Analyzers
Driver performance reduces from W2008 server to Win 2012 Server
Tejas_K_
Principiante
1.546 Visualizações
I have the proprietary driver which I run on Win 2008 Server and on Win 2012 Server. When the Que-depth is increased from 64 to 256 there is no reduction in performance on Win 2008 but reduces considerably on Win 2012. Vtune analysis on both systems give prettymuch the same results.
13 Respostas
Bernard
Contribuidor valorado I
1.546 Visualizações
What are the symptoms of reduced performance?
Tejas_K_
Principiante
1.546 Visualizações
When the Que-depth is 64  the driver performs about 720K I/Os per second
and when Que depth is increased to 256 there is a  reduction to 620K I/Os per second
Vtune indicated some functions which is taking time,even after ixing them it is still performing bad.
Bernard
1.546 Visualizações
At the beginning try to double check driver performance with Xperf.
Bernard
1.546 Visualizações
You can also try kernrate.
Tejas_K_
Principiante
1.546 Visualizações
I am using IOMeter , But shall try with Xperf
Bernard
1.546 Visualizações
Xperf will give you a call stack info also.
Tejas_K_
Principiante
1.546 Visualizações
Is there a good Xpef tuorial you would want to suggest , The ones I am looking into are not all that helpful
Bernard
1.546 Visualizações
Tejas_K_
Principiante
1.546 Visualizações
Thank you!
Bernard
1.546 Visualizações
@Tejas
Do you have any results?
Vitaly_S_Intel
Funcionário
1.546 Visualizações
BTW, have you tried General Exploration analysis in VTune? It may highlight some HW issues (look to red cells).
iliyapolak, can you please share your thoughts which useful XPerf features are missing in VTune?
Tejas_K_
Principiante
1.546 Visualizações
@iliyapolak , Yes Xperf was useful , made some changes and was effective. Thank you!
Bernard
1.546 Visualizações
I think that Xperf models or measures betters Win OS environment and its interaction with the software,although it is not probably the main purpose of the VTune.
For example time CPU spent in DPC routine.
Responder
