Analyzers
GPU in-kernel hardware not support but it should be
YellowMan
I can't run GPU In-kernel Profiling with this error : Current hardware does not support GPU in-kernel profiling. Whereas I have :
  • Intel I7-6700K with HD 530
  • Windows 7 / 64 bits
  • VTune 2018
and Intel documentation say GPU In-kernel is available on the processors based on Intel® microarchitecture code name Broadwell and later.
Broadwell is 5th Gen and i have 6th Gen (Skylabe). I don't understand why i can't run this profiling.
Do you have some ideas ?
Svetlana_K_Intel
Skylake - Win configuration should be supported, yes.
I'd recommend to update the GPU driver to the latest available and to use the latest VTune version (it should be 2019 Update4 at the moment) https://software.intel.com/en-us/vtune.
Please, write back if the problem persists.
P.S. I also need to mention that Win7 is deprecated and we do not test the product with it anymore.
Svetlana_K_Intel
YellowMan
It's work with VTune 2019 Update 1
