Analyzers
GFLAGS application verifier and Inspector
lionel-muratore
I've got a strange behaviour using Inspector this week, when I launched memory leak detection, I've got this error:
Memory error analysis: started
Result file:
Error: An internal error has occurred. Our apologies for this inconvenience. Please gather a description of the steps leading up to the problem and contact the Intel customer support team.
Application exit code: [-2147483645]
Result file:
Memory error analysis: terminated
So I found that the problem comes from Global Flags from Microsoft when the option "Enable application verifier" is checked.
The behaviour seems to be the same with Amplifier (even if I don't use it for this project).
Could you please check if there is a work-around for this?
Lionel
Kirill_R_Intel
Hello Lionel,
I'vetested mi3 analysis with"Enable application verifier"checked and all worked fine. I've used glags.exe to set the flag and Intel Inspector XE update 8 on Windows 7 x64. Do you use thelatest update of Inspector XE? Do you set other Global Flags?
Is it possible to provide a small reproducer that has the problem on your setup?
Kirill
SergeyKostrov
Valued Contributor II
[SergeyK] -2147483645 = 0x80000003 - Exception: Hardcoded-Breakpoint
To be honest, I'm not 100% sure. Please try to do your own verifications.
Sergey
Bernard
You application has encountered hardcoded breakpoint.Sometimes compiler will fill a buffer with int 3 0xCC instruction in order to triger debugger breakpoint and it is somehow related to your application behaviour.
