Analyzers
Error opening trace file
hiamitabha
I just started using the Amplifier XE and cannot get it to work.
I tried to analyze a simple program.
cat /stuff/run.c
#include
int main()
int i=0,j=0,k=0;
for (i=0; i<10000;i++) {
for (j=0; j<1000000;j++) {
k++;
printf("Value is %d\\n",k);
When I analyze it for hotspots using the GUI I get an error after the run is completed saying "failed to finalize the result"
I tried to run using the console command.
./amplxe-cl -collect hotspots /stuff/run
Value is 1410065408
Using result path `/opt/intel/vtune_amplifier_xe_2011/bin64/r000hs'
Executing actions 8 % Loading '22981-22985.0.trace' file terminate called after throwing an instance of 'pprofiling::trace::__E271'
Aborted
The version of Linux is:
Linux 2.6.32-100.22.1.el5 #1 SMP Mon Oct 25 20:46:50 EDT 2010 x86_64 x86_64 x86_64 GNU/Linux
The processor is:
Intel Xeon CPU E7- 8870 @ 2.40GHz
Please help.
Amitab
Peter_W_Intel
Thanks for your example code,however it seems there is no problem on my side:
[root@NHM02 problem_report]# amplxe-cl -collect hotspots -- ./run
Value is 1410065408
Using result path `/home/peter/problem_report/r000hs'
Executing actions 74 % Generating a report
Summary
Elapsed Time: 21.295
CPU Time: 21.260
Executing actions 99 % done
[root@NHM02 problem_report]# amplxe-cl -version
Intel VTune Amplifier XE 2011 Update 3 (build 150226) Command Line Tool
Copyright (C) 2009-2011 Intel Corporation. All rights reserved.
I guess it was caused by on your Cents OS version (2.6.32-100), please check supported OS is CentOS* 5.5 (2.6.18-164??) in release notes.
Regards, Peter
hiamitabha
Hi Peter,
I had sent you a private message on the platforms on which Amplifier is supported. Did you receive it?
/Amitab
