Analyzers
5254 Discussions
Error running vtune-gui
zshathry
When I run:
vtune-gui
I get the following error:
[29340:1029/101849.441418:ERROR:cert_verify_proc_builtin.cc(677)] CertVerifyProcBuiltin for 127.0.0.1 failed:
ERROR: No matching issuer found
 and the gui interface opens but my keyboard strokes are showing in the cli instead of the gui app.
Here are my specs:
- MacBook Pro 15-inch 2018
- macOS Ventura 13.5.2
- vtune-gui 2023.2.0
JaideepK_Intel
Thank you for posting in intel communities.
As per Intel Vtune system requirements, MacOS is currently unsupported, attaching system requirements links for your reference.
Link: https://www.intel.com/content/www/us/en/developer/articles/system-requirements/vtune-profiler-system-requirements.html
>> Do you want to use Intel Vtune to profile an application or to view results?
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Jaideep
JaideepK_Intel
I hope you are doing well.
Jaideep
JaideepK_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
