This is Linux RHEL 6 (Red Hat Enterprise Linux 6). I cannot stop a running collection because the amplxe-cl tool does not see one running, but it is running.
example:
when I try to stop the collection, the following error shows up
example:
[bash]amplxe-cl --collect hotspots -knob accurate-cpu-time-detection=true -follow-child -target-duration-type=short -no-allow-multiple-runs -no-analyze-system -data-limit=1000 -slow-frames-threshold=40 -fast-frames-threshold=100 -result-dir=/tmp/test --search-dir /tmp/symbols --target-process server &[/bash]
[bash]$ amplxe-cl --command stop Fatal error: Cannot detect running collection to deliver command. $ [/bash]
I see the collection it is running though:
[bash]28810 pts/1 Sl 0:00 amplxe-cl --collect hotspots -knob accurate-cpu-time-detection=true -follow-child -target-duration-type=short -no-allow-multiple-runs -no-analyze-system -data-limit=1000 -slow-frames-threshold=40 -fast-frames-threshold=100 -result-dir=/tmp/test --search-dir sym:r=/tmp/symbols --target-process server 28817 pts/1 Sl 0:00 /opt/intel/vtune_amplifier_xe_2011/bin64/amplxe-runss --ui-output-format xml --ui-output-fd 4 --option-file /tmp/test/config/runss.options 28845 pts/1 R+ 0:00 ps a [/bash]
what could be wrong here?
Thank you,
-Rilson
Hi Rilson:
Which version of the VTune Amplifier XE are you using? Attach to process for hotspots on Linux is only supported in Update 3 or later. Try lightweight-hotspots if using an earlier version.
Note, when you specify a result directory or -user-data-dir on the collection command line, you must specify that option on the --command comand line, as well. For example, if you specified:
to collect data, you should use the following command to check the status:
That is because the status is determined from some file within the results directory.
So, basically, whatever results directory is used by the collection command, the same results directory must be used by the command with the --command option.
amplxe-cl -collect hotspots -result-dir /tmp/test -target-process server &to collect data, you should use the following command to check the status:
$ amplxe-cl -result-dir /tmp/test --command statusPPID PID STATE NAME
011038 000513 RESUME serverThat is because the status is determined from some file within the results directory.
Hi Rilson:
Hi Mr. Anderson,
Thanks for the fast reply. It worked by adding "-result-dir" to the stop command (is this in the help somewhere?)
My VTune is "Intel VTune Amplifier XE 2011 Update 3 (build 150226) Command Line Tool".
I have another doubt for you, I'll open it in a different thread =D
Thank you again,
-Rilson
Thank you again,
-Rilson
