Analyzers
5254 Discussions
Data collector problem!
oyy_918
Hello,i met two problem using Vtune.
first :when i want to use sampling as mydata collector and type vtl activity -c sampling in the command line,i got the following error:
[cfd@lc Performance]$ vtl activity -c sampling
VTune Performance Analyzer 8.0 for Linux*. FOR NON-COMMERCIAL USE ONLY
Copyright (C) 2000-2005 Intel Corporation. All rights reserved.
TBSDevGetDsaAddr: couldn't open driver
Can't initialize collector properties
so i can only switch to the callgraph ,i can create a activity with callgraph,however,when i run it,problem comes:
[cfd@lc Projects]$ vtl project /home/cfd/VTune/Projects/vtldefault.vpj run
The Activity is running.
Sun Sep 10 10:29:44 2006 Reading property files started...
Sun Sep 10 10:29:44 2006 Call Graph collection was cancelled.
when it comes,what i can do is turn off the session and begin a new one, Could anyonetell me whatthe problem is? Thanks in advance!
Ekaterina_L_Intel
Thanks for your question. Let me help to you with the sampling issue. Seems that sampling driver isn't loaded into your kernel.Please try below steps:
1) Load existent pre-built driver:
$ cd /vdk
$ ./insmod-vtune
If there is pre-built driver for your kernel then it will be loaded into the kernel.
2) If there is no pre-built driver for your kernel, you need to build the driver manually. Make sure you have kernel headers configured properly for running kernel.
$ cd /vdk/src
$ ./build-driver
$ ./insmod-vtune
More info can be found in vdk/src/doc/HOWTO-BUILD-VTUNE-DRIVER
Katya
