Analyzers
5282 Discussions
Failed to use Counter Moniter
kiddxin75
I tried to use Counter Moniter activity to check the system performance of an application. But the VTune always failed to run the activity. There is a popup for the error: "Execution of D:\PathXXX\YYY.exe failed for unknown reasons. Try running the application seperately to be sure permission and access are correct.". In fact it seems I have this error on any application when I tried to use Counter Monitor activity.
I have no problem to run the application and I am using an admistrative account. I also have no problem to run the Samplingand Call Graph activity on the same application. And I build the application in Microsoft Visual Studio 2005 under Windows Vista.
Can anybody give me some guide on this error please? Does anybody has the same error before?
Thanks a lot in advance.
KIDD
kiddxin75
Quoting - kiddxin75
I tried to use Counter Moniter activity to check the system performance of an application. But the VTune always failed to run the activity. There is a popup for the error: "Execution of D:PathXXXYYY.exe failed for unknown reasons. Try running the application seperately to be sure permission and access are correct.". In fact it seems I have this error on any application when I tried to use Counter Monitor activity.
KIDD
By the way, I am using VTune Performance Analyzer 9.1 (Build 138).
Peter_W_Intel
Quoting - kiddxin75
KIDD
Based on my experience, it was not caused by Intel VTune Performance Analyzer, please check if you can run perfmon.exe from Microsoft* normally? Usually some data are corrupted in registry table, please refer tohttp://support.microsoft.com/kb/152513to know more in detail.
Thanks, Peter
David_A_Intel1
Also check out the elevateUserRight.exe utility in the VTuneAnalyzerBin directory. It may be a user permissions issue. Are you running as Administrator or another user on the system?
kiddxin75
Thanks for the reply.
I have no problem to run the PerfMon and I am running as an administrator.
When running elevateUserRight.exe verify, it said "Counter Monitor" is available and "Sampling" is available
When running elevateUserRight.exe add_all, it said both are already availbale already.
Any more information?
Thanks a lot.
KIDD
geoffrey-burling
This is more or less a shot in the dark. From the error message you posted above it appears you are running an executable on the D: drive. If so, is this drive a network drive? In that case, move the executable to a local drive and try it again. Network file systems introduce another factor of complexity to analysis that could lead to unpredictable (& unreliable)results.
Geoff
