Analyzers
Failed to allocate Injector, Error = INJECTOR_ERR_FAILED_TO_CREATE_REMOTE_THREAD
Uzair_A_
I'm trying to use an evaluation version of VTune Amplifier XE for windows 2016 to profile my application which is a windows service.
I got the following collection log:
[Instrumentation Engine]:Failed to allocate Injector, Error = INJECTOR_ERR_FAILED_TO_CREATE_REMOTE_THREAD
Profiling Details:
OS: windows server 2008 R2
target type:  Attach to Process
target is a running windows Service
Could you please help me on this? Thank you!
Peter_W_Intel
A simple solution is to use hardware PMU event-based sampling, e.g. advanced-hotspots, general-exploration,... (with administrator privilege)
If you profile a windows service application with user-mode sampling (basic-hotspots, for example), read this article
Peter_W_Intel
Uzair_A_
Hi Peter,
Thanks for your prompt reply. Your post was very helpful and I was able to attach to my service and could profile it.
Now I have another doubt.
My whole application consists of a service and a file system filter driver.
Now, is it possible to do windows kernel profiling and specifically file system filter driver profiling with VTune?
Thanks in advance.
Peter_W_Intel
This is good news from you.
>My whole application consists of a service and a file system filter driver. Now, is it possible to do windows kernel profiling and specifically file system filter driver profiling with VTune?
You may try advanced-hotspots (or other event-based sampling collectors) with "-analyze-system" option, after data collecting to open Bottom-up report, move to "bottom" called "Filter" panel to set "User/system functions", select module of your interest to filter data. I think that your *hot* driver should be there.
If your application have many waits e.g. disk IO, consider to use locksandwaits analysis to measure IO waits.
