- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi..
I am evaluating Vtune analyzer 9.0 for Linux.
configuration:
RHEL 5.1,vtune analyzer 9.0, IPP 5.3.2 .
Java 1.4.2
I was using call graph activity on a C++ program. Program was to perform compression and decompression activity on jp2 images, using IPP libraries. Its a user interactive program, as soon as I entered path of the jp2 image file as input, Vtune crashed giving following error messages in terminal..
I have even attached a screen shot of the error message.. So Please help me out ...
Thanx in advance...
configuration:
Java 1.4.2
===== BEGIN DUMP =============================================================
JRockit dump produced after 0 days, 00:01:56 on Mon May 26 14:36:25 2008
Additional information is available in:
/root/vtunewrkspace/jrockit.32410.dump
No snapshot file (core dump) will be created because core dumps have been
disabled. To enable core dumping, try "ulimit -c unlimited"
before starting JRockit again.
If you see this dump, please open a support case with BEA and
supply as much information as you can on your system setup and
the program you were running. You can also search for solutions
to your problem at http://forums.bea.com in
the forum jrockit.developer.interest.general.
Error Message: Illegal memory access. [54]
Signal info : si_signo=11, si_code=2 si_addr=0x3fc
Version : BEA JRockit R27.2.0-131-78843-1.5.0_10-20070320-1511-linux-ia32
GC Mode : Garbage collection optimized for throughput
GC Strategy : Generational Parallel Mark & Sweep
: Current OC phase is: not running. YC is not running.
: GC strategy for GC 0 was singleconcon
: GC strategy for GC 1 was genparpar
: GC strategy for GC 2 was genparpar
: mmHeap->data = 0x8500000, mmHeap->top = 0xc500000
: The nurserylist starts at 0x85f6668 and ends at 0xa939fb0
: mmStartCompaction = 0x8500000, mmEndCompaction = 0x8900000
: References are 32-bit.
CPU : Intel Pentium 4 (HT) SSE SSE2 SSE3 NetBurst EM64T
Number CPUs : 2
Tot Phys Mem : 1049391104 (1000 MB)
OS version : Red Hat Enterprise Linux Client release 5.1 (Tikanga)
Linux version 2.6.18-53.el5 (brewbuilder@hs20-bc2-3.build.redhat.com) (gcc version 4.1.2 20070626 (Red Hat 4.1.2-14)) #1 SMP Wed Oct 10 16:34:02 EDT 2007 (i686)
Thread System: NPTL
State : JVM is running
Command Line : -Dosgi.splashLocation=/opt/intel/eclipsepackage/3.2.1_0/eclipse/plugins/com.intel.sdp.primary_2.0.3/splash.bmp -Dosgi.sharedConfiguration.area=/opt/intel/vtune/bin/../shared/eclipse/configuration -Dsun.java.launcher=SUN_STANDARD /opt/intel/eclipsepackage/3.2.1_0/eclipse/startup.jar -os linux -ws gtk -arch x86 -launcher /opt/intel/eclipsepackage/3.2.1_0/eclipse/eclipse -name Eclipse -showsplash 600 -exitdata 61801d -product com.intel.sdp.primary.product -perspective com.intel.vtune.shell.tuningPerspective -vm /opt/intel/eclipsepackage/3.2.1_0/jrockit-R27.2.0-jre1.5.0_10/bin/java -vmargs -Dosgi.splashLocation=/opt/intel/eclipsepackage/3.2.1_0/eclipse/plugins/com.intel.sdp.primary_2.0.3/splash.bmp -Dosgi.sharedConfiguration.area=/opt/intel/vtune/bin/../shared/eclipse/configuration -jar /opt/intel/eclipsepackage/3.2.1_0/eclipse/startup.jar
java.home : /opt/intel/eclipsepackage/3.2.1_0/jrockit-R27.2.0-jre1.5.0_10
j.class.path : /opt/intel/eclipsepackage/3.2.1_0/eclipse/startup.jar
j.lib.path : /opt/intel/eclipsepackage/3.2.1_0/jrockit-R27.2.0 -jre1.5.0_10/lib/i386/jrockit:/opt/intel/eclipsepackage/3.2.1_0/jrockit-R27.2.0-jre1.5.0_10/lib/i386:/opt/intel/eclipsepackage/3.2.1_0/jrockit-R27.2.0-jre1.5.0_10/../lib/i386:/opt/intel/eclipsepackage/3.2.1_0/eclipse:/opt/intel/vtune/analyzer/bin:/opt/intel/vtune/shared/bin:/opt/sag/gcc-3.3/lib32:/opt/sag/gcc-3.3/lib32:/opt/sag/exx/v721/lib:/usr/lib:/usr/kerberos/lib:/opt/intel/ipp/5.3/ia32/sharedlib:/usr/lib:/usr/lib:/usr/kerberos/lib:/opt/intel/ipp/5.3/ia32/sharedlib:/usr/lib/firefox-1.5.0.12
JAVA_HOME :
_JAVA_OPTIONS:
LD_LIBRARY_PATH: /opt/intel/eclipsepackage/3.2.1_0/jrockit-R27.2.0-jre1.5.0_10/lib/i386/jrockit:/opt/intel/eclipsepackage/3.2.1_0/jrockit-R27.2.0-jre1.5.0_10/lib/i386:/opt/intel/eclipsepackage/3.2.1_0/jrockit-R27.2.0-jre1.5.0_10/../lib/i386:/opt/intel/eclipsepackage/3.2.1_0/eclipse:/opt/intel/vtune/analyzer/bin:/opt/intel/vtune/shared/bin:/opt/sag/gcc-3.3/lib32:/opt/sag/gcc-3.3/lib32:/opt/sag/exx/v721/lib:/usr/lib:/usr/kerberos/lib:/opt/intel/ipp/5.3/ia32/sharedlib:/usr/lib:/usr/lib:/usr/kerberos/lib:/opt/intel/ipp/5.3/ia32/sharedlib:/usr/lib/firefox-1.5.0.12
LD_ASSUME_KERNEL:
C Heap : Good; no memory allocations have failed
StackOverFlow: 0 StackOverFlowErrors have occured
OutOfMemory : 0 OutOfMemoryErrors have occured
Registers (from ThreadContext: 0xbfaa95f0 / OS context: 0xbfaa96ec):
eax = 000003fc ecx = a8d93b00 edx = 000003fc ebx = b2e1885c
esp = bfaa99dc ebp = bfaa9ab8 esi = 00000005 edi = b09105c0
es = 0000007b cs = 00000073 ss = 0000007b ds = 0000007b
fs = 00000000 gs = 00000033
eip = b2d6f674 eflags = 00210282
Stack:
(* marks the word pointed to by the stack pointer)
bfaa99dc: 00000007* 00000000 00000000 00000000 00000001 a909cc4c
bfaa99f4: b2e1885c aebedcdc b5cdff30 a909cc4c aebedcdc aac5c501
bfaa9a0c: a89ebabc 00000000 00000002 00000000 aac5c560 aac5c55c
bfaa9a24: 00000000 a89ebabc a89f09b8 aac5c550 aac5c554 aac5c550
Code:
(* marks the word pointed to by the instruction pointer)
b2d6f644: 83fff814 458908c4 f8c483b8 0508458b 00000108 8b240489
b2d6f65c: ffff5885 448948ff c1e80424 83fff814 458908c4 b8458bbc
b2d6f674: 558b008b* 8b128bbc 408b0848 10728b0c 0114528b 8bd011f1
b2d6f68c: ffff2495 28b58bff 29ffffff d85589ca 7589c619 f5820fdc
Loaded modules:
(* denotes the module causing the exception)
08048000-08056fd3 /opt/intel/eclipsepackage/3.2.1_0/jrockit-R27.2.0-jre1.5.0_10/bin/java
b7f46000-b7f46613 /opt/intel/eclipsepackage/3.2.1_0/jrockit-R27.2.0-jre1.5.0_10/bin/java
00665000-0067735f /lib/libpthread.so.0
00be1000-00c051c7 /lib/libm.so.6
0065f000-00660ceb /lib/libdl.so.2
004f4000-0062d10b /lib/libc.so.6
004d2000-004eae53 /lib/ld-linux.so.2
b7c11000-b7eb0207 /opt/intel/eclipsepackage/3.2.1_0/jrockit-R27.2.0-jre1.5.0_10/lib/i386/jrockit/libjvm.so
008d9000-008df46b /lib/librt.so.1
b7f39000-b7f417eb /lib/libnss_files.so.2
b7aa7000-b7ab17db /opt/intel/eclipsepackage/3.2.1_0/jrockit-R27.2.0-jre1.5.0_10/lib/i386/libverify.so
b7a84000-b7aa4217 /opt/intel/eclipsepackage/3.2.1_0/jrockit-R27.2.0-jre1.5.0_10/lib/i386/libjava.so
00b96000-00ba8bff /lib/libnsl.so.1
b7a4d000-b7a52f13 /opt/intel/eclipsepackage/3.2.1_0/jrockit-R27.2.0-jre1.5.0_10/lib/i386/native_threads/libhpi.so
b78c4000-b78d24c4 /opt/intel/ eclipsepackage/3.2.1_0/jrockit-R27.2.0-jre1.5.0_10/lib/i386/libzip.so
b7245000-b72560a3 /opt/intel/eclipsepackage/3.2.1_0/jrockit-R27.2.0-jre1.5.0_10/lib/i386/libnet.so
b7820000-b78261e7 /opt/intel/eclipsepackage/3.2.1_0/jrockit-R27.2.0-jre1.5.0_10/lib/i386/libnio.so
b6a5d000-b6aa6e1b /opt/intel/eclipsepackage/3.2.1_0/eclipse/configuration/org.eclipse.osgi/bundles/41/1/.cp/libswt-pi-gtk-3235.so
06808000-06b988f3 /usr/lib/libgtk-x11-2.0.so.0
b7f2c000-b7f2f2bb /lib/libgthread-2.0.so.0
04c68000-04c6c393 /usr/lib/libXtst.so.6
b6a46000-b6a5bed3 /usr/lib/libgdk_pixbuf-2.0.so.0
b69b9000-b6a42973 /usr/lib/libgdk-x11-2.0.so.0
b69b0000-b69b7647 /usr/lib/libpangocairo-1.0.so.0
b6971000-b69ad36f /usr/lib/libpango-1.0.so.0
b686e000-b696c06b /usr/lib/libX11.so.6
00cd2000-00cebb53 /usr/lib/libatk-1.0.so.0
b682f000-b686c86f /lib/libgobject-2.0.so.0
b7803000-b7805007 /lib/libgmodule-2.0.so.0
b6791000-b682d56f /lib/libglib-2.0.so.0
b6723000-b678e793 /usr/lib/libcairo.so.2
007a0000-007ae157 /usr/lib/libXext.so.6
0087f000-008a538b /usr/lib/libfontconfig.so.1
008b0000-008b72d7 /usr/lib/libXrender.so.1
008d4000-008d54cf /usr/lib/libXinerama.so.1
00baf000-00bb5cbb /usr/lib/libXi.so.6
008ce000-008d03b3 /usr/lib/libXrandr.so.2
008c2000-008ca7a3 /usr/lib/libXcursor.so.1
008bb000-008be86f /usr/lib/libXfixes.so.3
b66f5000-b67213c7 /usr/lib/libpangoft2-1.0.so.0
007b2000-0082e393 /usr/lib/libfreetype.so.6
004ef000-004f0977 /usr/lib/libXau.so.6
00798000-0079c31f /usr/lib/libXdmcp.so.6
b66e2000-b66f388f /usr/lib/libz.so.1
00bb9000-00bdd6d3 /usr/lib/libpng12.so.0
00834000-0085255b /lib/libexpat.so.0
b7816000-b7816c33 /usr/lib/gconv/ISO8859-1.so
b66b9000-b66de073 /opt/intel/eclipsepackage/3.2.1_0/eclipse/configuration/org.eclipse.osgi/bundles/41/1/.cp/libswt-gtk-3235.so
b66a7000-b66b7cf3 /usr/lib/gtk-2.0/2.10.0/engines/libclearlooks.so
b6514000-b6515293 /opt/intel/eclipsepackage/3.2.1_0/eclipse/configuration/org.eclipse.osgi/bundles/38/1/.cp/os/linux/x86/liblocalfile_1_0_0.so
b61b5000-b61b6bbb /usr/lib/pango/1.5.0/modules/pango-basic-fc.so
b5f41000-b5f4620f /opt/intel/eclipsepackage/3.2.1_0/eclipse/configuration/org.eclipse.osgi/bundles/41/1/.cp/libswt-atk-gtk-3235.so
b5f37000-b5f3fe87 /opt/intel/eclipsepackage/3.2.1_0/eclipse/configuration/org.eclipse.osgi/bundles/41/1/.cp/libswt-cairo-gtk-3235.so
b58b2000-b58b55e3 /opt/intel/vtune/shared/bin/libEcGUIClientHandler.so
b5804000-b588138f /opt/intel/vtune/shared/bin/libEcGUIClient.so
b565f000-b5801e07 /opt/sag/gcc-3.3/lib32/libimf.so
b7801000-b7801577 /opt/sag/gcc-3.3/lib32/libcxaguard.so.5
b5d1e000-b5d24f1f /opt/sag/gcc-3.3/lib32/libgcc_s.so.1
b55a7000-b5644393 /opt/sag/gcc-3.3/lib32/libstdc++.so.5
b540e000-b557a343 /opt/sag/exx/v721/lib/libole32.so
b534f000-b53fadab /opt/sag/exx/v721/lib/librpcrt4.so
b532d000-b5347733 /opt/sag/exx/v721/lib/libntrtl.so
b529b000-b5317183 /opt/sag/exx/v721/lib/libmutant.so
b5d16000-b5d1bb27 /opt/sag/exx/v721/lib/libcoolmisc.so
b51b7000-b52878af /opt/sag/exx/v721/lib/liboleaut32.so
b5124000-b51addb3 /opt/intel/vtune/analyzer/bin/libcomfreeremoteconnector.so
b50f8000-b5119023 /opt/intel/vtune/shared/bin/libVTUtil.so
b5d11000-b5d13ec3 /opt/sag/exx/v721/lib/libcoolcrypto.so
b4ca4000-b4fa89ab /opt/intel/vtune/shared/bin/libxerces-c.so.23
b4c70000-b4c9d547 /opt/intel/vtune/shared/ bin/libRemoteManager.so
b5d0a000-b5d0ec03 /opt/sag/exx/v721/lib/libbasecrypt.so
b4c59000-b4c69cff /opt/intel/vtune/shared/bin/libVTRegLoc.so
b4158000-b41f009f /opt/intel/vtune/shared/bin/libShell.so
b414e000-b4155ed7 /opt/intel/vtune/shared/bin/libShellRes.so
b3d12000-b3d3beaf /opt/intel/vtune/shared/bin/libReports.so
b5d00000-b5d04db7 /opt/intel/vtune/shared/bin/libReportsRes.so
b3cef000-b3d074eb /opt/intel/vtune/shared/bin/libComInfo.so
b3ca7000-b3cd8ecf /opt/intel/vtune/shared/bin/libProductInfo.so
b3ca1000-b3ca4537 /opt/intel/vtune/shared/bin/libProductInfoRes.so
b3b93000-b3c4e3e3 /opt/intel/vtune/shared/bin/libWorkspaceMgr.so
b3b8c000-b3b902b7 /opt/intel/vtune/shared/bin/libWorkspaceMgrRes.so
b3b22000-b3b6a39b /opt/intel/vtune/shared/bin/libCollection.so
b3b1c000-b3b1f5b7 /opt/intel/vtune/shared/bin/libCollectionRes.so
b398f000-b3a9f5b3 /opt/intel/vtune/shared/bin/libActivity.so
b3985000-b398c3f7 /opt/intel/vtune/shared/bin/libActivityRes.so
b3944000-b396e48b /opt/intel/vtune/shared/bin/libFileDialog.so
b3912000-b393528b /opt/intel/vtune/shared/bin/libFileDialogEc.so
b38c9000-b38fae8f /opt/intel/vtune/shared/bin/libFileMgr.so
b38c3000-b38c6cb7 /opt/intel/vtune/shared/bin/libFileMgrRes.so
b3808000-b3889563 /opt/intel/vtune/shared/bin/libTuningBrowser.so
b3800000-b3805217 /opt/intel/vtune/shared/bin/libTuningBrowserRes.so
b3769000-b37cf0d3 /opt/intel/vtune/shared/bin/libWorkspaceUI.so
b3761000-b3766277 /opt/intel/vtune/shared/bin/libWorkspaceUIRes.so
b36f5000-b373ff3f /opt/intel/vtune/analyzer/bin/libCGAddin.so
b3696000-b36d977b /opt/intel/vtune/analyzer/bin/libAnPropContainers.so
b3632000-b3679123 /opt/intel/vtune/analyzer/bin/libCGCons4VT.so
b346c000-b35a044b /opt/intel/vtune/shared/bin/libidvcbase.so
b3383000-b34286fb /opt/intel/vtune/analyzer/bin/libCGConsCore.so
b337c000-b3380daf /opt/intel/vtune/analyzer/bin/libCGPropStorage.so
b3343000-b336bef3 /opt/intel/vtune/analyzer/bin/libCGDataModelVTDBC.so
b3291000-b33110a7 /opt/intel/vtune/shared/bin/libidvcfrw.so
b3277000-b328950f /opt/intel/vtune/shared/bin/libidvcpilot.so
b30ea000-b32049ff /opt/intel/vtune/shared/bin/libidvgrid.so
b30de000-b30e63af /opt/intel/vtune/analyzer/bin/libVTDBRuntime.so
b30ce000-b30d9377 /opt/intel/vtune/analyzer/bin/libCGPruner.so
b30ab000-b30c3e0f /opt/intel/vtune/analyzer/bin/libVTDBC.so
b304a000-b308e3d3 /opt/intel/vtune/analyzer/bin/libCGDP_VTDBC.so
b300a000-b303f8bf /opt/intel/vtune/shared/bin/libigvlayout.so
b2f5c000-b2fcce67 /opt/intel/vtune/shared/bin/libigvviewer.so
b2f45000-b2f55457 /opt/intel/vtune/shared/bin/libigvgraph.so
b2f3b000-b2f4146b /opt/intel/vtune/shared/bin/libigvdatamanager.so
b2ed7000-b2f1fb83 /opt/intel/vtune/analyzer/bin/libvtsdb.so
b2e64000-b2eb7c8b /opt/intel/vtune/analyzer/bin/libCTCG.so
b2e5a000-b2e608c3 /opt/intel/vtune/shared/bin/libdbmanager.so
b2e1f000-b2e4885b /opt/intel/vtune/analyzer/bin/libSymbolProvider_VTDBC.so
b2cc5000-b2dba0f3 */opt/intel/vtune/shared/bin/libismImpl_2.so
b2c83000-b2cbc4d7 /opt/intel/vtune/shared/bin/libcommon_2.so
b2b26000-b2b39c9f /opt/intel/vtune/shared/bin/libsupport_2.so
b2b10000-b2b1e8c7 /opt/intel/vtune/shared/bin/libdtlu_trace_assert.so
b298a000-b29c5857 /opt/intel/vtune/shared/bin/libvtfamgr.so
b297e000-b298624f /opt/intel/vtune/shared/bin/libVTAddr_2.so
b2924000-b2961dcb /opt/intel/vtu ne/shared/bin/libSymVSrvr.so
b28f8000-b29161f7 /opt/intel/vtune/shared/bin/libDynamicLoading_2.so
b2874000-b28d5253 /opt/intel/vtune/analyzer/bin/libCGImpExp.so
b2860000-b286d9bb /opt/intel/vtune/analyzer/bin/libVTSDBUtil.so
b27cb000-b2835a03 /opt/intel/vtune/analyzer/bin/libCGPackNGo.so
b2797000-b27bb1f7 /opt/intel/vtune/analyzer/bin/libAnalyzerWizardsAddin.so
b26e2000-b2773353 /opt/intel/vtune/analyzer/bin/libAnProdInfo.so
b26db000-b26df4f7 /opt/intel/vtune/analyzer/bin/libAnProdInfoRes.so
b26a3000-b26c9f17 /opt/intel/vtune/analyzer/bin/libEcAnalyzerUtils.so
b263e000-b2685fe7 /opt/intel/vtune/analyzer/bin/libSVConsumerEc.so
b2629000-b26380db /opt/intel/vtune/analyzer/bin/libsv_vtune_u.so
b2604000-b261ea3f /opt/intel/vtune/analyzer/bin/libsvpropstorage_u.so
b252c000-b25c9e1f /opt/intel/vtune/analyzer/bin/libsvcore_u.so
b24f8000-b251c35f /opt/intel/vtune/analyzer/bin/libsvcontrol_u.so
b24e2000-b24f159f /opt/intel/vtune/analyzer/bin/libVtGridCtlLite_u.so
b231b000-b245049b /opt/intel/vtune/shared/bin/libidvcbase_u.so
b21d2000-b22099b7 /opt/intel/vtune/shared/bin/libdtlu_file.so
b213e000-b21af8bb /opt/intel/vtune/analyzer/bin/libsvdp.so
b212d000-b213854f /opt/intel/vtune/analyzer/bin/libsv_pi.so
b1f9d000-b20b982f /opt/intel/vtune/shared/bin/libidvgrid_u.so
b1f4b000-b1f8319f /opt/intel/vtune/shared/bin/libidvtextviewer_u.so
b1f2b000-b1f4162b /opt/intel/vtune/analyzer/bin/liblipsdp.so
b1eee000-b1f192d7 /opt/intel/vtune/analyzer/bin/libsv_dedp.so
b1edb000-b1ee8207 /opt/intel/vtune/analyzer/bin/libsv_do.so
b1ec5000-b1ed4c2f /opt/intel/vtune/analyzer/bin/libsv_mh.so
b1c6a000-b1c9f93f /opt/intel/vtune/analyzer/bin/liblips.so
b1c55000-b1c630d7 /opt/intel/vtune/analyzer/bin/libsv_ei.so
b1c4e000-b1c534ff /opt/intel/vtune/analyzer/bin/libbemrl.so
b1c2d000-b1c36d2f /opt/intel/vtune/analyzer/bin/libemrlcore.so
b1bb1000-b1bcd0f8 /opt/intel/vtune/analyzer/bin/libdecem.so
b1b9d000-b1bac693 /opt/intel/vtune/analyzer/bin/libdisem.so
b1b82000-b1b93e95 /opt/intel/vtune/analyzer/bin/libdasm.so
b1b74000-b1b802bf /opt/intel/vtune/analyzer/bin/libdisxsc.so
b1b65000-b1b71a5f /opt/intel/vtune/analyzer/bin/libdecxsc.so
b1b07000-b1b63d4b /opt/intel/vtune/analyzer/bin/libdecoder.so
b1a9a000-b1ae4f7f /opt/intel/vtune/shared/bin/libEnvInfo.so
b1a95000-b1a98a17 /opt/intel/vtune/shared/bin/libcpuinfo2.so.1
b1a8e000-b1a9248f /opt/intel/vtune/shared/bin/libcpuinfoxsc.so.1
b1a86000-b1a8ba57 /opt/intel/vtune/shared/bin/libEnvInfoRes.so
b1a00000-b1a5ea23 /opt/intel/vtune/analyzer/bin/libSamplingConsumerEc.so
b181f000-b1972587 /opt/intel/vtune/analyzer/bin/libSamplingViewerCore.so
b176d000-b17ed25f /opt/intel/vtune/shared/bin/libidvcfrw_u.so
b1588000-b1633eb7 /opt/intel/vtune/shared/bin/libidvtimeline_u.so
b150a000-b15650ff /opt/intel/vtune/shared/bin/libidvchart_u.so
b14c7000-b14f8a27 /opt/intel/vtune/shared/bin/libidvchartelements_u.so
b12a0000-b141d63b /opt/intel/vtune/analyzer/bin/libSPLMDEDataMgr.so
b1239000-b1284d6f /opt/intel/vtune/analyzer/bin/libVTDBJoin.so
b120e000-b122c19f /opt/intel/vtune/analyzer/bin/libSamplingPropContainersEc.so
b109c000-b11a1caf /opt/intel/vtune/analyzer/bin/libModuleHandler.so
b0fcb000-b10581e3 /opt/intel/vtune/shared/bin/libvtfilehandler.so
b0f6e000-b0fab40f /opt/intel/vtune/analyzer/bin/libOptrepAddin.so
b0f57000-b0f67d17 /opt/intel/vtune/an alyzer/bin/libOptRepControl.so
b0f3c000-b0f4fee3 /opt/intel/vtune/analyzer/bin/libOptReportParser.so
b0f38000-b0f3a167 /opt/intel/vtune/analyzer/bin/libOptRepEcClient.so
b0d47000-b0dc40bb /opt/intel/vtune/shared/bin/libidvcswt_u.so
b0ce8000-b0d2c657 /opt/intel/vtune/analyzer/bin/libRatiosEditor.so
b0f16000-b0f2fd0b /opt/intel/vtune/analyzer/bin/libEvents.so
b0c81000-b0cc863f /opt/intel/vtune/shared/bin/libFileSearchAddIn.so
b0c17000-b0c629af /opt/intel/vtune/shared/bin/libActivityEc.so
b0bc7000-b0c014ef /opt/intel/vtune/analyzer/bin/libCGPreferencePagesEC.so
b0b92000-b0bb744f /opt/intel/vtune/analyzer/bin/libSVPreferencePagesEC.so
b0b1b000-b0b70a3f /opt/intel/vtune/analyzer/bin/libSamplingPreferencesPagesEc.so
b0ac3000-b0b0080f /opt/intel/vtune/analyzer/bin/libVTMHPrefPagesEc.so
b0a77000-b0aabde7 /opt/intel/vtune/shared/bin/libFileSearchPrefPagesEc.so
b01e9000-b024c50b /opt/intel/vtune/shared/bin/libVTRun.so
b0f0e000-b0f12d17 /opt/intel/vtune/shared/bin/libVTRunRes.so
b01d2000-b01e558b /opt/sag/exx/v721/lib/libsecurity.so
aed9a000-aedbfabf /opt/intel/vtune/shared/bin/libPropBag.so
b0819000-b085c397 /opt/intel/vtune/analyzer/bin/libCGWizardLogic.so
b07e5000-b0809f87 /opt/intel/vtune/analyzer/bin/libCGWizardEc.so
b069e000-b0790507 /opt/intel/vtune/analyzer/bin/libCGC.so
b0689000-b0697fd7 /opt/intel/vtune/analyzer/bin/libfilestr.so
ae594000-ae5de6a7 /opt/intel/vtune/analyzer/bin/libATLBistroController.so
b067b000-b068643f /opt/intel/vtune/analyzer/bin/libCGMasterProject.so
aed00000-aed1a763 /opt/intel/vtune/analyzer/bin/libCallGraphInstrumentorEngineUtils.so
ae49f000-ae55ec97 /opt/intel/vtune/analyzer/bin/libInstrumentorEngine.so
aed64000-aed6b293 /opt/intel/vtune/analyzer/bin/libbistro_info.so
ae482000-ae498f07 /opt/intel/vtune/analyzer/bin/libInstrumentorEngineUtils.so
ae478000-ae47e08b /opt/intel/vtune/analyzer/bin/libDebugInfo.so
ae469000-ae4739bf /opt/intel/vtune/analyzer/bin/libInstrumentationConfig.so
ae454000-ae464a87 /opt/intel/vtune/analyzer/bin/libProject.so
ae41a000-ae449caf /opt/intel/vtune/analyzer/bin/libConsoleServer.so
aed89000-aed8fb07 /opt/intel/vtune/shared/bin/libActivityps.so
aed83000-aed864d7 /opt/intel/vtune/shared/bin/libActivityHps.so
acff3000-ad00eb97 /opt/intel/vtune/analyzer/bin/libAnalyzerResources.so
acfc5000-acfe4b5f /opt/intel/vtune/shared/bin/libRunCfg.so
abb54000-abba37e7 /opt/intel/vtune/analyzer/bin/libCGExeCtrl.so
aed80000-aed81e43 /opt/intel/vtune/analyzer/bin/libMessageQueue.so
aed78000-aed7d7ef /opt/intel/vtune/analyzer/bin/libCGC_TLBps.so
aed70000-aed75d47 /opt/intel/vtune/shared/bin/libVTRunps.so
aed5e000-aed61cd3 /opt/intel/vtune/analyzer/bin/libCGExeCtrlTLBps.so
abb46000-abb4eba3 /opt/intel/vtune/shared/bin/libfflISM_2.so
abb34000-abb40887 /opt/intel/vtune/shared/bin/libfflJIT_2.so
abb25000-abb2f607 /opt/intel/vtune/shared/bin/libfflELF64_2.so
abb16000-abb20713 /opt/intel/vtune/shared/bin/libfflELF_2.so
a90b4000-a90e4243 /opt/intel/vtune/shared/bin/libdilDWARF32_2.so
abb05000-abb10d03 /opt/intel/vtune/shared/bin/libdilSTABS_2.so
a90a0000-a90ad097 /opt/intel/vtune/shared/bin/libdilISM_2.so
a8c4c000-a8c89e93 /opt/intel/vtune/shared/bin/libFileCopier.so
a8c12000-a8c3bf3b /opt/intel/vtune/shared/bin/libDataObject.so
aafd2000-aaff1a47 /opt/intel/vtune/analyzer/bin/libCGCons4VTUIEc.so
aaf1a000-aaf96adb /o pt/intel/vtune/shared/bin/libidvcswt.so
b5e2c000-b5e32847 /opt/intel/vtune/shared/bin/libidvcjni.so
"Main Thread" id=1 idx=0x4 tid=32410 lastJavaFrame=0xbfab3778
Stack 0: start=0xbf8bf000, end=0xbfabf000, guards=0xbf8c4000 (ok), forbidden=0xbf8c2000
Thread Stack Trace:
at _ZN19CFileSymbolBankImpl13CalcAsmLengthEv+1012(FileSymbolBankImpl.cpp)@0xb2d6f674
at _ZN19CFileSymbolBankImpl12LoadLineInfoEv+3027(FileSymbolBankImpl.cpp)@0xb2d68e37
at _ZN19CFileSymbolBankImpl13CreateISMFileEPw+9146(FileSymbolBankImpl.cpp)@0xb2d57426
at _ZN18CAppSymbolBankImpl16AddPersistFileSVEP10VTModuleID9VTAddressP19INotifyProgressImplmPP19IFileSymbolBankImpl+3621(AppSymbolBankImpl.cpp)@0xb2d03ff9
at _ZN18CAppSymbolBankImpl16AddPersistFileSVEP10VTModuleID9VTAddressP19INotifyProgressImplmPP20IFileSymbolBankImpl5+104()@0xb2d24520
at _ZN17CVTSymbolProvider4InitEv+650(VTSymbolProvider.cpp)@0xb2e34836
at(???.c)@0xb2e8f674
at(???.c)@0xb2e8c1b6
at(???.c)@0xb2e8c446
at(???.c)@0xb2e8a431
at(???.c)@0xb2e95439
at(???.c)@0xb2e9d836
at(???.c)@0xb2e9d9e7
at(???.c)@0xb305e787
at(???.c)@0xb305f864
at(???.c)@0xb3063932
at(???.c)@0xb307453a
at(???.c)@0xb3060169
at(???.c)@0xb3357be8
at(???.c)@0xb335242a
at(???.c)@0xb3411fe8
at(???.c)@0xb341e8e1
at(???.c)@0xb3666452
at(???.c)@0xb366a5b7
at(???.c)@0xaafec171
-- Java stack --
at com/intel/vtune/analyzer/callgraphconsumer/CallGraphConsumer.InitializeClient(Ljava/lang/Object;)V(Native Method)
at com/intel/vtune/analyzer/callgraphconsumer/CallGraphConsumer.createPartControl(CallGraphConsumer.java:114)
at com/intel/vtune/shell/ChildWindowEditor.createPartControl(ChildWindowEditor.java:230)
at com/intel/vtune/analyzer/cgutils/AnUtilsEditor.createPartControl(AnUtilsEditor.java:17)
at org/eclipse/ui/internal/EditorReference.createPartHelper(EditorReference.java:596)
at org/eclipse/ui/internal/EditorReference.createPart(EditorReference.java:372)
at org/eclipse/ui/internal/WorkbenchPartReference.getPart(WorkbenchPartReference.java:566)
at org/eclipse/ui/internal/PartPane.setVisible(PartPane.java:290)
at org/eclipse/ui/internal/presentations/PresentablePart.setVisible(PresentablePart.java:140)
at org/eclipse/ui/internal/presentations/util/PresentablePartFolder.select(PresentablePartFolder.java:268)
at org/eclipse/ui/internal/presentations/util/LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org/eclipse/ui/internal/presentations/util/TabbedStackPresentation.selectPart(TabbedStackPresentation.java:394)
at org/eclipse/ui/internal/PartStack.refreshPresentationSelection(PartStack.java:1144)
at org/eclipse/ui/internal/PartStack.setSelection(PartStack.java:1097)
at org/eclipse/ui/internal/PartStack.showPart(PartStack.java:1311)
at org/eclipse/ui/internal/PartStack.add(PartStack.java:455)
at org/eclipse/ui/internal/EditorStack.add(EditorStack.java:102)
at org/eclipse/ui/internal/PartStack.add(PartStack.java:441)
at org/eclipse/ui/internal/EditorStack.add(EditorStack.java:111)
at org/eclipse/ui/internal/EditorSashContainer.addEditor(EditorSashContainer.java:60)
at org/eclipse/ui/internal/EditorAreaHelper.addToLayout(EditorAreaHelper.java:217)
at org/eclipse/ui/internal/EditorAreaHelper.addEditor(EditorAreaHelper.java:207)
at org/eclipse/ui/internal/EditorManager.createEditorTab(EditorManager.java:820)
at org/eclipse/ui/internal/EditorManager.openEditorFromDescriptor(EditorManager.java:719)
at org/eclipse/ui/internal/EditorManager.openEditor(EditorManager.java:680)
at org/eclipse/ui/internal/WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2593)
at org/eclipse/ui/internal/WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2528)
at org/eclipse/ui/internal/WorkbenchPage.access$10(WorkbenchPage.java:2520)
at org/eclipse/ui/internal/WorkbenchPage$9.run(WorkbenchPage.java:2505)
at org/eclipse/swt/custom/BusyIndicator.showWhile(BusyIndicator.java:67)
at org/eclipse/ui/internal/WorkbenchPage.openEditor(WorkbenchPage.java:2500)
at org/eclipse/ui/internal/WorkbenchPage.openEditor(WorkbenchPage.java:2477)
at com/intel/vtune/shell/ShellPlugin.createChildWindow(ShellPlugin.java:1257)
at jrockit/vm/RNI.c2java(IIII)V(Native Method)
at com/intel/vtune/shell/ShellPlugin.HandleWindowsMessages()V(Native Method)
at com/intel/vtune/shell/ShellPlugin.access$200(ShellPlugin.java:41)
at com/intel/vtune/shell/ShellPlugin$MyTimerTask$ShellUpdateMechanism.run(ShellPlugin.java:104)
at org/eclipse/swt/widgets/RunnableLock.run(RunnableLock.java:35)
at org/eclipse/swt/widgets/Synchronizer.runAsyncMessages(Synchronizer.java:123)
^-- Holding lock: org/eclipse/swt/widgets/RunnableLock@0x865b320[thin lock]
at org/eclipse/swt/widgets/Display.runAsyncMessages(Display.java:3143)
at org/eclipse/swt/widgets/Display.readAndDispatch(Display.java:2845)
at org/eclipse/ui/internal/Workbench.runEventLoop(Workbench.java:1914)
at org/eclipse/ui/internal/Workbench.runUI(Workbench.java:1878)
at org/eclipse/ui/internal/Workbench.createAndRunWorkbench(Workbench.java:419)
at org/eclipse/ui/PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at org/eclipse/ui/internal/ide/IDEApplication.run(IDEApplication.java:95)
at org/eclipse/core/internal/runtime/PlatformActivator$1.run(PlatformActivator.java:78)
at org/eclipse/core/runtime/internal/adaptor/EclipseAppLauncher.runApplication(EclipseAppLauncher.java:92)
at org/eclipse/core/runtime/internal/adaptor/EclipseAppLauncher.start(EclipseAppLauncher.java:68)
at org/eclipse/core/runtime/adaptor/EclipseStarter.run(EclipseStarter.java:400)
at org/eclipse/core/runtime/adaptor/EclipseStarter.run(EclipseStarter.java:177)
at jrockit/vm/Reflect.invokeMethod(Ljava/lang/Object;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;(Native Method)
at sun/reflect/NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;(Native Method)
at sun/reflect/NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun/reflect/DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java/lang/reflect/Method.invoke(Method.java:585)
at org/eclipse/core/launcher/ Main.invokeFramework(Main.java:336)
at org/eclipse/core/launcher/Main.basicRun(Main.java:280)
at org/eclipse/core/launcher/Main.run(Main.java:977)
at org/eclipse/core/launcher/Main.main(Main.java:952)
-- end of trace
Extended, platform specific info:
libc release: 2.5-stable
Elf headers:
libc ehdrs: EI: 7f454c46010101000000000000000000 ET: 3 EM: 3 V: 1 ENTRY: 00509f30 PHOFF: 00000034 SHOFF: 001826c4 EF: 0x0 HS: 52 PS: 32 PHN; 10 SS: 40 SHN: 75 STIDX: 74
libpthread ehdrs: EI: 7f454c46010101000000000000000000 ET: 3 EM: 3 V: 1 ENTRY: 006697d0 PHOFF: 00000034 SHOFF: 0001e4a4 EF: 0x0 HS: 52 PS: 32 PHN; 9 SS: 40 SHN: 40 STIDX: 39
libjvm ehdrs: EI: 7f454c46010101000000000000000000 ET: 3 EM: 3 V: 1 ENTRY: 00057470 PHOFF: 00000034 SHOFF: 002dfe00 EF: 0x0 HS: 52 PS: 32 PHN; 4 SS: 40 SHN: 19 STIDX: 16
===== END DUMP ===============================================================
Thanx in advance...
コピーされたリンク
1 返信
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Thank you for trying Intel VTune Analyzer. Such adump of the JVM should not happen.I therefore suggest that you report this to BEA* orin theirforums.
If the JVM keeps failing, you might want to give the command line interface of VTune (vtl) a try. There is a detailed description of vtl in the documentation.Since vtl does not rely on Java, the dump should be avoided.
Kind regards
Thomas
