Analyzers
5294 Discussions
Error: unable to open SELI interface
christoph-bartoschek
when I try to do a sampling run on the remote server I get the following error on the remote host:
000 04/19/2007 01:55:09 10072 [ERROR] unable to open SELI interface
The GUI says:
Error: unable to create environment file "./environment.xml" on localhost.localdomain (127.0.0.1): [ERROR] unable to open SELI interface
aokunev
Hi
Can you please add some details - do you use supported Linux distribution? What VTune version is?
This could be installation problem - please check /var/log/vtune_install.log is good.
Anyway - it's better to submit this issue to Premier.
thanks, Andrei
The version is 9.0 from the package vtune_linux_9.0.833.tar.gz.
The linux version is a supported one.
The installation log looks fine. The driver is build without problems.
John_O_Intel
Is this a known issue ? I ran into this on Red Hat EL 5.3, running 9.1.0 20080814102 on Intel 64. Is there a workaround ?
thanks,
John
Peter_W_Intel
Quoting - John O (Intel)
thanks,
John
Accesshttps://registrationcenter.intel.com/RegCenter/Download.aspx?productid=1101 to get latest v9.1 Update 2, build #226 which supports Red Hat EL 5.3.
Regards, peter
John_O_Intel
Regards, peter
Hi Peter,
Thanks for the info. I requested this to be installed on my machine. I also opened a VTune support issue to improve the error message.
thanks again,
John
