Analyzers
5271 Discussions
Get user events from VTune doesn't work with attach to process
FantasticMrFox
TLDR;
I am attempting to run a command line vtune attach to process analysis for some instrumented code with the application instrumentation lib supplied by intel. I have succeeded, in collecting user events when running within the vtune application (both command line and GUI). When I use `-target-pid` command line option to connect to the same application, user events do not show up in the profile. The environment setup suggested in the instructions for attaching to a process does not work.
## The long version ##
I have broken this down again and again, and i have hit the minimum amount of things going on here. I am running Ubuntu 20.04 with intel vtune installed as part of the oneapi installer package. I have built an example application, which i can share, but it basically spawns threads and does some random computations. I have instrumented the code with `itt` as such:
#include <ittnotify.h>
__itt_event cloud_in_event = __itt_event_create( "CloudIn", 7 );
void add() {
__itt_event_start( cloud_in_event );
This works correctly when run through the gui. Aka, i compile my application with the following:
g++ -g -O3 -fno-asm -std=c++17 -I/opt/intel/oneapi/vtune/latest/sdk/include -DUSE_THR example.cpp -g -o ./example -lpthread -lm -L/opt/intel/oneapi/vtune/2021.4.0/sdk/lib64 -littnotify -ldl -D_LINUX
I start the gui using:
. /opt/intel/oneapi/setvars.sh && vtune-gui &
Run it using the cpu hotspot analysis in hw mode. The application runs and i get this in the output:
cUPJ0
Yay, my user event is there. All is well.
The equivalent command line also works:
/opt/intel/oneapi/vtune/2021.4.0/bin64/vtune -collect hotspots -knob sampling-mode=hw -knob stack-size=0 -app-working-dir /home/development/example/example --app-working-dir=/home/development/example/example -- /home/development/hovermap/example/example
However, if i run the application on its own (using the correct setup for the link path in the environment variables for `INTEL_LIBITTNOTIF`), then attach with the GUI to that process (or with the command line). There are no user events (aka, the `CloudIn` event in the above image) in the profiler data.
If I print out the environment variables in the application, there are quite vast differences in the environments when profiling directly, vs when attaching. For example, there is the following:
INTEL_JIT_PROFILER32=/opt/intel/oneapi/vtune/2021.4.0/lib32/runtime/libittnotify_collector.so
INTEL_JIT_PROFILER64=/opt/intel/oneapi/vtune/2021.4.0/lib64/runtime/libittnotify_collector.so
ENABLE_JITPROFILING=1
Exists in the gui based run environment, but the setup instructional says nothing about these environment variables. I have also tried setting them with no luck.
Any ideas what extra stuff i need to set up?
AthiraM_Intel
We are working on it internally, will get back to you soon.
Could you please share the sample reproducer so that we can try out the same from our end.?
FantasticMrFox
Sure, here is the code that i run:
#include <thread>
#include <mutex>
#include <chrono>
#include <iostream>
#include <atomic>
#include <vector>
#include <limits>
using namespace std::chrono_literals;
std::vector<uint64_t> some_storage;
auto fibonachi() {
    uint64_t i = 1, i_prev = 1;
    while (i < 1000000) {
        auto temp = i;
        i += i_prev;
        i_prev = temp;
        if (i % 2) {
            some_storage.push_back(i);
    return i;
struct Counter {
    void add() {
        std::scoped_lock sl(lock);
        fibonachi();
        count++;
    int get() const {
        uint64_t sum = 0;
        for (auto i : some_storage) {
            sum += i;
        return count + sum;
    mutable std::mutex lock;
    volatile int count = 0;
int main(int, char **, char **envp)
    std::cout << "\n\n=========================================";
    for (char **env = envp; *env != 0; env++)
        std::string enviro = *env;
        std::cout << enviro << std::endl;
    std::cout << "=========================================\n\n";
    std::atomic_bool is_finished = false;
    Counter c;
    std::thread incrementor([&](){
        while (!is_finished) {
            c.add();
            std::this_thread::sleep_for(1ms);
    std::thread printer([&](){
            std::cout << c.get() << std::endl;
            std::this_thread::sleep_for(50ms);
    std::this_thread::sleep_for(500s);
    is_finished = true;
    incrementor.join();
    printer.join();
    return 0;
 I have also attached the environment variables for both cases of running:
from_attach.txt - the result of export run from where the application is run standalon (with the expectation that i will attach to it afterwards)
from_run_through_gui.txt - the result of export, run from the application when run through the gui.
As a reminder, this all works when running through the gui or running from command line, but not when attaching using:
vtune --collect hotspots -knob sampling-mode=hw -knob stack-size=0 -target-pid $(ps -ef | grep example | head -n 1 | awk '{print $2}') -result-dir /home/user/development/profiling/test_01
AthiraM_Intel
Thanks for sharing the sample reproducer.
We are working on it internally, will get back to you with an update.
AthiraM_Intel
We tried in Ubuntu 20.04 with Vtune 2021.5 and we were able to run the sample.
Could you please try to update the Vtune to the latest version and try again.
Also share the difference observed in environment variables and the commands used to print out the environment variables.
FantasticMrFox
Hi, thanks for looking into it.
Please be specific. When you say we were able to run the sample. Do you mean that you were able to run the application above in an environment and then attach to it from the gui using the `-attach-pid` argument from a different terminal?
This is what i am trying to achieve. If i run the application directly, that i can correctly collect user tasks.
As requested i have compiled and run this now with Vtune 2021.5.0 with the same results. To repeat the above that is:
1. I can get user events in the profiler when i run the application directly from the GUI.
2. I can not get user events when i run the application stand-alone, then attach to it from the GUI.
Attached are the environment variables from each run. In order to get these you can see in the application the following code:
This will print out the environment variables in each of the cases.
AthiraM_Intel
Sorry for the confusion, we were able to generate the vtune reports using attached process option. However as you mentioned, the user events are missing. We are checking on this internally and will get back to you with an update.
Vladimir_T_Intel
Could it be possible that by time you attached to a PID, the events have already happened and you are collecting just the rest of your execution (e.g. in a sleep(500) call)? I'd "debug" such case by calling a "heavy" function after all events, and observe its beginning in the results (filtered-in on a timeline).
FantasticMrFox
Hi Vladimir,
This is not an issue. Your counterpart (Athira) has already expressed that they have reproduced the issue. But to be complete lets walk through some parts of the example code:
1. Look at the layout, it is quite simple, in main we have:
// Set up a counter thread
// Set up a printer thread
// Joint the 2 threads
This means that the program runs for 500 seconds. It would be quite hard for me to miss the program itself.
2. The events occur in the second thread:
where `get` does:
So a rundown here is that we loop for the length of the program (aka 500s as explained above), and we do get every 50ms. That means an event is fired every 50ms until the end of the program. This is confirmed by the print to screen which we also see.
Again, this works fully when run in command line like `vtune -collect hotspots example` or from the gui. But when attaching using `-attach pid` we get the profile and we can see the function `get` being called. But no user event is seen.
Vladimir_T_Intel
Sorry, I didn't compile/run your example, but looking at your source code I do not see any int __itt_event_end() call. Most probably the very first __itt_event_start() call happened before attachment with VTune, and the rest of __itt_event_start() call didn't have any affect. So, that's why you might observe only one event mark on the timeline when launched the example under VTune.
The itt_event is global, so it's expecting start and end in any thread:
https://software.intel.com/content/www/us/en/develop/documentation/vtune-help/top/api-support/instrumentation-and-tracing-technology-apis/instrumentation-and-tracing-technology-api-reference/event-api.html
int __itt_event_end( __itt_event event );
Call this API following a call to __itt_event_start() to show the event as a tick mark with a duration line from start to end. If this API is not called, this event appears in the Timeline pane as a single tick mark.
Vladimir_T_Intel
Just curious, did it help?
FantasticMrFox
Hi Vladimir, I have just tested it and it did not help.
I changed the function with the user task to:
   void add() {
        fibonachi();
        count++;
         __itt_event_end( cloud_in_event );
You can see that we now do beginning and end. As before, if i run the application directly from the gui or using `vtune -collect hotspots example` in the command line, then i get the user events. Now they are longer as well, I guess because they have a beginning and an end:
But, if i use the gui (or the command line) to attach to the already running process, these events do not appear.
Vladimir_T_Intel
I do observe this problem as well. The development team is taking a look at a bug i submitted along with your reproducer. Thanks for that!
One more problem that I came across is that even in a launch mode, in case of stopping collection with Ctrl+C, user tasks do not show up in results as well. Submitted.
msmart
Has there been any update on this bug? I have also just encountered it.
Many thanks to FantasticMrFox for the documentation which helped me isolate the problem.
Vladimir_T_Intel
As far as I can see, the bug has not been fixed yet. Sorry.
Jeffrey_R_Intel1
This is not planned to be fixed in the near future.
However, as a workaround, you can use ITT API user tasks (instead of events) with attach to PID.
For more details on ITT user tasks, see https://www.intel.com/content/www/us/en/develop/documentation/vtune-help/top/api-support/instrumentation-and-tracing-technology-apis/instrumentation-tracing-technology-api-reference/task-api.html
Jeffrey_R_Intel1
As mentioned previously, this will not be fixed.
The workaround is to use ITT API user tasks instead of events. See my sample output below.
The event time is not recorded, which is why it does not appear in the GUI timeline display.
vtune 2023.1.0 command line output includes:
Top Tasks
Task Type    Task Time Task Count Average Task Time
Parallel Task   69.523s     797       0.087s
Serial Task    59.158s     709       0.083s
Parallel Event   0.000s     800       0.000s
Serial Event    0.000s     200       0.000s
