannot find context value: androidVersionMajor., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
82762 [7244] ERROR cfgmgr <> - Cannot find context value: gpuDX., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
82767 [7244] ERROR cfgmgr <> - Cannot find context value: systemWideDiskIO., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
82767 [7244] ERROR cfgmgr <> - Cannot find context value: androidBoardPlatform., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
82767 [7244] ERROR cfgmgr <> - Cannot find context value: collectIoWaits., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
82767 [7244] ERROR cfgmgr <> - Cannot find context value: systemWideContextSwitch., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
84965 [7244] ERROR cfgmgr <> - Cannot find context value: gpuDX., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
84972 [7244] ERROR cfgmgr <> - Cannot find context value: gpuDX., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
85042 [5376] ERROR cfgmgr <> - Cannot find context value: gpuPlatformIndex., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
85043 [5376] ERROR cfgmgr <> - Cannot find context value: gpuPlatformIndex., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
85044 [5376] ERROR cfgmgr <> - Cannot find context value: androidBoardPlatform., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
85057 [26204] ERROR cfgmgr <> - Cannot find context value: androidBoardPlatform., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
85064 [14924] ERROR cfgmgr <> - Cannot find context value: gpuFormatVersion., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
86483 [7244] ERROR GEN_HELPERS <> - file != ((HANDLE)(LONG_PTR)-1) 'error::FailedTo.Open.The.File(path.as_string()):D:\AnsysDev\V171\CodeDV\CADIntegration\ModelRollmarkManager\Tests\EngineTests\My Amplifier XE Results - Ans.ModelManager.Engine.Tests\r001hs\sqlite-db\timelinedb\ef3b-5f31-ecbf-a220\aggregated\0'
C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\gen_helpers2\src\core\das\das_io_primitives.cpp(704): gen_helpers2::set_volume_compression
, at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\gen_helpers2\src\core\das\das_io_primitives.cpp:704
86943 [7244] ERROR cfgmgr <> - Cannot find context value: gpuDX., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
86950 [7244] ERROR cfgmgr <> - Cannot find context value: gpuDX., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
87013 [26204] ERROR cfgmgr <> - Cannot find context value: gpuPlatformIndex., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
87013 [26204] ERROR cfgmgr <> - Cannot find context value: androidBoardPlatform., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
87022 [3880] ERROR cfgmgr <> - Cannot find context value: androidBoardPlatform., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
87023 [3880] ERROR cfgmgr <> - Cannot find context value: androidBoardPlatform., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
87024 [3880] ERROR cfgmgr <> - Cannot find context value: androidBoardPlatform., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
87032 [11768] ERROR cfgmgr <> - Cannot find context value: gpuFormatVersion., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
87346 [26392] ERROR cfgmgr <> - Cannot find context value: androidBoardPlatform., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
87354 [26392] ERROR cfgmgr <> - Cannot find context value: gpuPlatformIndex., at file: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\vcs\cfgmgr2\src\rules.cpp:374
[CreationLog]
Crash report initialized
HandlerState::exportCrashInfo: Set exception, thread ID, pid
HandlerState::exportCrashInfo: Set thread context
HandlerState::exportCrashInfo: Set crash dump info
HandlerState::exportCrashInfo: Added premortal log
HandlerState::exportCrashInfo: Added app property pool
[Context.0x000004d0]
EAX: 0x0000000000000000
EBP: 0x0000000003138e20
EBX: 0x0000000000000000
ECX: 0x0000000000000000
EDI: 0x0000000000000000
EDX: 0x0000000000000000
EIP: 0x0000000077bfd9fa
ESI: 0x0000000000000000
ESP: 0x00000000063afcd8
R10: 0x0000000000000000
R11: 0x0000000000000000
R12: 0x0000000000000000
R13: 0x0000000000000000
R14: 0x0000000000000000
R15: 0x0000000000000000
R8: 0x0000000000000000
R9: 0x0000000000000000
[Context.0x00000ad8]
EBP: 0x000000001b5ff770
ESP: 0x000000001b5f4f98
[Context.0x00000ef4]
EBP: 0x0000000003139920
ESP: 0x0000000008abf688
[Context.0x00000f00]
ESP: 0x000000000421fa78
[Context.0x00000f28]
EBP: 0x000000001b09fde0
ESP: 0x000000001b090288
[Context.0x00000f64]
EBP: 0x0000000000000000
ESP: 0x00000000057295f8
[Context.0x00001460]
ESP: 0x000000000611f598
[Context.0x00001500]
EBP: 0x000000000dbefb50
ESP: 0x000000000dbeac78
[Context.0x000015b8]
ESP: 0x0000000005f1f748
[Context.0x00001b84]
EBP: 0x0000000009d1f970
ESP: 0x0000000009d1cff8
[Context.0x00001c4c]
EBP: 0x0000000000000002
EIP: 0x0000000077bfdf6a
ESP: 0x000000000d78f228
[Context.0x00001f28]
ESP: 0x000000000461f7a8
[Context.0x00001f80]
ESP: 0x000000000475f698
[Context.0x00002104]
ESP: 0x00000000035bf688
[Context.0x0000232c]
ESP: 0x0000000005a3faa8
[Context.0x00002420]
EBP: 0x000000001d50fd90
ESP: 0x000000001d503068
[Context.0x00002474]
EBP: 0x0000000002f4c170
EIP: 0x0000000077bfda1a
ESP: 0x0000000002f4c078
[Context.0x00002ae4]
ESP: 0x0000000005d4f8b8
[Context.0x00002b74]
EBP: 0x0000000015f0f8e0
ESP: 0x0000000015f0d838
[Context.0x00002d70]
EBP: 0x00000000193efb40
ESP: 0x00000000193e9e28
[Context.0x00002df8]
EBP: 0x000000001bb1fcd0
ESP: 0x000000001bb19168
[Context.0x00002ea0]
ESP: 0x00000000058af6e8
[Context.0x000030b4]
ESP: 0x000000000644f8a8
[Context.0x0000336c]
EIP: 0x0000000077bff2ba
ESP: 0x000000000c1cf678
[Context.0x000033e8]
EBP: 0x000000001bf9fdc0
ESP: 0x000000001bf9cec8
[Context.0x0000342c]
ESP: 0x0000000005b9f628
[Context.0x00003450]
EBP: 0x000000001c0ae4c0
EIP: 0x0000000077bfdd4a
ESP: 0x000000001c0ae408
[Context.0x000035f0]
ESP: 0x000000000c57f4c8
[Context.0x000037d0]
EBP: 0x000000002059fce0
ESP: 0x000000002059e4f8
[Context.0x000037f8]
EBP: 0x0000000015affd00
ESP: 0x0000000015af6378
[Context.0x00003804]
ESP: 0x000000000458f4c8
[Context.0x00003950]
EBP: 0x000000001c4bf6d0
ESP: 0x000000001c4bed38
[Context.0x00003968]
ESP: 0x0000000006b5f848
[Context.0x00003a4c]
EBP: 0x000000001561f7a0
ESP: 0x00000000156121a8
[Context.0x00003c98]
EBP: 0x000000001cfef710
ESP: 0x000000001cfe40f8
[Context.0x00003db0]
EBP: 0x000000001caaf750
ESP: 0x000000001caa04c8
[Context.0x00003f60]
ESP: 0x00000000039ef8d8
[Context.0x00004034]
ESP: 0x00000000055ef688
[Context.0x000040cc]
ESP: 0x00000000038af0f8
[Context.0x00004210]
EBP: 0x000000001e91fbb0
ESP: 0x000000001e91be78
[Context.0x00004510]
EBP: 0x000000001f13fb50
ESP: 0x000000001f131fd8
[Context.0x00004658]
EBP: 0x000000001277fdc0
ESP: 0x000000001277eb58
[Context.0x000047a0]
EIP: 0x0000000077bfda4a
ESP: 0x000000000445f9c8
[Context.0x000047f8]
ESP: 0x000000000669f8c8
[Context.0x00004a28]
ESP: 0x00000000065ff8f8
[Context.0x00004a2c]
ESP: 0x000000000686f718
[Context.0x00004b5c]
ESP: 0x000000000609f938
[Context.0x00004ce4]
ESP: 0x00000000061cf908
[Context.0x00004d24]
ESP: 0x000000000625fc28
[Context.0x00004d28]
EBP: 0x000000001df0fae0
ESP: 0x000000001df0a688
[Context.0x00004d64]
EBP: 0x000000001982fb20
ESP: 0x000000001982c358
[Context.0x00004f24]
ESP: 0x00000000067cf8a8
[Context.0x00004f8c]
EBP: 0x000000001ed2f990
ESP: 0x000000001ed25a88
[Context.0x0000500c]
ESP: 0x000000000ddef648
[Context.0x0000528c]
EBP: 0x000000001fa2fc30
ESP: 0x000000001fa217f8
[Context.0x00005458]
EBP: 0x0000000003d174d0
ESP: 0x0000000008caf7b8
[Context.0x00005484]
ESP: 0x000000000419f8e8
[Context.0x0000551c]
EBP: 0x0000000012fff760
ESP: 0x0000000012ff46c8
[Context.0x00005544]
EBP: 0x000000001216f920
ESP: 0x0000000012163a38
[Context.0x000055dc]
ESP: 0x0000000006c5f5c8
[Context.0x00005608]
EBP: 0x000000000353ed09
ESP: 0x000000000353eb98
[Context.0x00005704]
ESP: 0x00000000069bf6d8
[Context.0x00005744]
ESP: 0x000000000690f9e8
[Context.0x00005760]
ESP: 0x000000000c35f888
[Context.0x0000576c]
EBP: 0x000000000982f920
ESP: 0x0000000009826dd8
[Context.0x00005788]
ESP: 0x000000000656f6f8
[Context.0x000057a0]
ESP: 0x00000000054df688
[Context.0x00005894]
ESP: 0x0000000005e5f618
[Context.0x00005944]
EBP: 0x000000000432f350
ESP: 0x000000000432f278
[Context.0x0000595c]
ESP: 0x000000000340f7e8
[Context.0x000059bc]
EBP: 0x000000001f62f770
ESP: 0x000000001f62b168
[Context.0x00005ca0]
ESP: 0x000000000632fd08
[Context.0x00005d20]
EBP: 0x0000000012baf740
ESP: 0x0000000012ba0a38
[Context.0x00005de8]
ESP: 0x000000000379fb88
[Context.0x00005e1c]
ESP: 0x00000000046bfbb8
[Context.0x00005eb0]
EBP: 0x00000000ffffffff
ESP: 0x000000000492f9d8
[Context.0x0000609c]
ESP: 0x0000000005acf5f8
[Context.0x0000613c]
ESP: 0x00000000064df838
[Context.0x0000614c]
EBP: 0x000000001ffdf6e0
ESP: 0x000000001ffd7468
[Context.0x00006174]
EBP: 0x0000000003d15ed0
ESP: 0x0000000007e6fb28
[Context.0x00006214]
ESP: 0x000000000580f5b8
[Context.0x00006248]
EBP: 0x000000001e3efbc0
ESP: 0x000000001e3e8218
[Context.0x000062bc]
EBP: 0x000000001ac6f780
ESP: 0x000000001ac68358
[Context.0x00006348]
ESP: 0x000000000673fa78
[Context.0x0000665c]
EBP: 0x000000001d97fa30
ESP: 0x000000001d976978
[Context.0x000066f4]
ESP: 0x0000000005dcfb28
[Context.0x00006718]
EBP: 0x000000000022a600
EBX: 0x000000000022a560
ECX: 0x000007fee9050678
EDI: 0x0000000000000087
EDX: 0x0000000000000002
EIP: 0x000007fefbf11573
ESI: 0x00000000ffffffff
ESP: 0x000000000022a4d0
R10: 0x000007fee904c270
R11: 0x0000000000000246
R13: 0x000007fecdbbe594
R15: 0x000007fecf4f32b8
R8: 0x000007fee90519b0
R9: 0x0000000000000008
[Module000]
Age: 0x0000000000000002
Base: 0x000007feff9e0000
Begin: 0x000007feff9e1000
End: 0x000007feffa11000
FullName: C:\Windows\system32\WS2_32.dll
Guid: 348be7d2-2346-495b-841b-7fa203996bd0
SymbolName: ws2_32.pdb
Timestamp: 0x000000004ce7ca25
[Module001]
Base: 0x000007fefda20000
Begin: 0x000007fefda21000
End: 0x000007fefda6b000
FullName: C:\Windows\system32\KERNELBASE.dll
Guid: 4e29414c-c7cf-41a7-91c2-a0f24af10f3c
SymbolName: kernelbase.pdb
Timestamp: 0x00000000568429dd
[Module002]
Base: 0x000007fefd0f0000
Begin: 0x000007fefd0f1000
End: 0x000007fefd134000
FullName: C:\Windows\system32\mswsock.dll
Guid: 1d73630d-03bc-4818-b6c0-76dd90aff58e
SymbolName: mswsock.pdb
Timestamp: 0x00000000522be0b3
[Module003]
Age: 0x0000000000000001
Base: 0x000007fefbf10000
Begin: 0x000007fefbf11000
End: 0x000007fefbf13000
FullName: C:\Program Files (x86)\IntelSWTools\VTune Amplifier XE 2016\bin64\mozalloc.dll
Guid: d8c9543a-0198-4105-93bb-be3408e7f254
SymbolName: c:\gecko34\release64\memory\mozalloc\mozalloc.pdb
Timestamp: 0x000000005540ee9b
[Module004]
Base: 0x000007fefb410000
Begin: 0x000007fefb411000
End: 0x000007fefb5f8000
FullName: C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.19061_none_2b299db671e86e03\gdiplus.dll
Guid: 1268357c-628e-4cfc-a9d7-57a0670ca9da
SymbolName: MicrosoftWindowsGdiPlus-1.1.7601.19061-gdiplus.pdb
Timestamp: 0x0000000056423b4a
[Module005]
Base: 0x000007feeb490000
Begin: 0x000007feeb491000
End: 0x000007feeb4b6000
FullName: C:\Program Files (x86)\IntelSWTools\VTune Amplifier XE 2016\bin64\amplxe_boost_thread_1.55.dll
Guid: 3418872b-7d30-41ea-add3-dc60c006e4a2
SymbolName: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\build\build_release_win32-x86_64_icl_15.0.221_mstools_12.0\boost\boost_1.55.0\boost.thread\amplxe_boost_thread_1.55.pdb
Timestamp: 0x00000000567883b5
[Module006]
Base: 0x000007fee9f30000
Begin: 0x000007fee9f31000
End: 0x000007fee9f41000
FullName: C:\Program Files (x86)\IntelSWTools\VTune Amplifier XE 2016\bin64\amplxe_xulrunnerwxadapter_1.3.dll
Guid: f1fae13c-83bf-4624-a52d-f30fdef92601
SymbolName: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\build\build_release_win32-x86_64_icl_15.0.221_mstools_12.0\xulrunnerwxadapter\amplxe_xulrunnerwxadapter_1.3.pdb
Timestamp: 0x0000000056789011
[Module007]
Base: 0x000007fee8f70000
Begin: 0x000007fee8f71000
End: 0x000007fee9018000
FullName: C:\Program Files (x86)\IntelSWTools\VTune Amplifier XE 2016\bin64\MSVCR120.dll
Guid: 3e4edf77-4220-443e-8524-b0a90dfb7699
SymbolName: msvcr120.amd64.pdb
Timestamp: 0x00000000524f83ff
[Module008]
Base: 0x000007fee04c0000
Begin: 0x000007fee04c1000
End: 0x000007fee0513000
FullName: C:\Program Files (x86)\IntelSWTools\VTune Amplifier XE 2016\bin64\amplxe_tbb.dll
Guid: ee39fea0-c4e9-4074-a266-d8b92fd10a30
SymbolName: c:\TEMP\tbb.2015_01_22T00_34_13+0400nntpat21-48_2\build\nntpat21-48_2icc14_64_vc10_mt_release\tbb.pdb
Timestamp: 0x0000000054c017c1
[Module009]
Base: 0x000007fedea10000
Begin: 0x000007fedea11000
End: 0x000007fedea86000
FullName: C:\Program Files (x86)\IntelSWTools\VTune Amplifier XE 2016\bin64\amplxe_htmlui_1.6.dll
Guid: e275187b-c7ab-4007-9650-2efd312852c7
SymbolName: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\build\build_release_win32-x86_64_icl_15.0.221_mstools_12.0\htmlui.util\amplxe_htmlui_1.6.pdb
Timestamp: 0x00000000567886ab
[Module010]
Base: 0x000007fed9700000
Begin: 0x000007fed9701000
End: 0x000007fed9933000
FullName: C:\Program Files (x86)\IntelSWTools\VTune Amplifier XE 2016\bin64\amplxe_gen_helpers_core_2.29.dll
Guid: 4636a605-b81d-47b5-891e-943eafd6936c
SymbolName: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\build\build_release_win32-x86_64_icl_15.0.221_mstools_12.0\gen_helpers.core\amplxe_gen_helpers_core_2.29.pdb
Timestamp: 0x0000000056788400
[Module011]
Base: 0x000007fed92f0000
Begin: 0x000007fed92f1000
End: 0x000007fed9519000
FullName: C:\Program Files (x86)\IntelSWTools\VTune Amplifier XE 2016\bin64\amplxe_wx_helpers_core_1.28.dll
Guid: 39bea943-1952-4d45-b418-905aa8bda287
SymbolName: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\build\build_release_win32-x86_64_icl_15.0.221_mstools_12.0\wx_helpers.core\amplxe_wx_helpers_core_1.28.pdb
Timestamp: 0x000000005678900d
[Module012]
Age: 0x00000000000001c7
Base: 0x000007fed85d0000
Begin: 0x000007fed85d1000
End: 0x000007fed8c85000
FullName: C:\Program Files (x86)\IntelSWTools\VTune Amplifier XE 2016\bin64\wxmsw28u_vc_amplxe_2.8.1226.dll
Guid: 03e82f80-d66b-4ab8-be5a-8538e45ff4fa
SymbolName: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\build\build_release_win32-x86_64_icl_15.0.221_mstools_12.0\wxwidgets\wxWidgets-2.8.12\lib\vc_dll\wxmsw28u_vc_amplxe_2.8.1226.pdb
Timestamp: 0x0000000056788fab
[Module013]
Base: 0x000007fed7e70000
Begin: 0x000007fed7e71000
End: 0x000007fed7fe2000
FullName: C:\Program Files (x86)\IntelSWTools\VTune Amplifier XE 2016\bin64\amplxe_abclient_1.29.dll
Guid: aa5c7314-dab1-4168-b948-c6f5771ad1a6
SymbolName: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\build\build_release_win32-x86_64_icl_15.0.221_mstools_12.0\abclient.core\amplxe_abclient_1.29.pdb
Timestamp: 0x0000000056789026
[Module014]
Base: 0x000007fed7d40000
Begin: 0x000007fed7d41000
End: 0x000007fed7deb000
FullName: C:\Program Files (x86)\IntelSWTools\VTune Amplifier XE 2016\bin64\amplxe_qfagentminidump_core_1.18.dll
Guid: b8de34cd-789c-4184-9fbc-200e5d24f898
SymbolName: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\build\build_release_win32-x86_64_icl_15.0.221_mstools_12.0\qfagentminidump.core\amplxe_qfagentminidump_core_1.18.pdb
Timestamp: 0x000000005678869c
[Module015]
Base: 0x000007fed6a00000
Begin: 0x000007fed6a01000
End: 0x000007fed6c07000
FullName: C:\Program Files (x86)\IntelSWTools\VTune Amplifier XE 2016\bin64\amplxe_client_1.6.dll
Guid: 37954591-7d3b-48f0-b32b-f72f12d27c25
SymbolName: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\build\build_release_win32-x86_64_icl_15.0.221_mstools_12.0\perfclient.core\amplxe_client_1.6.pdb
Timestamp: 0x000000005678902d
[Module016]
Base: 0x000007fed0d10000
Begin: 0x000007fed0d11000
End: 0x000007fed0db8000
FullName: C:\Program Files (x86)\IntelSWTools\VTune Amplifier XE 2016\bin64\amplxe_htmlpane_1.9.dll
Guid: 4c3c5439-f575-4c49-bbef-6419611b8bd8
SymbolName: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\build\build_release_win32-x86_64_icl_15.0.221_mstools_12.0\htmlpane\amplxe_htmlpane_1.9.pdb
Timestamp: 0x0000000056789017
[Module017]
Base: 0x000007fed0520000
Begin: 0x000007fed0521000
End: 0x000007fed0691000
FullName: C:\Program Files (x86)\IntelSWTools\VTune Amplifier XE 2016\bin64\nss3.dll
Guid: 73b90bc0-243e-4270-b90d-76525856917c
SymbolName: c:\gecko34\release64\config\external\nss\nss3.pdb
Timestamp: 0x000000005540eebe
[Module018]
Base: 0x000007fed0070000
Begin: 0x000007fed0071000
End: 0x000007fed0412000
FullName: C:\Program Files (x86)\IntelSWTools\VTune Amplifier XE 2016\bin64\mozjs.dll
Guid: 6d7b7ba7-e415-45e3-a703-638cafebde7a
SymbolName: c:\gecko34\release64\js\src\mozjs.pdb
Timestamp: 0x000000005540ef63
[Module019]
Age: 0x0000000000000005
Base: 0x000007fecdb40000
Begin: 0x000007fecdb41000
End: 0x000007fecf0a2000
FullName: C:\Program Files (x86)\IntelSWTools\VTune Amplifier XE 2016\bin64\xul.dll
Guid: fc5d10c3-ba69-46d2-8ce7-4a3a0311a065
SymbolName: c:\gecko34\release64\toolkit\library\xul.pdb
Timestamp: 0x000000005604fd27
[Module020]
Base: 0x000000013fa80000
Begin: 0x000000013fa81000
End: 0x000000013fa9e000
FullName: C:\Program Files (x86)\IntelSWTools\VTune Amplifier XE 2016\bin64\amplxe-eil-bridge.exe
Guid: a7a4148e-ae03-44c6-b096-693df87398be
SymbolName: C:\bb\INNLphep2w6r\b\b\tmp6phjd4\build\build_release_win32-x86_64_icl_15.0.221_mstools_12.0\eil.bridge\amplxe-eil-bridge.pdb
Timestamp: 0x0000000056789024
[Module021]
Base: 0x0000000077bb0000
Begin: 0x0000000077bb1000
End: 0x0000000077caf000
FullName: C:\Windows\SYSTEM32\ntdll.dll
Guid: 951f2888-bfa8-4f68-bac2-893170810edb
SymbolName: ntdll.pdb
Timestamp: 0x00000000568429e5
[Module022]
Base: 0x0000000077ab0000
Begin: 0x0000000077ab1000
End: 0x0000000077b32000
FullName: C:\Windows\system32\USER32.dll
Guid: 270f670f-42e9-4eec-8208-ea4e019cdfe4
SymbolName: user32.pdb
Timestamp: 0x0000000056423d2a
[Module023]
Base: 0x0000000077990000
Begin: 0x0000000077991000
End: 0x0000000077a2c000
FullName: C:\Windows\system32\kernel32.dll
Guid: 2955e75d-f328-48d4-8f29-ca500baf1bd3
SymbolName: kernel32.pdb
Timestamp: 0x00000000568429dc
[Stack.clean.0x000004d0]
+ | 0x00000000063afce0 | 0x000007fefda210dc
+ | 0x00000000063afd80 | 0x000007fed067be18
+ | 0x00000000063afdb0 | 0x000007fed068c9a6
+ | 0x00000000063afde0 | 0x000007fed03aa32a
+ | 0x00000000063afe10 | 0x000007fed068e2cf
+ | 0x00000000063afe40 | 0x000007fed067f1aa
+ | 0x00000000063afe70 | 0x000007fee8f94f7f
+ | 0x00000000063afea0 | 0x000007fee8f95126
+ | 0x00000000063afed0 | 0x00000000779a59ed
+ | 0x00000000063aff00 | 0x0000000077bdb831
[Stack.clean.0x00000ad8]
+ | 0x000000001b5f4fa0 | 0x000007fefda210dc
+ | 0x000000001b5f5040 | 0x000007fee04d4614
+ | 0x000000001b5ff7d0 | 0x000007fee04ecebb
+ | 0x000000001b5ff800 | 0x000007fee04ecf4f
+ | 0x000000001b5ff830 | 0x00000000779a59ed
+ | 0x000000001b5ff860 | 0x0000000077bdb831
[Stack.clean.0x00000ef4]
+ | 0x0000000008abf690 | 0x000007fefda210dc
+ | 0x0000000008abf730 | 0x000007fed067be18
+ | 0x0000000008abf760 | 0x000007fed068c9a6
+ | 0x0000000008abf790 | 0x000007fecdbf7ae0
+ | 0x0000000008abf810 | 0x000007fecdbf9f57
+ | 0x0000000008abf9e0 | 0x000007fecdc0f8cf
+ | 0x0000000008abfa10 | 0x000007fecddd86cf
+ | 0x0000000008abfa60 | 0x000007fecddc7829
+ | 0x0000000008abfa90 | 0x000007fecddc77c2
+ | 0x0000000008abfae0 | 0x000007fecdbfa810
+ | 0x0000000008abfb10 | 0x000007fed068e2cf
+ | 0x0000000008abfb40 | 0x000007fed067f1aa
+ | 0x0000000008abfb70 | 0x000007fee8f94f7f
+ | 0x0000000008abfba0 | 0x000007fee8f95126
+ | 0x0000000008abfbd0 | 0x00000000779a59ed
+ | 0x0000000008abfc00 | 0x0000000077bdb831
[Stack.clean.0x00000f00]
+ | 0x000000000421fa80 | 0x000007fefda210dc
+ | 0x000000000421fb20 | 0x000007fed067be18
+ | 0x000000000421fb50 | 0x000007fed068c9a6
+ | 0x000000000421fb80 | 0x000007fed03aa32a
+ | 0x000000000421fbb0 | 0x000007fed068e2cf
+ | 0x000000000421fbe0 | 0x000007fed067f1aa
+ | 0x000000000421fc10 | 0x000007fee8f94f7f
+ | 0x000000000421fc40 | 0x000007fee8f95126
+ | 0x000000000421fc70 | 0x00000000779a59ed
+ | 0x000000000421fca0 | 0x0000000077bdb831
[Stack.clean.0x00000f28]
+ | 0x000000001b090290 | 0x000007fefda210dc
+ | 0x000000001b090330 | 0x000007fee04d4614
+ | 0x000000001b09fe40 | 0x000007fee04ecebb
+ | 0x000000001b09fe70 | 0x000007fee04ecf4f
+ | 0x000000001b09fea0 | 0x00000000779a59ed
+ | 0x000000001b09fed0 | 0x0000000077bdb831
[Stack.clean.0x00000f64]
+ | 0x0000000005729600 | 0x000007fefd100f75
+ | 0x0000000005729680 | 0x000007fefd101057
+ | 0x0000000005729820 | 0x000007feff9e4efc
+ | 0x0000000005729860 | 0x000007feff9e4e7d
+ | 0x0000000005729960 | 0x000007fed067b1e1
+ | 0x000000000572fa40 | 0x000007fecdc3a184
+ | 0x000000000572fa70 | 0x000007fecdc397c7
+ | 0x000000000572fad0 | 0x000007fecdc3a7e8
+ | 0x000000000572fb20 | 0x000007fecdbf9f57
+ | 0x000000000572fcf0 | 0x000007fecdc0f8cf
+ | 0x000000000572fd20 | 0x000007fecddd86cf
+ | 0x000000000572fd70 | 0x000007fecddc7829
+ | 0x000000000572fda0 | 0x000007fecddc77c2
+ | 0x000000000572fdf0 | 0x000007fecdbfa810
+ | 0x000000000572fe20 | 0x000007fed068e2cf
+ | 0x000000000572fe50 | 0x000007fed067f1aa
+ | 0x000000000572fe80 | 0x000007fee8f94f7f
+ | 0x000000000572feb0 | 0x000007fee8f95126
+ | 0x000000000572fee0 | 0x00000000779a59ed
+ | 0x000000000572ff10 | 0x0000000077bdb831
[Stack.clean.0x00001460]
+ | 0x000000000611f5a0 | 0x000007fefda210dc
+ | 0x000000000611f640 | 0x000007fed067be18
+ | 0x000000000611f670 | 0x000007fed068c9a6
+ | 0x000000000611f6a0 | 0x000007fed03aa32a
+ | 0x000000000611f6d0 | 0x000007fed068e2cf
+ | 0x000000000611f700 | 0x000007fed067f1aa
+ | 0x000000000611f730 | 0x000007fee8f94f7f
+ | 0x000000000611f760 | 0x000007fee8f95126
+ | 0x000000000611f790 | 0x00000000779a59ed
+ | 0x000000000611f7c0 | 0x0000000077bdb831
[Stack.clean.0x00001500]
+ | 0x000000000dbeac80 | 0x000007fefda210dc
+ | 0x000000000dbead20 | 0x000007fee04d4614
+ | 0x000000000dbefbb0 | 0x000007fee04ecebb
+ | 0x000000000dbefbe0 | 0x000007fee04ecf4f
+ | 0x000000000dbefc10 | 0x00000000779a59ed
+ | 0x000000000dbefc40 | 0x0000000077bdb831
[Stack.clean.0x000015b8]
+ | 0x0000000005f1f750 | 0x000007fefda210dc
+ | 0x0000000005f1f7f0 | 0x000007fed067be18
+ | 0x0000000005f1f820 | 0x000007fed068c9a6
+ | 0x0000000005f1f850 | 0x000007fed03aa32a
+ | 0x0000000005f1f880 | 0x000007fed068e2cf
+ | 0x0000000005f1f8b0 | 0x000007fed067f1aa
+ | 0x0000000005f1f8e0 | 0x000007fee8f94f7f
+ | 0x0000000005f1f910 | 0x000007fee8f95126
+ | 0x0000000005f1f940 | 0x00000000779a59ed
+ | 0x0000000005f1f970 | 0x0000000077bdb831
[Stack.clean.0x00001b84]
+ | 0x0000000009d1d000 | 0x000007fefda210dc
+ | 0x0000000009d1d0a0 | 0x000007fee04d4614
+ | 0x0000000009d1f9d0 | 0x000007fee04ecebb
+ | 0x0000000009d1fa00 | 0x000007fee04ecf4f
+ | 0x0000000009d1fa30 | 0x00000000779a59ed
+ | 0x0000000009d1fa60 | 0x0000000077bdb831
[Stack.clean.0x00001c4c]
+ | 0x000000000d78f230 | 0x000007fefda21430
+ | 0x000000000d78f330 | 0x00000000779a06e0
+ | 0x000000000d78f3c0 | 0x000007feeb498c77
+ | 0x000000000d78f4d0 | 0x000007fed98f5d12
+ | 0x000000000d78f580 | 0x000007fed9906121
+ | 0x000000000d78fa50 | 0x000007fed99059f2
+ | 0x000000000d78fb00 | 0x000007fed9907816
+ | 0x000000000d78fb90 | 0x000007fed9909f0b
+ | 0x000000000d78fbe0 | 0x000007feeb4950de
+ | 0x000000000d78fd20 | 0x000007feeb494833
+ | 0x000000000d78fd70 | 0x00000000779a59ed
+ | 0x000000000d78fda0 | 0x0000000077bdb831
[Stack.clean.0x00001f28]
+ | 0x000000000461f7b0 | 0x000007fefda210dc
+ | 0x000000000461f850 | 0x000007fed067be18
+ | 0x000000000461f880 | 0x000007fed068c9a6
+ | 0x000000000461f8b0 | 0x000007fed03aa32a
+ | 0x000000000461f8e0 | 0x000007fed068e2cf
+ | 0x000000000461f910 | 0x000007fed067f1aa
+ | 0x000000000461f940 | 0x000007fee8f94f7f
+ | 0x000000000461f970 | 0x000007fee8f95126
+ | 0x000000000461f9a0 | 0x00000000779a59ed
+ | 0x000000000461f9d0 | 0x0000000077bdb831
[Stack.clean.0x00001f80]
+ | 0x000000000475f6a0 | 0x000007fefda210dc
+ | 0x000000000475f740 | 0x000007fed067be18
+ | 0x000000000475f770 | 0x000007fed068c9a6
+ | 0x000000000475f7a0 | 0x000007fed03aa32a
+ | 0x000000000475f7d0 | 0x000007fed068e2cf
+ | 0x000000000475f800 | 0x000007fed067f1aa
+ | 0x000000000475f830 | 0x000007fee8f94f7f
+ | 0x000000000475f860 | 0x000007fee8f95126
+ | 0x000000000475f890 | 0x00000000779a59ed
+ | 0x000000000475f8c0 | 0x0000000077bdb831
[Stack.clean.0x00002104]
+ | 0x00000000035bf690 | 0x000007fefda210dc
+ | 0x00000000035bf730 | 0x000007fed067be18
+ | 0x00000000035bf760 | 0x000007fed068c9a6
+ | 0x00000000035bf790 | 0x000007fed03aa32a
+ | 0x00000000035bf7c0 | 0x000007fed068e2cf
+ | 0x00000000035bf7f0 | 0x000007fed067f1aa
+ | 0x00000000035bf820 | 0x000007fee8f94f7f
+ | 0x00000000035bf850 | 0x000007fee8f95126
+ | 0x00000000035bf880 | 0x00000000779a59ed
+ | 0x00000000035bf8b0 | 0x0000000077bdb831
[Stack.clean.0x0000232c]
+ | 0x0000000005a3fab0 | 0x000007fefda210dc
+ | 0x0000000005a3fb50 | 0x000007fed067be18
+ | 0x0000000005a3fb80 | 0x000007fed068c9a6
+ | 0x0000000005a3fbb0 | 0x000007fed03aa32a
+ | 0x0000000005a3fbe0 | 0x000007fed068e2cf
+ | 0x0000000005a3fc10 | 0x000007fed067f1aa
+ | 0x0000000005a3fc40 | 0x000007fee8f94f7f
+ | 0x0000000005a3fc70 | 0x000007fee8f95126
+ | 0x0000000005a3fca0 | 0x00000000779a59ed
+ | 0x0000000005a3fcd0 | 0x0000000077bdb831
[Stack.clean.0x00002420]
+ | 0x000000001d503070 | 0x000007fefda210dc
+ | 0x000000001d503110 | 0x000007fee04d4614
+ | 0x000000001d50fdf0 | 0x000007fee04ecebb
+ | 0x000000001d50fe20 | 0x000007fee04ecf4f
+ | 0x000000001d50fe50 | 0x00000000779a59ed
+ | 0x000000001d50fe80 | 0x0000000077bdb831
[Stack.clean.0x00002474]
+ | 0x0000000002f4c080 | 0x000007fefda21a7a
+ | 0x0000000002f4c100 | 0x00000000779a0a19
+ | 0x0000000002f4c140 | 0x000000013fa871ef
+ | 0x0000000002f4f920 | 0x000007fee8f94f7f
+ | 0x0000000002f4f950 | 0x000007fee8f95126
+ | 0x0000000002f4f980 | 0x00000000779a59ed
+ | 0x0000000002f4f9b0 | 0x0000000077bdb831
[Stack.clean.0x00002ae4]
+ | 0x0000000005d4f8c0 | 0x000007fefda210dc
+ | 0x0000000005d4f960 | 0x000007fed067be18
+ | 0x0000000005d4f990 | 0x000007fed068c9a6
+ | 0x0000000005d4f9c0 | 0x000007fed03aa32a
+ | 0x0000000005d4f9f0 | 0x000007fed068e2cf
+ | 0x0000000005d4fa20 | 0x000007fed067f1aa
+ | 0x0000000005d4fa50 | 0x000007fee8f94f7f
+ | 0x0000000005d4fa80 | 0x000007fee8f95126
+ | 0x0000000005d4fab0 | 0x00000000779a59ed
+ | 0x0000000005d4fae0 | 0x0000000077bdb831
[Stack.clean.0x00002b74]
+ | 0x0000000015f0d840 | 0x000007fefda210dc
+ | 0x0000000015f0d8e0 | 0x000007fee04d4614
+ | 0x0000000015f0f940 | 0x000007fee04ecebb
+ | 0x0000000015f0f970 | 0x000007fee04ecf4f
+ | 0x0000000015f0f9a0 | 0x00000000779a59ed
+ | 0x0000000015f0f9d0 | 0x0000000077bdb831
[Stack.clean.0x00002d70]
+ | 0x00000000193e9e30 | 0x000007fefda210dc
+ | 0x00000000193e9ed0 | 0x000007fee04d4614
+ | 0x00000000193efba0 | 0x000007fee04ecebb
+ | 0x00000000193efbd0 | 0x000007fee04ecf4f
+ | 0x00000000193efc00 | 0x00000000779a59ed
+ | 0x00000000193efc30 | 0x0000000077bdb831
[Stack.clean.0x00002df8]
+ | 0x000000001bb19170 | 0x000007fefda210dc
+ | 0x000000001bb19210 | 0x000007fee04d4614
+ | 0x000000001bb1fd30 | 0x000007fee04ecebb
+ | 0x000000001bb1fd60 | 0x000007fee04ecf4f
+ | 0x000000001bb1fd90 | 0x00000000779a59ed
+ | 0x000000001bb1fdc0 | 0x0000000077bdb831
[Stack.clean.0x00002ea0]
+ | 0x00000000058af6f0 | 0x000007fefda210dc
+ | 0x00000000058af790 | 0x000007fed067be18
+ | 0x00000000058af7c0 | 0x000007fed068c9a6
+ | 0x00000000058af7f0 | 0x000007fed03aa32a
+ | 0x00000000058af820 | 0x000007fed068e2cf
+ | 0x00000000058af850 | 0x000007fed067f1aa
+ | 0x00000000058af880 | 0x000007fee8f94f7f
+ | 0x00000000058af8b0 | 0x000007fee8f95126
+ | 0x00000000058af8e0 | 0x00000000779a59ed
+ | 0x00000000058af910 | 0x0000000077bdb831
[Stack.clean.0x000030b4]
+ | 0x000000000644f8b0 | 0x000007fefda210dc
+ | 0x000000000644f950 | 0x000007fed067be18
+ | 0x000000000644f980 | 0x000007fed068c9a6
+ | 0x000000000644f9b0 | 0x000007fed03aa32a
+ | 0x000000000644f9e0 | 0x000007fed068e2cf
+ | 0x000000000644fa10 | 0x000007fed067f1aa
+ | 0x000000000644fa40 | 0x000007fee8f94f7f
+ | 0x000000000644fa70 | 0x000007fee8f95126
+ | 0x000000000644faa0 | 0x00000000779a59ed
+ | 0x000000000644fad0 | 0x0000000077bdb831
[Stack.clean.0x0000336c]
+ | 0x000000000c1cf680 | 0x0000000077bcf6bb
+ | 0x000000000c1cf980 | 0x00000000779a59ed
+ | 0x000000000c1cf9b0 | 0x0000000077bdb831
[Stack.clean.0x000033e8]
+ | 0x000000001bf9ced0 | 0x000007fefda210dc
+ | 0x000000001bf9cf70 | 0x000007fee04d4614
+ | 0x000000001bf9fe20 | 0x000007fee04ecebb
+ | 0x000000001bf9fe50 | 0x000007fee04ecf4f
+ | 0x000000001bf9fe80 | 0x00000000779a59ed
+ | 0x000000001bf9feb0 | 0x0000000077bdb831
[Stack.clean.0x0000342c]
+ | 0x0000000005b9f630 | 0x000007fefda210dc
+ | 0x0000000005b9f6d0 | 0x000007fed067be18
+ | 0x0000000005b9f700 | 0x000007fed068c9a6
+ | 0x0000000005b9f730 | 0x000007fed03aa32a
+ | 0x0000000005b9f760 | 0x000007fed068e2cf
+ | 0x0000000005b9f790 | 0x000007fed067f1aa
+ | 0x0000000005b9f7c0 | 0x000007fee8f94f7f
+ | 0x0000000005b9f7f0 | 0x000007fee8f95126
+ | 0x0000000005b9f820 | 0x00000000779a59ed
+ | 0x0000000005b9f850 | 0x0000000077bdb831
[Stack.clean.0x00003450]
+ | 0x000000001c0ae410 | 0x000007fefda3bbdf
+ | 0x000000001c0ae480 | 0x000007fed7d7927c
+ | 0x000000001c0af770 | 0x000007feeb4950de
+ | 0x000000001c0af8b0 | 0x000007feeb494833
+ | 0x000000001c0af900 | 0x00000000779a59ed
+ | 0x000000001c0af930 | 0x0000000077bdb831
[Stack.clean.0x000035f0]
+ | 0x000000000c57f4d0 | 0x0000000077bcf6bb
+ | 0x000000000c57f7d0 | 0x00000000779a59ed
+ | 0x000000000c57f800 | 0x0000000077bdb831
[Stack.clean.0x000037d0]
+ | 0x000000002059e500 | 0x000007fefda210dc
+ | 0x000000002059e5a0 | 0x000007fee04d4614
+ | 0x000000002059fd40 | 0x000007fee04ecebb
+ | 0x000000002059fd70 | 0x000007fee04ecf4f
+ | 0x000000002059fda0 | 0x00000000779a59ed
+ | 0x000000002059fdd0 | 0x0000000077bdb831
[Stack.clean.0x000037f8]
+ | 0x0000000015af6380 | 0x000007fefda210dc
+ | 0x0000000015af6420 | 0x000007fee04d4614
+ | 0x0000000015affd60 | 0x000007fee04ecebb
+ | 0x0000000015affd90 | 0x000007fee04ecf4f
+ | 0x0000000015affdc0 | 0x00000000779a59ed
+ | 0x0000000015affdf0 | 0x0000000077bdb831
[Stack.clean.0x00003804]
+ | 0x000000000458f4d0 | 0x000007fefd100f75
+ | 0x000000000458f550 | 0x000007fefd101057
+ | 0x000000000458f6f0 | 0x000007feff9e4efc
+ | 0x000000000458f730 | 0x000007feff9e4e7d
+ | 0x000000000458f830 | 0x000007fedea49745
+ | 0x000000000458fd60 | 0x000007fedea48f78
+ | 0x000000000458fe00 | 0x000007fedea4fc1e
+ | 0x000000000458fe50 | 0x000007fee8f94f7f
+ | 0x000000000458fe80 | 0x000007fee8f95126
+ | 0x000000000458feb0 | 0x00000000779a59ed
+ | 0x000000000458fee0 | 0x0000000077bdb831
[Stack.clean.0x00003950]
+ | 0x000000001c4bed40 | 0x000007fefda210dc
+ | 0x000000001c4bede0 | 0x000007fee04d4614
+ | 0x000000001c4bf730 | 0x000007fee04ecebb
+ | 0x000000001c4bf760 | 0x000007fee04ecf4f
+ | 0x000000001c4bf790 | 0x00000000779a59ed
+ | 0x000000001c4bf7c0 | 0x0000000077bdb831
[Stack.clean.0x00003968]
+ | 0x0000000006b5f850 | 0x000007fefda210dc
+ | 0x0000000006b5f8f0 | 0x000007fed067be18
+ | 0x0000000006b5f920 | 0x000007fed068c9a6
+ | 0x0000000006b5f950 | 0x000007fed03aa32a
+ | 0x0000000006b5f980 | 0x000007fed068e2cf
+ | 0x0000000006b5f9b0 | 0x000007fed067f1aa
+ | 0x0000000006b5f9e0 | 0x000007fee8f94f7f
+ | 0x0000000006b5fa10 | 0x000007fee8f95126
+ | 0x0000000006b5fa40 | 0x00000000779a59ed
+ | 0x0000000006b5fa70 | 0x0000000077bdb831
[Stack.clean.0x00003a4c]
+ | 0x00000000156121b0 | 0x000007fefda210dc
+ | 0x0000000015612250 | 0x000007fee04d4614
+ | 0x000000001561f800 | 0x000007fee04ecebb
+ | 0x000000001561f830 | 0x000007fee04ecf4f
+ | 0x000000001561f860 | 0x00000000779a59ed
+ | 0x000000001561f890 | 0x0000000077bdb831
[Stack.clean.0x00003c98]
+ | 0x000000001cfe4100 | 0x000007fefda210dc
+ | 0x000000001cfe41a0 | 0x000007fee04d4614
+ | 0x000000001cfef770 | 0x000007fee04ecebb
+ | 0x000000001cfef7a0 | 0x000007fee04ecf4f
+ | 0x000000001cfef7d0 | 0x00000000779a59ed
+ | 0x000000001cfef800 | 0x0000000077bdb831
[Stack.clean.0x00003db0]
+ | 0x000000001caa04d0 | 0x000007fefda210dc
+ | 0x000000001caa0570 | 0x000007fee04d4614
+ | 0x000000001caaf7b0 | 0x000007fee04ecebb
+ | 0x000000001caaf7e0 | 0x000007fee04ecf4f
+ | 0x000000001caaf810 | 0x00000000779a59ed
+ | 0x000000001caaf840 | 0x0000000077bdb831
[Stack.clean.0x00003f60]
+ | 0x00000000039ef8e0 | 0x0000000077bca957
+ | 0x00000000039efb80 | 0x00000000779a59ed
+ | 0x00000000039efbb0 | 0x0000000077bdb831
[Stack.clean.0x00004034]
+ | 0x00000000055ef690 | 0x000007fefda21430
+ | 0x00000000055ef790 | 0x00000000779a06e0
+ | 0x00000000055ef820 | 0x000007fecdd56f52
+ | 0x00000000055ef880 | 0x000007fecdbf9f57
+ | 0x00000000055efa50 | 0x000007fecdc0f8cf
+ | 0x00000000055efa80 | 0x000007fecddd86cf
+ | 0x00000000055efad0 | 0x000007fecddc7829
+ | 0x00000000055efb00 | 0x000007fecddc77c2
+ | 0x00000000055efb50 | 0x000007fecdbfa810
+ | 0x00000000055efb80 | 0x000007fed068e2cf
+ | 0x00000000055efbb0 | 0x000007fed067f1aa
+ | 0x00000000055efbe0 | 0x000007fee8f94f7f
+ | 0x00000000055efc10 | 0x000007fee8f95126
+ | 0x00000000055efc40 | 0x00000000779a59ed
+ | 0x00000000055efc70 | 0x0000000077bdb831
[Stack.clean.0x000040cc]
+ | 0x00000000038af100 | 0x000007fefda21430
+ | 0x00000000038af200 | 0x00000000779a06e0
+ | 0x00000000038af290 | 0x000007feeb498c77
+ | 0x00000000038af3a0 | 0x000007fed98f5d12
+ | 0x00000000038af450 | 0x000007fed98ed99c
+ | 0x00000000038af690 | 0x000007feeb4950de
+ | 0x00000000038af7d0 | 0x000007feeb494833
+ | 0x00000000038af820 | 0x00000000779a59ed
+ | 0x00000000038af850 | 0x0000000077bdb831
[Stack.clean.0x00004210]
+ | 0x000000001e91be80 | 0x000007fefda210dc
+ | 0x000000001e91bf20 | 0x000007fee04d4614
+ | 0x000000001e91fc10 | 0x000007fee04ecebb
+ | 0x000000001e91fc40 | 0x000007fee04ecf4f
+ | 0x000000001e91fc70 | 0x00000000779a59ed
+ | 0x000000001e91fca0 | 0x0000000077bdb831
[Stack.clean.0x00004510]
+ | 0x000000001f131fe0 | 0x000007fefda210dc
+ | 0x000000001f132080 | 0x000007fee04d4614
+ | 0x000000001f13fbb0 | 0x000007fee04ecebb
+ | 0x000000001f13fbe0 | 0x000007fee04ecf4f
+ | 0x000000001f13fc10 | 0x00000000779a59ed
+ | 0x000000001f13fc40 | 0x0000000077bdb831
[Stack.clean.0x00004658]
+ | 0x000000001277eb60 | 0x000007fefda210dc
+ | 0x000000001277ec00 | 0x000007fee04d4614
+ | 0x000000001277fe20 | 0x000007fee04ecebb
+ | 0x000000001277fe50 | 0x000007fee04ecf4f
+ | 0x000000001277fe80 | 0x00000000779a59ed
+ | 0x000000001277feb0 | 0x0000000077bdb831
[Stack.clean.0x000047a0]
+ | 0x000000000445f9d0 | 0x000007fefd0f5941
+ | 0x000000000445fa30 | 0x00000000779a59ed
+ | 0x000000000445fa60 | 0x0000000077bdb831
[Stack.clean.0x000047f8]
+ | 0x000000000669f8d0 | 0x000007fefda210dc
+ | 0x000000000669f970 | 0x000007fed067be18
+ | 0x000000000669f9a0 | 0x000007fed068c9a6
+ | 0x000000000669f9d0 | 0x000007fed03aa32a
+ | 0x000000000669fa00 | 0x000007fed068e2cf
+ | 0x000000000669fa30 | 0x000007fed067f1aa
+ | 0x000000000669fa60 | 0x000007fee8f94f7f
+ | 0x000000000669fa90 | 0x000007fee8f95126
+ | 0x000000000669fac0 | 0x00000000779a59ed
+ | 0x000000000669faf0 | 0x0000000077bdb831
[Stack.clean.0x00004a28]
+ | 0x00000000065ff900 | 0x000007fefda210dc
+ | 0x00000000065ff9a0 | 0x000007fed067be18
+ | 0x00000000065ff9d0 | 0x000007fed068c9a6
+ | 0x00000000065ffa00 | 0x000007fed03aa32a
+ | 0x00000000065ffa30 | 0x000007fed068e2cf
+ | 0x00000000065ffa60 | 0x000007fed067f1aa
+ | 0x00000000065ffa90 | 0x000007fee8f94f7f
+ | 0x00000000065ffac0 | 0x000007fee8f95126
+ | 0x00000000065ffaf0 | 0x00000000779a59ed
+ | 0x00000000065ffb20 | 0x0000000077bdb831
[Stack.clean.0x00004a2c]
+ | 0x000000000686f720 | 0x000007fefda210dc
+ | 0x000000000686f7c0 | 0x000007fed067be18
+ | 0x000000000686f7f0 | 0x000007fed068c9a6
+ | 0x000000000686f820 | 0x000007fed03aa32a
+ | 0x000000000686f850 | 0x000007fed068e2cf
+ | 0x000000000686f880 | 0x000007fed067f1aa
+ | 0x000000000686f8b0 | 0x000007fee8f94f7f
+ | 0x000000000686f8e0 | 0x000007fee8f95126
+ | 0x000000000686f910 | 0x00000000779a59ed
+ | 0x000000000686f940 | 0x0000000077bdb831
[Stack.clean.0x00004b5c]
+ | 0x000000000609f940 | 0x000007fefda210dc
+ | 0x000000000609f9e0 | 0x000007fed067be18
+ | 0x000000000609fa10 | 0x000007fed068c9a6
+ | 0x000000000609fa40 | 0x000007fed03aa32a
+ | 0x000000000609fa70 | 0x000007fed068e2cf
+ | 0x000000000609faa0 | 0x000007fed067f1aa
+ | 0x000000000609fad0 | 0x000007fee8f94f7f
+ | 0x000000000609fb00 | 0x000007fee8f95126
+ | 0x000000000609fb30 | 0x00000000779a59ed
+ | 0x000000000609fb60 | 0x0000000077bdb831
[Stack.clean.0x00004ce4]
+ | 0x00000000061cf910 | 0x000007fefda210dc
+ | 0x00000000061cf9b0 | 0x000007fed067be18
+ | 0x00000000061cf9e0 | 0x000007fed068c9a6
+ | 0x00000000061cfa10 | 0x000007fed03aa32a
+ | 0x00000000061cfa40 | 0x000007fed068e2cf
+ | 0x00000000061cfa70 | 0x000007fed067f1aa
+ | 0x00000000061cfaa0 | 0x000007fee8f94f7f
+ | 0x00000000061cfad0 | 0x000007fee8f95126
+ | 0x00000000061cfb00 | 0x00000000779a59ed
+ | 0x00000000061cfb30 | 0x0000000077bdb831
[Stack.clean.0x00004d24]
+ | 0x000000000625fc30 | 0x000007fefda210dc
+ | 0x000000000625fcd0 | 0x000007fed067be18
+ | 0x000000000625fd00 | 0x000007fed068c9a6
+ | 0x000000000625fd30 | 0x000007fed03aa32a
+ | 0x000000000625fd60 | 0x000007fed068e2cf
+ | 0x000000000625fd90 | 0x000007fed067f1aa
+ | 0x000000000625fdc0 | 0x000007fee8f94f7f
+ | 0x000000000625fdf0 | 0x000007fee8f95126
+ | 0x000000000625fe20 | 0x00000000779a59ed
+ | 0x000000000625fe50 | 0x0000000077bdb831
[Stack.clean.0x00004d28]
+ | 0x000000001df0a690 | 0x000007fefda210dc
+ | 0x000000001df0a730 | 0x000007fee04d4614
+ | 0x000000001df0fb40 | 0x000007fee04ecebb
+ | 0x000000001df0fb70 | 0x000007fee04ecf4f
+ | 0x000000001df0fba0 | 0x00000000779a59ed
+ | 0x000000001df0fbd0 | 0x0000000077bdb831
[Stack.clean.0x00004d64]
+ | 0x000000001982c360 | 0x000007fefda210dc
+ | 0x000000001982c400 | 0x000007fee04d4614
+ | 0x000000001982fb80 | 0x000007fee04ecebb
+ | 0x000000001982fbb0 | 0x000007fee04ecf4f
+ | 0x000000001982fbe0 | 0x00000000779a59ed
+ | 0x000000001982fc10 | 0x0000000077bdb831
[Stack.clean.0x00004f24]
+ | 0x00000000067cf8b0 | 0x000007fefda210dc
+ | 0x00000000067cf950 | 0x000007fed067be18
+ | 0x00000000067cf980 | 0x000007fed068c9a6
+ | 0x00000000067cf9b0 | 0x000007fed03aa32a
+ | 0x00000000067cf9e0 | 0x000007fed068e2cf
+ | 0x00000000067cfa10 | 0x000007fed067f1aa
+ | 0x00000000067cfa40 | 0x000007fee8f94f7f
+ | 0x00000000067cfa70 | 0x000007fee8f95126
+ | 0x00000000067cfaa0 | 0x00000000779a59ed
+ | 0x00000000067cfad0 | 0x0000000077bdb831
[Stack.clean.0x00004f8c]
+ | 0x000000001ed25a90 | 0x000007fefda210dc
+ | 0x000000001ed25b30 | 0x000007fee04d4614
+ | 0x000000001ed2f9f0 | 0x000007fee04ecebb
+ | 0x000000001ed2fa20 | 0x000007fee04ecf4f
+ | 0x000000001ed2fa50 | 0x00000000779a59ed
+ | 0x000000001ed2fa80 | 0x0000000077bdb831
[Stack.clean.0x0000500c]
+ | 0x000000000ddef650 | 0x000007fefda21430
+ | 0x000000000ddef750 | 0x00000000779b1893
+ | 0x000000000ddef7e0 | 0x0000000077ac8fbd
+ | 0x000000000ddef880 | 0x0000000077ac62ce
+ | 0x000000000ddef8c0 | 0x0000000077ac6300
+ | 0x000000000ddef900 | 0x000007fefb482cac
+ | 0x000000000ddef970 | 0x000007fefb482b10
+ | 0x000000000ddef9a0 | 0x00000000779a59ed
+ | 0x000000000ddef9d0 | 0x0000000077bdb831
[Stack.clean.0x0000528c]
+ | 0x000000001fa21800 | 0x000007fefda210dc
+ | 0x000000001fa218a0 | 0x000007fee04d4614
+ | 0x000000001fa2fc90 | 0x000007fee04ecebb
+ | 0x000000001fa2fcc0 | 0x000007fee04ecf4f
+ | 0x000000001fa2fcf0 | 0x00000000779a59ed
+ | 0x000000001fa2fd20 | 0x0000000077bdb831
[Stack.clean.0x00005458]
+ | 0x0000000008caf7c0 | 0x000007fefda210dc
+ | 0x0000000008caf860 | 0x000007fed067be18
+ | 0x0000000008caf890 | 0x000007fed068c9a6
+ | 0x0000000008caf8c0 | 0x000007fecdbf6789
+ | 0x0000000008caf8f0 | 0x000007fed068e2cf
+ | 0x0000000008caf920 | 0x000007fed067f1aa
+ | 0x0000000008caf950 | 0x000007fee8f94f7f
+ | 0x0000000008caf980 | 0x000007fee8f95126
+ | 0x0000000008caf9b0 | 0x00000000779a59ed
+ | 0x0000000008caf9e0 | 0x0000000077bdb831
[Stack.clean.0x00005484]
+ | 0x000000000419f8f0 | 0x000007fefda210dc
+ | 0x000000000419f990 | 0x000007fed067be18
+ | 0x000000000419f9c0 | 0x000007fed068c9a6
+ | 0x000000000419f9f0 | 0x000007fed03aa32a
+ | 0x000000000419fa20 | 0x000007fed068e2cf
+ | 0x000000000419fa50 | 0x000007fed067f1aa
+ | 0x000000000419fa80 | 0x000007fee8f94f7f
+ | 0x000000000419fab0 | 0x000007fee8f95126
+ | 0x000000000419fae0 | 0x00000000779a59ed
+ | 0x000000000419fb10 | 0x0000000077bdb831
[Stack.clean.0x0000551c]
+ | 0x0000000012ff46d0 | 0x000007fefda210dc
+ | 0x0000000012ff4770 | 0x000007fee04d4614
+ | 0x0000000012fff7c0 | 0x000007fee04ecebb
+ | 0x0000000012fff7f0 | 0x000007fee04ecf4f
+ | 0x0000000012fff820 | 0x00000000779a59ed
+ | 0x0000000012fff850 | 0x0000000077bdb831
[Stack.clean.0x00005544]
+ | 0x0000000012163a40 | 0x000007fefda210dc
+ | 0x0000000012163ae0 | 0x000007fee04d4614
+ | 0x000000001216f980 | 0x000007fee04ecebb
+ | 0x000000001216f9b0 | 0x000007fee04ecf4f
+ | 0x000000001216f9e0 | 0x00000000779a59ed
+ | 0x000000001216fa10 | 0x0000000077bdb831
[Stack.clean.0x000055dc]
+ | 0x0000000006c5f5d0 | 0x000007fefda210dc
+ | 0x0000000006c5f670 | 0x000007fed067be18
+ | 0x0000000006c5f6a0 | 0x000007fed068c9a6
+ | 0x0000000006c5f6d0 | 0x000007fed03aa32a
+ | 0x0000000006c5f700 | 0x000007fed068e2cf
+ | 0x0000000006c5f730 | 0x000007fed067f1aa
+ | 0x0000000006c5f760 | 0x000007fee8f94f7f
+ | 0x0000000006c5f790 | 0x000007fee8f95126
+ | 0x0000000006c5f7c0 | 0x00000000779a59ed
+ | 0x0000000006c5f7f0 | 0x0000000077bdb831
[Stack.clean.0x00005608]
+ | 0x000000000353eba0 | 0x000007fefda210dc
+ | 0x000000000353ec40 | 0x000007fee8f9b9f8
+ | 0x000000000353ed70 | 0x000007fee8f9ca24
+ | 0x000000000353edc0 | 0x000007fee8f9c880
+ | 0x000000000353ee30 | 0x000007fed7d73573
+ | 0x000000000353efc0 | 0x000007fed7d62d3e
+ | 0x000000000353f080 | 0x000007fed7d76269
+ | 0x000000000353f0b0 | 0x000007fed7dd2b4b
+ | 0x000000000353f7c0 | 0x000007fed7d6e708
+ | 0x000000000353f890 | 0x000007feeb4950de
+ | 0x000000000353f9d0 | 0x000007feeb494833
+ | 0x000000000353fa20 | 0x00000000779a59ed
+ | 0x000000000353fa50 | 0x0000000077bdb831
[Stack.clean.0x00005704]
+ | 0x00000000069bf6e0 | 0x000007fefda210dc
+ | 0x00000000069bf780 | 0x000007fed067be18
+ | 0x00000000069bf7b0 | 0x000007fed068c9a6
+ | 0x00000000069bf7e0 | 0x000007fed03aa32a
+ | 0x00000000069bf810 | 0x000007fed068e2cf
+ | 0x00000000069bf840 | 0x000007fed067f1aa
+ | 0x00000000069bf870 | 0x000007fee8f94f7f
+ | 0x00000000069bf8a0 | 0x000007fee8f95126
+ | 0x00000000069bf8d0 | 0x00000000779a59ed
+ | 0x00000000069bf900 | 0x0000000077bdb831
[Stack.clean.0x00005744]
+ | 0x000000000690f9f0 | 0x000007fefda210dc
+ | 0x000000000690fa90 | 0x000007fed067be18
+ | 0x000000000690fac0 | 0x000007fed068c9a6
+ | 0x000000000690faf0 | 0x000007fed03aa32a
+ | 0x000000000690fb20 | 0x000007fed068e2cf
+ | 0x000000000690fb50 | 0x000007fed067f1aa
+ | 0x000000000690fb80 | 0x000007fee8f94f7f
+ | 0x000000000690fbb0 | 0x000007fee8f95126
+ | 0x000000000690fbe0 | 0x00000000779a59ed
+ | 0x000000000690fc10 | 0x0000000077bdb831
[Stack.clean.0x00005760]
+ | 0x000000000c35f890 | 0x0000000077bcf6bb
+ | 0x000000000c35fb90 | 0x00000000779a59ed
+ | 0x000000000c35fbc0 | 0x0000000077bdb831
[Stack.clean.0x0000576c]
+ | 0x0000000009826de0 | 0x000007fefda210dc
+ | 0x0000000009826e80 | 0x000007fee04d4614
+ | 0x000000000982f980 | 0x000007fee04ecebb
+ | 0x000000000982f9b0 | 0x000007fee04ecf4f
+ | 0x000000000982f9e0 | 0x00000000779a59ed
+ | 0x000000000982fa10 | 0x0000000077bdb831
[Stack.clean.0x00005788]
+ | 0x000000000656f700 | 0x000007fefda210dc
+ | 0x000000000656f7a0 | 0x000007fed067be18
+ | 0x000000000656f7d0 | 0x000007fed068c9a6
+ | 0x000000000656f800 | 0x000007fed03aa32a
+ | 0x000000000656f830 | 0x000007fed068e2cf
+ | 0x000000000656f860 | 0x000007fed067f1aa
+ | 0x000000000656f890 | 0x000007fee8f94f7f
+ | 0x000000000656f8c0 | 0x000007fee8f95126
+ | 0x000000000656f8f0 | 0x00000000779a59ed
+ | 0x000000000656f920 | 0x0000000077bdb831
[Stack.clean.0x000057a0]
+ | 0x00000000054df690 | 0x000007fefda210dc
+ | 0x00000000054df730 | 0x000007fed067be18
+ | 0x00000000054df760 | 0x000007fed068c9a6
+ | 0x00000000054df790 | 0x000007fed03aa32a
+ | 0x00000000054df7c0 | 0x000007fed068e2cf
+ | 0x00000000054df7f0 | 0x000007fed067f1aa
+ | 0x00000000054df820 | 0x000007fee8f94f7f
+ | 0x00000000054df850 | 0x000007fee8f95126
+ | 0x00000000054df880 | 0x00000000779a59ed
+ | 0x00000000054df8b0 | 0x0000000077bdb831
[Stack.clean.0x00005894]
+ | 0x0000000005e5f620 | 0x000007fefda210dc
+ | 0x0000000005e5f6c0 | 0x000007fed067be18
+ | 0x0000000005e5f6f0 | 0x000007fed068c9a6
+ | 0x0000000005e5f720 | 0x000007fed03aa32a
+ | 0x0000000005e5f750 | 0x000007fed068e2cf
+ | 0x0000000005e5f780 | 0x000007fed067f1aa
+ | 0x0000000005e5f7b0 | 0x000007fee8f94f7f
+ | 0x0000000005e5f7e0 | 0x000007fee8f95126
+ | 0x0000000005e5f810 | 0x00000000779a59ed
+ | 0x0000000005e5f840 | 0x0000000077bdb831
[Stack.clean.0x00005944]
+ | 0x000000000432f280 | 0x000007fefda216ad
+ | 0x000000000432f2e0 | 0x00000000779999a1
+ | 0x000000000432f320 | 0x000007fedea659f1
+ | 0x000000000432f430 | 0x000007fedea45761
+ | 0x000000000432f620 | 0x000007feeb4950de
+ | 0x000000000432f760 | 0x000007feeb494833
+ | 0x000000000432f7b0 | 0x00000000779a59ed
+ | 0x000000000432f7e0 | 0x0000000077bdb831
[Stack.clean.0x0000595c]
+ | 0x000000000340f7f0 | 0x000007fefda210dc
+ | 0x000000000340f890 | 0x000007fed067be18
+ | 0x000000000340f8c0 | 0x000007fed068c9a6
+ | 0x000000000340f8f0 | 0x000007fed03aa32a
+ | 0x000000000340f920 | 0x000007fed068e2cf
+ | 0x000000000340f950 | 0x000007fed067f1aa
+ | 0x000000000340f980 | 0x000007fee8f94f7f
+ | 0x000000000340f9b0 | 0x000007fee8f95126
+ | 0x000000000340f9e0 | 0x00000000779a59ed
+ | 0x000000000340fa10 | 0x0000000077bdb831
[Stack.clean.0x000059bc]
+ | 0x000000001f62b170 | 0x000007fefda210dc
+ | 0x000000001f62b210 | 0x000007fee04d4614
+ | 0x000000001f62f7d0 | 0x000007fee04ecebb
+ | 0x000000001f62f800 | 0x000007fee04ecf4f
+ | 0x000000001f62f830 | 0x00000000779a59ed
+ | 0x000000001f62f860 | 0x0000000077bdb831
[Stack.clean.0x00005ca0]
+ | 0x000000000632fd10 | 0x000007fefda210dc
+ | 0x000000000632fdb0 | 0x000007fed067be18
+ | 0x000000000632fde0 | 0x000007fed068c9a6
+ | 0x000000000632fe10 | 0x000007fed03aa32a
+ | 0x000000000632fe40 | 0x000007fed068e2cf
+ | 0x000000000632fe70 | 0x000007fed067f1aa
+ | 0x000000000632fea0 | 0x000007fee8f94f7f
+ | 0x000000000632fed0 | 0x000007fee8f95126
+ | 0x000000000632ff00 | 0x00000000779a59ed
+ | 0x000000000632ff30 | 0x0000000077bdb831
[Stack.clean.0x00005d20]
+ | 0x0000000012ba0a40 | 0x000007fefda210dc
+ | 0x0000000012ba0ae0 | 0x000007fee04d4614
+ | 0x0000000012baf7a0 | 0x000007fee04ecebb
+ | 0x0000000012baf7d0 | 0x000007fee04ecf4f
+ | 0x0000000012baf800 | 0x00000000779a59ed
+ | 0x0000000012baf830 | 0x0000000077bdb831
[Stack.clean.0x00005de8]
+ | 0x000000000379fb90 | 0x000007fefda210dc
+ | 0x000000000379fc30 | 0x000007fed067be18
+ | 0x000000000379fc60 | 0x000007fed068c9a6
+ | 0x000000000379fc90 | 0x000007fed03aa32a
+ | 0x000000000379fcc0 | 0x000007fed068e2cf
+ | 0x000000000379fcf0 | 0x000007fed067f1aa
+ | 0x000000000379fd20 | 0x000007fee8f94f7f
+ | 0x000000000379fd50 | 0x000007fee8f95126
+ | 0x000000000379fd80 | 0x00000000779a59ed
+ | 0x000000000379fdb0 | 0x0000000077bdb831
[Stack.clean.0x00005e1c]
+ | 0x00000000046bfbc0 | 0x000007fefda210dc
+ | 0x00000000046bfc60 | 0x000007fed067be18
+ | 0x00000000046bfc90 | 0x000007fed068c9a6
+ | 0x00000000046bfcc0 | 0x000007fed03aa32a
+ | 0x00000000046bfcf0 | 0x000007fed068e2cf
+ | 0x00000000046bfd20 | 0x000007fed067f1aa
+ | 0x00000000046bfd50 | 0x000007fee8f94f7f
+ | 0x00000000046bfd80 | 0x000007fee8f95126
+ | 0x00000000046bfdb0 | 0x00000000779a59ed
+ | 0x00000000046bfde0 | 0x0000000077bdb831
[Stack.clean.0x00005eb0]
+ | 0x000000000492f9e0 | 0x000007fefda216ad
+ | 0x000000000492fa40 | 0x00000000779999a1
+ | 0x000000000492fa80 | 0x000007fecddb9f9a
+ | 0x000000000492fac0 | 0x000007fecddba522
+ | 0x000000000492fb10 | 0x000007fecddb9e13
+ | 0x000000000492fb40 | 0x000007fecddba3ba
+ | 0x000000000492fb90 | 0x000007fecddc7829
+ | 0x000000000492fbc0 | 0x000007fecddc77c2
+ | 0x000000000492fc10 | 0x000007fecddc98f9
+ | 0x000000000492fda0 | 0x000007fecddbaaba
+ | 0x000000000492fdd0 | 0x00000000779a59ed
+ | 0x000000000492fe00 | 0x0000000077bdb831
[Stack.clean.0x0000609c]
+ | 0x0000000005acf600 | 0x000007fefda210dc
+ | 0x0000000005acf6a0 | 0x000007fed067be18
+ | 0x0000000005acf6d0 | 0x000007fed068c9a6
+ | 0x0000000005acf700 | 0x000007fed03aa32a
+ | 0x0000000005acf730 | 0x000007fed068e2cf
+ | 0x0000000005acf760 | 0x000007fed067f1aa
+ | 0x0000000005acf790 | 0x000007fee8f94f7f
+ | 0x0000000005acf7c0 | 0x000007fee8f95126
+ | 0x0000000005acf7f0 | 0x00000000779a59ed
+ | 0x0000000005acf820 | 0x0000000077bdb831
[Stack.clean.0x0000613c]
+ | 0x00000000064df840 | 0x000007fefda210dc
+ | 0x00000000064df8e0 | 0x000007fed067be18
+ | 0x00000000064df910 | 0x000007fed068c9a6
+ | 0x00000000064df940 | 0x000007fed03aa32a
+ | 0x00000000064df970 | 0x000007fed068e2cf
+ | 0x00000000064df9a0 | 0x000007fed067f1aa
+ | 0x00000000064df9d0 | 0x000007fee8f94f7f
+ | 0x00000000064dfa00 | 0x000007fee8f95126
+ | 0x00000000064dfa30 | 0x00000000779a59ed
+ | 0x00000000064dfa60 | 0x0000000077bdb831
[Stack.clean.0x0000614c]
+ | 0x000000001ffd7470 | 0x000007fefda210dc
+ | 0x000000001ffd7510 | 0x000007fee04d4614
+ | 0x000000001ffdf740 | 0x000007fee04ecebb
+ | 0x000000001ffdf770 | 0x000007fee04ecf4f
+ | 0x000000001ffdf7a0 | 0x00000000779a59ed
+ | 0x000000001ffdf7d0 | 0x0000000077bdb831
[Stack.clean.0x00006174]
+ | 0x0000000007e6fb30 | 0x000007fefda210dc
+ | 0x0000000007e6fbd0 | 0x000007fed067be18
+ | 0x0000000007e6fc00 | 0x000007fed068c9a6
+ | 0x0000000007e6fc30 | 0x000007fecdf3ea08
+ | 0x0000000007e6fc70 | 0x000007fed068e2cf
+ | 0x0000000007e6fca0 | 0x000007fed067f1aa
+ | 0x0000000007e6fcd0 | 0x000007fee8f94f7f
+ | 0x0000000007e6fd00 | 0x000007fee8f95126
+ | 0x0000000007e6fd30 | 0x00000000779a59ed
+ | 0x0000000007e6fd60 | 0x0000000077bdb831
[Stack.clean.0x00006214]
+ | 0x000000000580f5c0 | 0x000007fefda210dc
+ | 0x000000000580f660 | 0x000007fed067be18
+ | 0x000000000580f690 | 0x000007fed068c9a6
+ | 0x000000000580f6c0 | 0x000007fed03aa32a
+ | 0x000000000580f6f0 | 0x000007fed068e2cf
+ | 0x000000000580f720 | 0x000007fed067f1aa
+ | 0x000000000580f750 | 0x000007fee8f94f7f
+ | 0x000000000580f780 | 0x000007fee8f95126
+ | 0x000000000580f7b0 | 0x00000000779a59ed
+ | 0x000000000580f7e0 | 0x0000000077bdb831
[Stack.clean.0x00006248]
+ | 0x000000001e3e8220 | 0x000007fefda210dc
+ | 0x000000001e3e82c0 | 0x000007fee04d4614
+ | 0x000000001e3efc20 | 0x000007fee04ecebb
+ | 0x000000001e3efc50 | 0x000007fee04ecf4f
+ | 0x000000001e3efc80 | 0x00000000779a59ed
+ | 0x000000001e3efcb0 | 0x0000000077bdb831
[Stack.clean.0x000062bc]
+ | 0x000000001ac68360 | 0x000007fefda210dc
+ | 0x000000001ac68400 | 0x000007fee04d4614
+ | 0x000000001ac6f7e0 | 0x000007fee04ecebb
+ | 0x000000001ac6f810 | 0x000007fee04ecf4f
+ | 0x000000001ac6f840 | 0x00000000779a59ed
+ | 0x000000001ac6f870 | 0x0000000077bdb831
[Stack.clean.0x00006348]
+ | 0x000000000673fa80 | 0x000007fefda210dc
+ | 0x000000000673fb20 | 0x000007fed067be18
+ | 0x000000000673fb50 | 0x000007fed068c9a6
+ | 0x000000000673fb80 | 0x000007fed03aa32a
+ | 0x000000000673fbb0 | 0x000007fed068e2cf
+ | 0x000000000673fbe0 | 0x000007fed067f1aa
+ | 0x000000000673fc10 | 0x000007fee8f94f7f
+ | 0x000000000673fc40 | 0x000007fee8f95126
+ | 0x000000000673fc70 | 0x00000000779a59ed
+ | 0x000000000673fca0 | 0x0000000077bdb831
[Stack.clean.0x0000665c]
+ | 0x000000001d976980 | 0x000007fefda210dc
+ | 0x000000001d976a20 | 0x000007fee04d4614
+ | 0x000000001d97fa90 | 0x000007fee04ecebb
+ | 0x000000001d97fac0 | 0x000007fee04ecf4f
+ | 0x000000001d97faf0 | 0x00000000779a59ed
+ | 0x000000001d97fb20 | 0x0000000077bdb831
[Stack.clean.0x000066f4]
+ | 0x0000000005dcfb30 | 0x000007fefda210dc
+ | 0x0000000005dcfbd0 | 0x000007fed067be18
+ | 0x0000000005dcfc00 | 0x000007fed068c9a6
+ | 0x0000000005dcfc30 | 0x000007fed03aa32a
+ | 0x0000000005dcfc60 | 0x000007fed068e2cf
+ | 0x0000000005dcfc90 | 0x000007fed067f1aa
+ | 0x0000000005dcfcc0 | 0x000007fee8f94f7f
+ | 0x0000000005dcfcf0 | 0x000007fee8f95126
+ | 0x0000000005dcfd20 | 0x00000000779a59ed
+ | 0x0000000005dcfd50 | 0x0000000077bdb831
[Stack.clean.0x00006718]
! | 0x0000000000000000 | 0x000007fefbf11573 | mozalloc.dll
+ | 0x000000000022a500 | 0x000007fecdbbeff8
+ | 0x000000000022a9a0 | 0x000007fecedd7c81
+ | 0x000000000022a9e0 | 0x000007fecdbf3c72
+ | 0x000000000022aa10 | 0x000007fecdbf298e
+ | 0x000000000022aa60 | 0x000007fecdbf246a
+ | 0x000000000022aa90 | 0x000007fecdc0c275
+ | 0x000000000022aad0 | 0x000007fecdc0bfaf
+ | 0x000000000022ab00 | 0x000007fecdc0b1db
+ | 0x000000000022ab30 | 0x000007fecdc00d00
+ | 0x000000000022ad40 | 0x000007fecdc03bb8
+ | 0x000000000022add0 | 0x000007fecdbf0059
+ | 0x000000000022b4c0 | 0x000007fecdbf4be0
+ | 0x000000000022b530 | 0x000007fecdbf43a0
+ | 0x000000000022b580 | 0x000007fecdbf00d7
+ | 0x000000000022bc70 | 0x000007fecdbf4be0
+ | 0x000000000022bce0 | 0x000007fecdbf5226
+ | 0x000000000022bd10 | 0x000007fecdbf380c
+ | 0x000000000022bdb0 | 0x000007fecdc13d29
+ | 0x000000000022bf20 | 0x000007fee9f3478c
+ | 0x000000000022c0b0 | 0x000007fee9f376e2
+ | 0x000000000022c1e0 | 0x000007fed0d5230d
+ | 0x000000000022c290 | 0x000007fed0d51eee
+ | 0x000000000022c300 | 0x000007fed6bbb26b
+ | 0x000000000022d2e0 | 0x000007fed6b89a3d
+ | 0x000000000022d310 | 0x000007fed7f108e1
+ | 0x000000000022d500 | 0x000007fed7f02876
+ | 0x000000000022d530 | 0x000007fed7fd893d
+ | 0x000000000022d5d0 | 0x000007fed7fd87d2
+ | 0x000000000022d680 | 0x000007fed7fc8286
+ | 0x000000000022d6b0 | 0x000007fed7fc0a9d
+ | 0x000000000022d750 | 0x000007fed7fbfa46
+ | 0x000000000022d830 | 0x000007fed7fbe88d
+ | 0x000000000022d900 | 0x000007fed7fbcbf4
+ | 0x000000000022d940 | 0x000007fed7fbb210
+ | 0x000000000022d970 | 0x000007fed7f165da
+ | 0x000000000022da80 | 0x000007fed7f0972f
+ | 0x000000000022dc30 | 0x000007fed7f02854
+ | 0x000000000022dc60 | 0x000007fed6a6cc0f
+ | 0x000000000022dd00 | 0x000007fed6a58b9c
+ | 0x000000000022dde0 | 0x000007fed7f08af8
+ | 0x000000000022df00 | 0x000007fed7f02854
+ | 0x000000000022df30 | 0x000007fed6a6cc0f
+ | 0x000000000022dfd0 | 0x000007fed6a534a4
+ | 0x000000000022e0f0 | 0x000007fed6a5c36a
+ | 0x000000000022eeb0 | 0x000007fed6a70426
+ | 0x000000000022eee0 | 0x000007fed6b0eb3c
+ | 0x000000000022ef90 | 0x000007fed94fba2f
+ | 0x000000000022efd0 | 0x000007fed94f3c0c
+ | 0x000000000022f030 | 0x000007fed98f1561
+ | 0x000000000022f0e0 | 0x000007fed98f81bf
+ | 0x000000000022f330 | 0x000007fed87137dd
+ | 0x000000000022f3e0 | 0x000007fed8713c69
+ | 0x000000000022f440 | 0x000007fed860affc
+ | 0x000000000022f470 | 0x000007fed87ab59e
+ | 0x000000000022f4b0 | 0x0000000077ab795c
+ | 0x000000000022f4e0 | 0x0000000077abf5e7
+ | 0x000000000022f510 | 0x0000000077ac4869
+ | 0x000000000022f560 | 0x0000000077bfd8f5
+ | 0x000000000022f620 | 0x0000000077ac9ece
+ | 0x000000000022f650 | 0x000007fed876b2f3
+ | 0x000000000022f6e0 | 0x000007fed8853070
+ | 0x000000000022f730 | 0x000007fed881ac6c
+ | 0x000000000022f7a0 | 0x000007fed867e3c8
+ | 0x000000000022f820 | 0x000007fed8721308
+ | 0x000000000022f8d0 | 0x000000013fa9cb9d
+ | 0x000000000022f910 | 0x00000000779a59ed
+ | 0x000000000022f940 | 0x0000000077bdb831
[replay.xml]
<?xml version='1.0' encoding='UTF-8'?>
<actions xmlns:unsignedInt="http://www.w3.org/2001/XMLSchema#unsignedInt">
 <action object="component[id='TabPane']" unsignedInt:pause="71247" unsignedInt:time="71247">
  <objectAction tab="Analysis Target">Switch</objectAction>
 </action>
 <action object="component[id='TabPane']" unsignedInt:pause="3297" unsignedInt:time="74544">
  <objectAction tab="Analysis Type">Switch</objectAction>
 </action>
 <action object="component[id='TabPane']" unsignedInt:pause="1447" unsignedInt:time="75991">
  <objectAction tab="Collection Log">Switch</objectAction>
 </action>
</actions>
Vitaly_S_Intel
We provided a patch to Jeremy and he confirmed it fixed this issue.
We expect the fix for this issue to be included in the next VTune release.
Peter_W_Intel
>Side note: the error popup explicitly said to email parallel.studio.support@intel.com, but then I got a reply that I should not use that inbox! That's a bit annoying.
Please try "amplxe-feedback -send-crash-report report_file" ; it should work I tested on Linux where I have no email box.
Vitaly_S_Intel
Hi Jeremy,
Thanks for reporting this issue.
Can you please do the following in command line:
> set TEMP=c:\temp
> amplxe-gui.exe
Does it still crash?
Jeremy_N_
Hi Vitaly,
Thanks for the suggestion. I tried that but still got the same crash.
Dmitry_K_Intel1
Hi Jeremy,
You may type 'set' in CMD console and take a look what environment variables you have set on your system. If you have, for example 'TEMP=c:/temp' or/and 'TMP=c:/temp' in the list of environment variables then need to update the temp variables using back-slashes in path(s)!
For example, I have the following on my Windows system:
TEMP=C:\Users\ADMINI~1\AppData\Local\Temp
TMP=C:\Users\ADMINI~1\AppData\Local\Temp
One more which need to check is, you have the pointed temp directories on disk exist and write permissions set.
You may update the env. variables in local console(CMD) or on System level. If you update it locally please keep in mind that 'amplxe-gui.exe' need to start from the console(CMD) you updated for.
If you update the variables on System level then need to re-open console/CMD/window_explorer to get the variables propagated. And after that you may start 'amplxe-gui.exe' or VS with VTune integrated.
Please let us know if you still have the message box ( "Fail in NS_NewNativeLocalFile!") or/and crash on start of 'amplxe-gui.exe' or in VS.
Jeremy_N_
Hi Dmitry,
In order to rule that out, I opened a command prompt as an administrator (probably unnecessary since I am already an admin on this machine). I set TEMP to C:\Temp, created that folder, and set privileges to "Full Control". I typed "set" and verified TEMP was set to C:\Temp. I ran amplxe-gui.exe and still got both the "Fail in NS_NewNativeLocalFile!" and crash after running an analysis.
Vitaly_S_Intel
Hi Jeremy,
Please try to setup TMP variable together with TEMP - use the same value.
Also, can you provide your original value of TEMP variable? If you can not share it, will you please send it to me as a private message?
Jeremy_N_
Hi Vitaly, that did not fix it either. I'm beginning to think it's not a permissions or filepath issue
Dmitry_K_Intel1
Jeremy, please take a look at private message I sent...
You may check a suggested approach and let us know if it works or not.
Jeremy_N_
@Dmitry, Hmm, I don't have any messages in my inbox
Vitaly_S_Intel
Jeremy, please check your message box right on software.intel.com - look on the top right corner of the site, you should have a few messages from me and Dmitry.
Jeremy_N_
It literally says "0 messages", and when I click it, "No messages available".
Vitaly_S_Intel
