Analyzers
Error messages when running VTune Amplifier
Mitsuhiro_T_
I am a first user to Vtune Amplifier and I have limited knowledge on it.
I am using Ubuntu 12.04 64bit and Intel Parallel Studio XE 2013.
I can see the messages on the terminal like below when I run amplxe-gui.
** (amplxe-gui:28202): CRITICAL **: os_bar_hide: assertion `OS_IS_BAR (bar)' failed
(amplxe-gui:28202): Gtk-CRITICAL **: IA__gtk_widget_hide: assertion `GTK_IS_WIDGET (widget)' failed
** (amplxe-gui:28202): CRITICAL **: os_bar_set_parent: assertion `OS_IS_BAR (bar)' failed
When closing the program:
(amplxe-gui:28202): LIBDBUSMENU-GLIB-WARNING **: Trying to remove a child that doesn't believe we're it's parent.
What would be the cause for these messages?
Peter_W_Intel
Probably there were some Gtk libs missed, or version was mismatched in your system.
It will not interfere to collect data and do post-analysis, I think.
Mitsuhiro_T_
Thanks for your reply. Then I will try adjust or reinstall gtk library.
SergeyKostrov
Valued Contributor II
>>** (amplxe-gui:28202): CRITICAL **: os_bar_hide: assertion `OS_IS_BAR (bar)' failed >> >>(amplxe-gui:28202): Gtk-CRITICAL **: IA__gtk_widget_hide: assertion `GTK_IS_WIDGET (widget)' failed >> >>** (amplxe-gui:28202): CRITICAL **: os_bar_set_parent: assertion `OS_IS_BAR (bar)' failed >> >>When closing the program: >> >>(amplxe-gui:28202): LIBDBUSMENU-GLIB-WARNING **: Trying to remove a child that doesn't believe we're it's parent. >> >>(amplxe-gui:28202): LIBDBUSMENU-GLIB-WARNING **: Trying to remove a child that doesn't believe we're it's parent. >> >>(amplxe-gui:28202): LIBDBUSMENU-GLIB-WARNING **: Trying to remove a child that doesn't believe we're it's parent. >>... >>What would be the cause for these messages? Some internal verifications of GTK library ( I think built in Debug Configuration ) failed and you need to look at source codes of the library. Take into account the VTune is Not responsible for these errors and it simply "passes" these errors to a console.
Bernard
As it was already said those problems are not related to VTune functionality  itself.Probably in some cases asserts thrown by GTK lib.
Yi_H_
My CPU is AMD and OS is Ubuntu 14.04 32 bit. I have met the same problem. Have you solved the peoblem yet?
Peter_W_Intel
Original issue was due to GTK* library installation, but VTune command line (amplxe-cl) still can work...
Please try current product VTune(TM) Amplifier XE 2015 which supports Ubuntu* 14.04, and check supported processors for PMU event-based sampling collections, but user-mode sampling still can be used, they are "basic hotspots", "concurrency", and "locksandwaits".
